Hot Rods The car I've been waiting for
Discussion in 'The Hokey Ass Message Board' started by wheeldog57, May 8, 2024.
  1. Robdski
    Robdski
    The clear, detailed photos are excellent.
    Thank you for continuing to share your progress.
  2. wheeldog57
    wheeldog57
    Got some new hardware that needed some 'tuning'
    Hinges back on with no washers ( before it was loaded to make up for B pillar being bent) all 3 Hinges at B pillar had nuts welded in and the upper the holes didn't line up. I hogged out the hinge and beveled the now oval hole, mint. 20250706_105039.jpg 20250706_105108.jpg
  3. wheeldog57
    wheeldog57
    Closed the door and I still have a big gap.
    Cut off wheel to the lower pillar braces and a ratchet strap got me back in shape.
    Now waiting for the MIG wire delivery so I can get back together 20250706_122954.jpg 20250706_122757.jpg 20250706_122804.jpg 20250706_131127.jpg 20250706_131112.jpg
  4. wheeldog57
    wheeldog57
    Got the delivery and welded the pillar brace. Released the ratchet strap and the door opening opened up again! Ratchet strap ratchet tight again and temp brace from A pillar to B pillar. Move onto gas tank 20250706_145322.jpg 20250706_145743.jpg 20250706_185201.jpg 20250706_185221.jpg
    Red squirrel is homeless now. Not calling myself a welder until I can seal this tank. It has about a dozen leaks in it
  5. wheeldog57
    wheeldog57
    Went over a fellow Snapper's place, he's got torches. We heated up and bent the 3 hinges back to straight. Installed the door and don't you know it closed the gap quite a bit! 20250708_172512.jpg 20250708_172523.jpg 20250708_172529.jpg
    Man, I am pumped about this!!
  6. wheeldog57
    wheeldog57
    After studying the driver's door for the last couple of weeks I just can't stop looking at the cowl patch, it's crooked! The eye doesn't lie. I cut it off, cleaned up the adjoining areas very carefully and then tacked it back on. Now I will be able to sleep tonight 20250708_172843.jpg 20250708_175743.jpg
  7. NoSurf
    NoSurf
    Go man go
    porkshop likes this.
  8. ididntdoit1960
    ididntdoit1960
    from Western MA
    You're a better man than I - for me it would have been " close enough for who it's for"
  9. wheeldog57
    wheeldog57
    I locked in the cowl patch, stitch welded the rocker below the door, then mocked up my future panels. 20250709_200524.jpg
  10. Robdski
    Robdski
    Looking good!
  11. adam401
    adam401
    Ron the coupe is looking awesome!!
    porkshop and wheeldog57 like this.
  12. wheeldog57
    wheeldog57
    Been holding off on the door tops for lack of confidence. Today I just went for it and I'm happy with the results 20250711_120627.jpg 20250711_120635.jpg 20250711_151358.jpg
  13. Robdski
    Robdski
    You are doing a great job. The door alignment is perfect.
    I’m watching and learning from your progress. I’ll be going through the same process, at some point.
    Thanks for sharing the photos.
  14. wheeldog57
    wheeldog57
    Sheet metal fitting and measuring and fitting and re-fitting and shrinking and stretching and cutting and fitting. Driver's side quarter panel was cut off pretty high behind the door. I don't have a beader die to make the reveal but I do have an old patch panel. . . . Quite happy with the results. Shrinking and stretching tools are excellent 20250714_171518.jpg 20250714_172137.jpg 20250714_173540.jpg 20250714_174218.jpg 20250714_181206.jpg 20250714_194431.jpg
    Going to slowly and carefully weld these pieces in. This is curved front to back and top to bottom
  15. wheeldog57
    wheeldog57
    20250713_162958.jpg 20250713_162947.jpg 20250714_145435.jpg 17525374695751898105900788897366.jpg I also made a patch for inside the driver's door at the lower cowl area. Many curves and steps in this, I got it close then squeezed the vice grips to suck it into place
  16. RodStRace
    RodStRace
    Keep at it! That car you have been waiting for is here and responding to your efforts.
    Robdski, porkshop and Thor1 like this.
  17. wheeldog57
    wheeldog57
    PHEW! Slow and slower. Small tack welds, pushing out from the back to keep it from sucking in. It's hard for me to go slow- I want to zip it up and be done!
    Very happy with my patience and the results of being patient. 20250715_161903.jpg 20250715_161941.jpg 20250715_162010.jpg
    catdad49, RodStRace, hfh and 12 others like this.
  18. NoSurf
    NoSurf
    Doing great!
  19. flamedabone
    flamedabone
    I am so glad that door top came with the car, that sucker fits right on there.
    -Abone.
  20. wheeldog57
    wheeldog57
    Lots of welding today, bottom of B pillar, sub rail back to axle, wheel well all welded out. Still need to grind and finish but Lots of progress today 20250717_094427.jpg 20250717_094441.jpg 20250717_124358.jpg 20250717_124415.jpg 20250717_124433.jpg 20250717_142914.jpg 20250717_152301.jpg 20250717_152316.jpg 20250717_152327.jpg
  21. wheeldog57
    wheeldog57
    I used the remnants of the quarter patch panel for the back corner of the quarter. Cut the bead in the middle, cut, fit shrink/ stretch. Cut, trim, fit, then repeat a few more times. It's not perfect but pretty damn close 20250721_170944.jpg 20250721_170934.jpg 20250721_172239.jpg 20250722_193311.jpg 20250722_193328.jpg 20250722_193343.jpg
  22. ne'erdowell
    ne'erdowell
    Wow! Seeing the steady progress you are making is impressive. Thanks for sharing.
    wheeldog57 likes this.
  23. wheeldog57
    wheeldog57
    I had to get it on the ground, step back and look at it from a distance. It's been a long time. 20250726_192158.jpg 20250726_192220.jpg 20250726_192255.jpg 20250726_192402.jpg 20250726_192439.jpg 20250726_192524.jpg 20250726_192555.jpg 20250726_195041.jpg
    Ok, I did climb in and enjoy a beer
  24. Robdski
    Robdski
    porkshop, Stogy and wheeldog57 like this.
  25. flamedabone
    flamedabone
    It passed the "does it look cool outside " test.
    -Abone.
    NoSurf, porkshop, Thor1 and 3 others like this.
  26. ne'erdowell
    ne'erdowell
    Looking great. I know it may not be HAMB friendly, but your tree is awesome :)!
    NoSurf, porkshop, Stogy and 2 others like this.
  27. patsurf
    patsurf
    surprised there isn't a chain hanging from that limb!
    Stogy and osage orange like this.
  28. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Cool. Whole deal is just plain cool. No other way to say it. Build all you can while you can.
    Jokers and Thieves
    wheeldog57, Thor1 and Stogy like this.
  29. wheeldog57
    wheeldog57
    Thank you @ne'erdowell Mass DCR labeled it a legacy tree, just shy of the state champion. 20250727_170824.jpg
    Passenger door top welded in
    catdad49, RodStRace, porkshop and 3 others like this.
  30. chevy57dude
    chevy57dude
    Looking great! It's a good feeling to see it out of the shop after hammering away so long, I'm sure.
