Soft Brakes !!
Discussion in 'Off Topic Hot Rods & Customs' started by Anthony Herrera, Jul 23, 2025.
  1. Kit is wrong for that car
    1 vote(s)
    100.0%
  2. booster is issue
    0 vote(s)
    0.0%
  1. Anthony Herrera
    Anthony Herrera
    1963 buick lesabre all drum brake system
    2004 LM7 LS 5.3 out of a Tahoe.
    Aftermarket universal brake 10” dual diaphragm brake booster.
    A Chrome Flat Top Dual MC.
    Routed all new brake lines to the mc.
    Got the pedal ratio/ geometry the same.
    Bled the MC as well as the entire system ……but still soft but only when the car is turned on. As soon as the car turns on the pedal is DEAD. it’ll return slowly .
    My best bet is the booster is faulty and not doing it job …..
    i have strong 18-19 HG of vacuum. the car ran great until the booster went out . (i don’t have the Original booster )
  2. RodStRace
    RodStRace
    Title = soft = mushy
    soft on (off?) = soft
    car on pedal is dead = ? = hard, firm, no pedal, normal?
    return slowly = another different symptom.
    Disconnect booster. retry.
    Compare OE booster specs with universal 10 inch dual diaphragm booster specs.
    Anthony Herrera likes this.
  3. Anthony Herrera
    Anthony Herrera
    with the car off i have a nice firm pedal but as soon as the car turn on soft pedal like the slightest touch sinks it to the floor.
  4. RodStRace
    RodStRace
    Gotcha! I thought that was what you were trying to say.
    I get the strong suspicion the new booster is overpowering the rest of the system.
    As said, try to find specs on the original, even if you don't have it. I don't know of a way to modify or adjust a booster's****ist. You sure don't want to restrict the vacuum or create a leak. So you will probably end up swapping to another replacement or finding a rebuilt stocker.
  5. Anthony Herrera
    Anthony Herrera
    i’m looking into a replacement but not sure with which one to go with. Dual Or Single ? 9” 10” or 11” was told the bigger the better but i’m not sure
  6. RodStRace
    RodStRace
    Considering the one on there is over-assisting, it should be quite clear.
  7. Anthony Herrera
    Anthony Herrera
    i suspected that the booster on now isn’t working properly my****umption lol. i have a 5.3 LS now as well but maybe ima just go back to a 9” single diaphragm
  8. 57 Fargo
    57 Fargo
    Explain how the booster is “overpowering” the system? If it’s too much booster the pedal will be extremely touchy but wouldn’t go to the floor.
    dogwalkin and twenty8 like this.
  9. Anthony Herrera
    Anthony Herrera
    my****umption is the cheap 50$ universal booster i purchased was just faulty and or bad
  10. twenty8
    twenty8
    If the booster is giving too much****istance the pedal would be overly sensitive causing harsh application of the brakes. It would not cause a soft pedal.
    My guess...??? There is still air in the system. Rebleed at all four corners.
    57 Fargo likes this.
  11. Anthony Herrera
    Anthony Herrera
    bled the dual mc twice and all 4 corners twice …. not to mention vacuum pump i used as well and still nothing im sure all the air is out
  12. bobss396
    bobss396
    All drum brakes, make sure the adjustment is good. I'll make them a few clicks tight, then bleed, readjust.
    The bad booster acid test, turn the car off. Pump out all the residual vacuum until the pedal is hard. With a foot on the pedal, start the car. The pedal should sink, but not go to the floor.
    You may have a bad master. If this was my car, I'd source a factory master booster from a 1967 car, the same model as what you have.
    Rock Auto has matched masters/boosters. Sometimes they have pictures of the booster mounting to help match it up to your old one.
  13. Anthony Herrera
    Anthony Herrera
    in my case it does sink to the floor…… and fast as hell!so source a booster /mc combo from a 1967 vehicle? they all came with stock drums?
  14. Anthony Herrera
    Anthony Herrera
    i have a 63 by the way not a 67. my original system had a single pot master cylinder . i now want to run a dual for that extra safety
  15. RodStRace
    RodStRace
  16. Anthony Herrera
    Anthony Herrera
    since i didn’t get my mc and booster as a KIT i sourced each one separately in hopes they would work . I’m going to purchase a dual mc and 9” single diaphragm brake booster as that was the same size as my original one .
    when sourcing one …since this car is a B body , all the kits i find for sale are for “A” “F” “X” body’s …. does that matter in my case ? since i’m going to be retrofitting ?
  17. RodStRace
    RodStRace
    Look up what the original parts were. Find out the specs needed to compare. Check interchange of them. See if they are close to the others.
    It's research, I don't have that all in my head and the chances of someone else on here knowing the exact solution to this is unlikely if it's been on here this long.
