Termites and Bowties- Early Chevy Group
Discussion in 'The Hokey Ass Message Board' started by 29bowtie, Jan 7, 2009.
  1. Brother, you need to bribe that Chevrolet Dealer somehow to purchase THAT sign or billboard that just happens to show the year of your Chevrolet Coupe... That's TOO much of a coincidense...
    snoop74 and Jay Altemus like this.
  2. snoop74
    snoop74
    Haha I know crazy right!? I had to get a pic in front of it, a
    31chevymike likes this.
  3. Smokeshow
    Smokeshow
    Square body syndicate did an amazing 3+3 with a ***mins swap. blue and white truck. Do it!
  4. swade41
    swade41
    from Buffalo,NY
    A local car that's pretty untouched and stayed in the family
  5. snoop74
    snoop74
  6. Jay Altemus
    Jay Altemus
    Today was awesome. Mini-tub day. I relocated the body to frame support INSIDE the frame so I would have room for the mini-tub. I made a pattern to match the curve of the wheel well with duct tape. (Something I saw done on a video.) Used that pattern to cut a 4” strip of 18g steel. It was sorta crescent shaped when flat but fit perfectly when shaped over the wheel well. Held it in place with Clecos.
    Then I cut out the wheel well leaving a 1” flange. I then deleted the temporary 2” wheel spacer. I never intended to use wheel spacers. They are only temporary. The mock up looks better than I had hoped. The wheels in the pic have 4.25” of backspacing. I’ll likely buy wheels with 3.5”of backspacing. Did some body work too. Too many pics to post them all now.
    IMG_0235.jpeg IMG_0238.jpeg IMG_0240.jpeg IMG_0244.jpeg IMG_0245.jpeg IMG_0246.jpeg IMG_0260.jpeg IMG_0261.jpeg IMG_0279.jpeg IMG_0288.jpeg IMG_0289.jpeg IMG_0290.jpeg IMG_0293.jpeg IMG_0298.jpeg IMG_0301.jpeg IMG_0307.jpeg IMG_0315.jpeg IMG_0317.jpeg IMG_0316.jpeg
    laidbackluis, TFoch, r2c1 and 5 others like this.
  7. Six Ball
    Six Ball
    from Nevada
    You are good!!
    TFoch, Jay Altemus and 31chevymike like this.
  8. Jay Altemus
    Jay Altemus
    Before I start to weld the pieces of the mini tub together, I thought it wise to have y’all review my plan and give me advice.
    The first picture shows the strip of 18 gauge metal held in place with Cleco fasteners and the original fender well in the new position. My plan is:
    1. Hold all of the pieces together with rivets or Cleco fasteners for mock up.
    2. Then make short cuts along the joint line with the yellow arrows so I can **** weld the splice piece flush with the wheel well flange.
    3. I will need to go slowly and planish the weld bead so I don’t get too much distortion from heat and shrinkage.
    4. I would then make any final adjustments to the wheel well tub before doing the same thing with that weld bead (red arrows).
    It’s a lot of welding. Making my own new wheel wells would reduce the welding by half, but I do not have the skill to fabricate my own wheel wells from new steel.
    Another issue. I think the body damage to the DS rear quarter panel was more significant than I had realized. I have successfully hammered out the two dents at the very back of the driver side wheel well (red oval). However, when I compare the driver side rear quarter with the p***enger side rear quarter, I think the driver side wheel well bead is pushed towards the centerline more than on the p***enger side. The belt line extending back from the door seems the same as the PS. The DS area with the red oval was partly rolled under and I rolled it back out when I hammered out the 2 dents in that same area. I think I need to pull the wheel well bead away from the center line a little bit more. I took some pictures (with yellow rectangles) so you can compare. Maybe 31ChevyMike, Snoop74, or anyone else could show me a picture of their rear quarter panel from the same angle for my comparison?
    IMG_0344.jpeg IMG_0349.jpeg IMG_0350.jpeg IMG_0352.jpeg IMG_0348.jpeg IMG_0353.jpeg IMG_0309.jpeg
    TFoch, snoop74, Kelly Burns and 2 others like this.
  9. Wayne67vert
    Wayne67vert
    Jay, It appears to me, using the tires as a reference, the axle may not be centered. If it is centered on the frame the driver side is further towards the left. If you can reference the yellow boxes the same in both photos it will give another point to check from. Or the angle of the photos aren't the same.
    Jay Altemus likes this.
  10. Jay Altemus
    Jay Altemus
    Wayne, It just occurred to me why the tire on the p***enger side sticks out more than it does on the driver side. That’s because I still have a 2” wheel spacer on the p***enger side. The axle is very close to being perfectly centered, but it looks off-center because of the wheel spacer on the p***enger side.
  11. Six Ball
    Six Ball
    from Nevada
  12. AAAAAHHHHHH....
  13. Jay Altemus
    Jay Altemus
    So I still think the DS rear quarter needs to be pulled out a bit more. The DS tire is tucked in more than the PS (PS has a wheel spacer) which gives the illusion that they are almost the same. It’s easier to see in person.
    TFoch, Six Ball and 31chevymike like this.
  14. tb33anda3rd
    tb33anda3rd
    use a comp*** and a large piece of cardboard to make a templet of both sides and compare the two. use the one that looks correct as a guide to straighten the other side.
