Technical Quarter panel repair
Discussion in 'The Hokey Ass Message Board' started by johnfin, Jul 24, 2025.
  1. johnfin
    johnfin
    from Florida
    I have seen guys tack weld the replacement panel in with a mig then grind it down. Wouldnt there be a open seam doing it that way?
  2. Wanderlust
    Wanderlust
    Lots of little tacks with good penetration and very careful grinding of only the proud part leaves plenty of metal
    Algoma56 likes this.
  3. johnfin
    johnfin
    from Florida
    isnt there a seam between the tacks
  4. 19Fordy
    19Fordy
    No, not if you slightly overlap each tack so that they fuse together.
    warhorseracing and gimpyshotrods like this.
  5. Bandit Billy
    Bandit Billy
    This is how I do all my body panel replacements since I do not own a TIG. This is a gas tank filler hole on my 41 PU, I needed to make the hole smaller to fit a flip top bung that I also welded in. Lots of tacks, moving around to spread the heat out (I don't make two tacks next to each other until you can touch them without gloves.
    Repeat the tack and grind process until they are all filled in.
    Grind and metal finish. It isn't fast, in fact the slower you go the better as it reduces warping form the heat.
  6. SPEC
    SPEC
    Excellent Job!!
  7. Paladin1962
    Paladin1962
    If you check out YouTube look for videos from Fitzee's Fabrication; he can show you the quickest way to pick up the method of doing this.
    rusty valley likes this.
  8. This is how I did the quarter panel section on my 53 before I bought my new tig. Leave a gap the thickness of the metal and tack it in. Weld between the tacks a little at time. My 53 8.JPG
  9. johnfin
    johnfin
    from Florida
    Whats a good small thin cutoff wheel for body panel/ floor pan replacement?
  10. Bcap55
    Bcap55
    from PA, USA
  11. RodStRace
    RodStRace