  18. Anthony Herrera
    Anthony Herrera
    true that sir.! thanks !! appreciate your help
  19. RodStRace
    RodStRace
    Hey, we would all love for someone to say, "This part, number***X available from***X and it's the best and cheapest fix, watch out for this one small detail".
    The power of the HAMB is often amazing. But some stuff you just have to dig to find. :oops:
  20. bobss396
    bobss396
    The '67 is a dual system, an upgrade from a single master.
  21. Anthony Herrera
    Anthony Herrera
    yes sir .i didn’t know my facts lol. will be sourcing a 9” single diaphragm brake booster and dual master cylinder kit . Instead of getting them separate.
  22. 57 Fargo
    57 Fargo
    I would figure out why you have soft brakes before ordering more random parts but that’s just me.
    bobss396 likes this.
  23. Anthony Herrera
    Anthony Herrera
    aside from the cheap 50$ brake booster i purchased and several tests later im almost 90% sure its due to mc/booster not matching . other 10% is maybe wheel cylinders , and rear shoes need adjustment so will check that tomorrow
  24. 57 Fargo
    57 Fargo
    Ok, as long as you’re sure, you should look at how a booster works and see why a booster will/cannot cause a soft pedal first. But you asked for help all while being convinced you already know the answer.
    TrailerTrashToo likes this.
  25. Anthony Herrera
    Anthony Herrera
    understood . ….. i’m aware a booster cannot cause a soft pedal . but a bad mc can or if it’s not properly matched with the boosters push rod length and that’s what i believe happened in my case . comparing this aftermarket mc to my original one (sourced online pics ) .
  26. Wobbly
    Wobbly
    from UK
    When you check the rear shoe adjustment make sure the parking brake cable is slackened off and that the parking brake levers on the shoes are not opening the shoes up. Once the rear shoes are properly adjusted then adjust the parking brake. I don't think this is your problem but incorrect adjustment procedures on the rear brakes can cause excessive brake pedal travel.
  27. 57 Fargo
    57 Fargo
    Nope it still won’t cause a soft pedal and it’s easy to measure.
    Explain what’s happening in a bad master cylinder to cause a soft pedal please? Or how the incorrect pushrod length will?
  28. Tickety Boo
    Tickety Boo
    from Wisconsin
    Find out the bore size of the front and rear brake cylinders, then check the bore size of the new master. You may find the new masters bore too small to fill larger bore wheel cylinders.
    Had a similar problem when I installed a Mustang 2 dual master/booster kit advertised to bolt into early Fords. :rolleyes:
    An adaptor allowed it to bolt in; problem is the small bore of the master in the kit, could not supply enough brake fluid to fill the large 48 ford 1 1/8-wheel cylinders in one pump, :oops:
    Took me a while to figure the kit was made for a car with updated brakes already :confused:
  29. Ned Ludd
    Ned Ludd
    A week late, but: if you turn the engine off again, does it return to a firm pedal?
    By "to the floor", do you mean right to the floor as if there were no fluid in the system? Or just disconcertingly close to the floor?
    Brake boosters work by balanced vacuum. When the engine is running, both sides of the diaphragm are subject to vacuum. Apply the brakes, and atmospheric pressure is admitted to one side of the diaphragm, and it is this pressure which supplies the****ist. You're never dealing with more than atmospheric pressure, though the****ist pressure on the MC will depend on the ratio of the squares of the diaphragm diameter and the MC bore diameter, and that can be a lot more than 14.7psi.
    Without knowing all the specifics, it sounds like that****ist pressure ought to be encountering the incompressibility of brake fluid, but isn't. If you're not losing fluid somewhere, air must be getting in. You've bled the system several times: does it stay bled?
  30. MAD MIKE
    MAD MIKE
    from 94577
    You are keeping the stock drums and wheel cylinders correct?
    What was the size of the original MC bore?
    What is the size of the current 'flat top' MC bore?
    Did the original MC use residual valves?
    Does the new MC have residual valves?
    Even when the pedal was flooring, how well did the car stop?
    Boosters are perpetually sinned with.
    Most modern boosters are double diaphragm and will provide too much****ist in an older, otherwise stock, application. A simple single diaphragm booster, especially with self energizing drums, is all that is needed if you desire PB.
    If the pushrod through the firewall is too long it may be pushing on the booster, activating the poppet valve which will lead to atmo pressure to push on the backside of the diaphragm causing unwanted****ist.
    If the poppet valve is leaking it will also self activate the booster, and not allow for the pedal to self return.
    If the pedal is not returning, the boosters piston return spring may be broken.
    Unless the condition of the booster is known, it can be a gamble to use a used booster.
