Technical Who makes these?
Discussion in 'The Hokey Ass Message Board' started by Snicklefritz65, Jul 23, 2025.
  1. Snicklefritz65
    Snicklefritz65
    from Mass.
    I'm on the lookout for a set of leaf spring pivots (I think P & J calls them t-bolts) that will accept a 2" spring. Every one I find is for 1 3/4" spring. A more capable guy with more tools on hand could whip these up but that guy ain't me at the moment.
    I checked P & J, Posies, Speedway, and a couple others including a general internet search. No dice... if anyone can point me in the right direction I'd appreciate it. Also, if this is the wrong place to post I can fix that. swtbolt 1.jpg swtbolt 2.jpg
  2. alchemy
    alchemy
    The lower one looks cast. A huge no-no. Definitely need to be forged or very well fabricated from steel pieces.
    deathrowdave likes this.
  3. Paladin1962
    Paladin1962
    Oddly enough, they look very similar to Morris Minor trunnion pivot brackets.....
  4. woodiewagon46
    woodiewagon46
    from New York
    I would doubt that the lower fitting is cast, it's probably a forging.
    Fordors and warhorseracing like this.
  5. TCTND
    TCTND
    A heavy 1/8" thick washer on each end would let it accept a 2" shackle.
  6. Yep, pretty wide parting line for a casting.
  7. dwollam
    dwollam
    The second one looks like Speedway. Bought some there a few years ago.
    Dave
  8. 2OLD2FAST
    2OLD2FAST
    from illinois
    Speedway advertised those as "investment cast" stainless steel . The upper iteration is very simple to make . You could grind an 1/8" off the spring eyes without problems .
  9. Clydesdale
    Clydesdale
    I think I'd sooner go thick washer/fabricated spacer than removing material from anything.
    Snicklefritz65, 5window and Just Gary like this.
  10. mgtstumpy
    mgtstumpy
    I fabricated similar with thick wall tubing with HT cap screws welded to tubing. A small jig ensured both were identical
    2OLD2FAST likes this.
  11. Snicklefritz65
    Snicklefritz65
    from Mass.
    that thought occurred to me but i think i dismissed it as not being ideal for some reason. it may come to it though.
  12. Snicklefritz65
    Snicklefritz65
    from Mass.
    i appreciate the comments, all. i'd still like to come up with a pivot in the size i need but the washer idea may be the way to go. still, if anyone has a lead, or other thoughts about it, please share.
    Doublepumper likes this.
  13. Doublepumper
    Doublepumper
    from OR-WA, USA
    Some factory stuff used spacers. I'd do the spacer thing just to be able to use readily available parts.
    Snicklefritz65 and seb fontana like this.