    I think I would also make two new identical wheel wells. each one made from two pieces, an upright piece and the piece that creates the arch over the wheel. this way it would provide the shape to make the sides identical.
    TFoch and Jay Altemus like this.
  15. Jay Altemus
    Jay Altemus
    Wheel well repair + started welding the mini-tub.
    IMG_0357.jpeg IMG_0356.jpeg IMG_0365.jpeg IMG_0366.jpeg IMG_0363.jpeg IMG_0371.jpeg IMG_0379.jpeg IMG_0381.jpeg IMG_0383.jpeg IMG_0390.jpeg IMG_0391.jpeg IMG_0392.jpeg
  16. Your determination and welding skills are inspiring Jay! Keep up the great work sir!
    TFoch, Six Ball and Jay Altemus like this.
  17. Jay Altemus
    Jay Altemus
    That’s because you haven’t seen it in person. Haha!
    Six Ball likes this.
  18. Joking aside, early Chevy owners have it MUCH tougher to restore our hot rods than most other makes and models. With that said, Chevy models are popping up more and more as we speak! I just sold my bottom rumble seat spring to a new owner of the same model as mine, right here in Lake Havasu City! He purchased his '31 Chevrolet for only $1,500 as a complete original car, stored on a farm INDOORS for over 65 years in Wisconsin! I haven't seen his car in person, but soon enough, looking at one photo and the car seems to be in as close to mint condition as it can get! Even the wood is in awesome shape! His plans are to build an early 60's hot rod, leaving the top unchopped, a '65 Corvette 327 mill that he's had for over 25 years, whitewalls, etc. Lynn was really impressed with my coupe, and wowed at the sight of my hemi, reminding him with his '40 Ford coupe that he had with a '92 hemi...
  19. snoop74
    snoop74
    Jay are those the Wheels you plan on running? Or at least the size ?
    31chevymike and Jay Altemus like this.
  20. Jay Altemus
    Jay Altemus
    These wheels are 15” x 7” wide with 4.25” backspacing.
    I want to go with at least an 8” wide wheel x 15” and go with 4” of backspacing (might go black instead of red). I think I can squeeze that under the fender but I’m gonna wait and finish both mini-tubs first and do some measuring. No wheel spacers will be used EVER.
    TFoch likes this.
  21. brokedownbiker
    brokedownbiker
    Love that wheel!!! I've been looking for one for years. Thanks for sharing!
    31chevymike, Jay Altemus and snoop74 like this.
  22. Jay Altemus
    Jay Altemus
    Very little got done to the 34 this week.
    However . . . .
    My son told me he was ready to take possession of his 1968 C10 which has been at my shop for 4 years. Now I have more room and don’t need to sell my 1965 C10 short bed stepside. Hooray!
    Today I pulled off the DS tire and I mocked up the inside piece of the mini-tub. It lines up great which is a real relief.
    Here’s a short video. LINK
    More needs to be done before I weld it up. I held the fibergl*** fender in place and there is plenty of room for a wider wheel/tire combo.
    So far, so good.
    TFoch, snoop74, Six Ball and 3 others like this.
  23. Jay Altemus
    Jay Altemus
    P***enger side mini-tub is underway. The 2WD S10 rear really does a nice job at tucking the wheels in close so I can use a wide tire and still fit a fender if I want.
    IMG_0494.jpeg IMG_0498.jpeg IMG_0501.jpeg IMG_0506.jpeg IMG_0507.jpeg IMG_0508.jpeg IMG_0514.jpeg
    TFoch, 31chevymike, Six Ball and 2 others like this.
  24. FRANKTHECRANK
    FRANKTHECRANK
    from EAST COAST
    So, did you convince him it was a 34 and not a 36 that he owned and you now own? Also, that was a nice 1970 Camaro. My first car was a 1973 Camaro.
  25. Jay Altemus
    Jay Altemus
    I explained the car was a 1934 and not a 1936 and he told me he just forgot what the correct year was. There is no doubt it’s the same car. I was standing in front of his garage, right where this picture was taken. I had this picture on my phone for a year and a half prior to meeting him.
  26. Jay Altemus
    Jay Altemus
    I’ve completed the mini-tub. I’m happy with the results but my wheel well repair patches ain’t pretty. I’ll likely redo some areas but it will wait until I’m in the mood. Best of all is that I can use the 54.25” S10 rear axle and wide tires and still use fenders if I choose to.
    Today I worked on getting the PS door aligned. This has been a daunting task. So far, so good. The front gap is good but the door belt line doesn’t line up well enough to satisfy me. I think I can correct the alignment by moving the top door hinge out board 1/8”.
    IMG_0566.jpeg IMG_0559.jpeg IMG_0622.jpeg IMG_0643.jpeg IMG_0644.jpeg IMG_0645.jpeg IMG_0141_Original.jpeg
  27. Six Ball
    Six Ball
    from Nevada
    Looks good !
  28. Jay Altemus
    Jay Altemus
    Really great day in the shop yesterday. The p***enger door lines up great and the struggle to get it right was minimal. VIDEO LINK.
    TFoch, tb33anda3rd, Six Ball and 2 others like this.
  29. The old girl is looking better and better after each task that you have completed Jay! Nice work!
  30. snoop74
    snoop74
    good job jay she's coming together well
