Catch Cans for coolant overflow - what-ya-use?
Discussion in 'The Hokey Ass Message Board' started by Gas_Tires_Oil, Jan 9, 2006.
  1. bottle of popov...gives new meaning to puke tank.
  2. dixiedog
    dixiedog
    HEY - I NEED THAT!!!
    dixiedog - I have a Dixie Beer bottle
  3. novatattoo
    novatattoo
    from Canton,OH
    I think I have one of those generic "beer" cans. Maybe even a "light beer" can also. If you want it I can check around. Send me a PM. Later,Bill
  4. Slide
    Slide
    turbine oil reservoir from the auxiliary power unit on a Boeing 737:
  5. AV8Paul
    AV8Paul
    This is what I ran at first. Then I used a Marvel Mystery oil can, but some ***hole stole it. Now I have a Sam Adams double bock bottle. Can't find a good picture.
  6. Here's Moon's little 1 quart tank which can be used as for catch tank or reservoir.
    Expensive little devils they are, but Moon Tanks have been trad for a long while so I'm not bashful about using this one.
    If you take a look in a cooking/restrurant supply store you can find stainless steel cans in different sizes that would make a very nice catch tank with nothing more than a stainless mounting plate welded on similar to the Moon tank.
    If the little catch tank bothers some as being too billety, the third pic shows a 2 1/2 gallon tank that's been in the family for over 45 years.
    As well as having been on a number of friends drag race cars running from back in the day g***ers to modern bracket racers and a couple of dragsters.
    One modern one running alcohol - the tank was too small - and the other a flathead running fuel.
    Trad or not, the little fuel tank has quite a history.
  7. Bruce Lancaster
    Bruce Lancaster
    The WWII canteens mentioned were practically standard equipment on drag cars in the 1950's--they were generally mounted upside down with a welded fitting for the hose and the original cap serving as drain. The aluminum capped one is Model 1910, I think, and the similar bakelite topped one was also issued during the war, with very similar ones being used up into early Vietnam war before being replaced by plastic. Check out a few--some have much better welding than others, and can look really good in a car with 1950's style fuel system parts.
  8. DrJ
    DrJ
    I also run a bicycle water bottle with the "******" drilled out and the hose run to the bottom of the bottle so it works as a coolant recover system with the proper radiator cap. I had the vented radiator vent sealed off and converted to a recover type neck.
    Instead of the plastic bicycle bottle mount I have it in a windshield washer bottle mount out of a '73 MGB. The MGB washer bottle was too small in volume and over flowed.
    The bottle was on a bicycle I bought for Wife but she didnt want to drink "hot water" out of the black plastic bottle so it was "free".
    (Free parts always = "Traditional" Jalopy parts, even if not traditional hotrod parts!) :rolleyes: :cool:
  9. Gas_Tires_Oil
    Gas_Tires_Oil
    Good stuff guys - keep 'em comin'!!
    Slide - Nice looking engine bay. I dig that hubcap air filter lid and your overflow! Nice work.
  10. Just Gary
    Just Gary
    I do too. The gray metal cage looks OK with the cast aluminum engine parts.
  11. Steve
    Steve
    I'm using a canteen I got from a surplus store.
  12. Count Scrapula
    Count Scrapula
    from Mid TN
    Here's one I'm gonna use on the pickup. I love the Happy Crusing script on the bottom.
  13. s.e.charles
    s.e.charles
    if it were old, you woulda needed a church key
    dana barlow, hrm2k and firstinsteele like this.
  14. vtx1800
    vtx1800
    IMG_5623.JPG I used a "fragrance" container that was gifted to me from an old Army Buddy. His wife made soap and had lots of different aluminum containers. Simple and it works.
  15. Joe Blow
    Joe Blow
    I use a 1960 GM Optikleen windshield wiper reservoir now......but not sure what I used in 2006.
    dana barlow and hrm2k like this.
  16. s.e.charles
    s.e.charles
    the space between the carburetors is making my head hurt
    dana barlow likes this.
  17. dana barlow
    dana barlow
    from Miami Fla.
    Far old tread,but as it's being added too,OK.
    The first one I used on my 28A,was a alum. US Army Canteen,but a buddy wanted it bad,an was not in love with it anyway.
    Digging around in my stuff,I found my lunch box canteen,it's stainless steel an I thought ,just the size I like. 008.JPG
    loudbang, warhorseracing and Joe Blow like this.
  18. TA DAD
    TA DAD
    from NC
    Some PVC pipe and I installed a pet**** in the bottom. No rat rod **** on this pile. IMG_0403.JPG
  19. Splitbudaba
    Splitbudaba
    PXL_20240426_183545784.jpg Had an old canteen laying around.Drilled the top for an inlet, and a tiny vent pointed down.
  20. blue 49
    blue 49
    from Iowa
    Mine is just a boring piece of aluminum conduit with ends welded on, then turned in a lathe. Inlet tube goes to the bottom for recovery. Has a pet**** on the bottom for draining. My Henry J has one also but with a raw aluminum finish.
    Gary
    Splitbudaba likes this.
