Projects Model A Roadster Headers
Discussion in 'Traditional Hot Rods' started by BobRob72!, Jul 27, 2025.
  1. BobRob72!
    BobRob72!
    I'm building a 31 Model A roadster that will have a 383 sbc stroker. I am looking for some headers that are not the usual lakester, block hugger or zoomie exhaust. I would like to find something that is unique. I would welcome any suggestions you might have. Thanks in advance.
    -Brent-, Sharpone and dana barlow like this.
  2. 26 T Ford RPU
    26 T Ford RPU
    Unique usually means make your own. JW
    D-Russ, Sharpone, Stan Back and 11 others like this.
  3. dana barlow
    dana barlow
    from Miami Fla.
    I like chrome,but the cost of doing custom headers is up there.
    One off custom type are pretty high $,an even then can be not as good as hoped for.
    Fender-well types can be cut into some far out customs styles.
    Custom canbe cool.
    The best set,over the years,I've done for my 28A Roadster,was a used set of chrome SBC header from a buddy's T- bucket that had cracked at the flange=So he got a brand new set,gave me the cracked set. Thing is,my 28A is powered by Ford Y V8. I cut the Chevy flange off,moved the center tubes a little bit ,to match Ford Y,welded Ford flange to tubes { and painted the welds header heat silver< every thing,other then the center EX = Chevy use same as Ford anyway. :D:p:cool: Bobtail 28 roadster DB's.jpg
  4. 1935ply
    1935ply
    from peyton,co
    IMG_0032.JPG IMG_0051.JPG 35-36 drive shafts. As said above make your own.
    Okie Pete, RMR&C, Sharpone and 9 others like this.
  5. Just Gary
    Just Gary
    If you want something unique, make your own.
    I mocked these up with coat hangers, then made them with a Lincoln 140 MIG welder & tubing from Summit.
    Uncle Lee, Blues4U, RMR&C and 26 others like this.
  6. Pav8427
    Pav8427
    I have a set of old school modified dirt track chrome headers.
    They run straight out from block and straight back.
    They are for spread ports, but could be adapted fairly easy.
    Check with local dirt trackers and you might find something to modify to make work.
    Will try to get a pic when I get home tonight.
  7. 19Eddy30
    19Eddy30
    from VA
    Close to 50 cid bigger , No bling
    Race Rod
    First built for & A,
    then switched to a Duce ,
    2.250 primary,
    IMG_3685.png IMG_3684.png IMG_3688.png IMG_3687.png IMG_3686.png IMG_3683.png
    vtx1800, alanp561, Deutscher and 4 others like this.
  8. Motorwrxs
    Motorwrxs
    I have seen pics of a two piece header for Sbc that Fenton made? Super cool looking headers.
    Joe Blow and Just Gary like this.
  9. Joe Blow
    Joe Blow
    They were reproduced for several years - 6 or 7 years ago.....Cl***ic Industries sold them. Used repros are scarce and originals are scarcer.
    -Brent-, RMR&C, Hotrodmyk and 12 others like this.
  10. grdra1
    grdra1
    I just finished fabricating these headers for my coupe, 383 chev, 2 inch pipes. Glen 1.jpg 2.jpg 3.jpg
    Okie Pete, Blues4U, RMR&C and 8 others like this.
  11. Pav8427
    Pav8427
  12. Just Gary
    Just Gary
    Beautiful!:cool:
    Sharpone likes this.
  13. 26 T Ford RPU
    26 T Ford RPU
    Is this another thread where a question is asked and the OP never comes back? JW
    Blues4U, Sharpone, jet996 and 2 others like this.
  14. WC145
    WC145
    from Maine
    Doug's fenderwell exit headers for a '64 Chevy II on my '30 Model A-
    Okie Pete, Blues4U, RMR&C and 3 others like this.
  15. BobRob72!
    BobRob72!
    Thanks to all for some great ideas. Looks like I will fabricate some or at least modify some existing. I appreciate everyones suggestions.
  16. X-cpe
    X-cpe
    A set of Tri-Y's.
  17. iafraser39
    iafraser39
    from Warmland
    heres mine in my R.P.U.
    its a 425 nailhead, headers are home built, and are
    GuyW, Okie Pete, RMR&C and 7 others like this.
  18. jnaki
    jnaki
    upload_2025-9-11_4-27-36.png Nice even bend/flow style with individual pipes
    Hello,
    Your request has two routes to finish. But, you failed to mention if the model a roadster has fenders or is open wheel.
    On both accounts, the exhaust routing needs to be neat and smooth, without any radical bends, just for looks or thinking it will improve horsepower with curves and a collector. The modified T roadster had the best looking shaped exhaust pipes of any open roadster. Each pipe was shaped evenly and extended past the driver’s location. Yes, they had the rumble of 8 open header pipes, but each one had a baffle to meet the CHP loud pipe law.
    At least, the parallel design running on both sides was fashioned to keep with the smooth style of the body/frame. Some roadsters have pipes that lead to the back, but are not in line with the body design and look as if it was an after thought. Besides, if it is for performance, wouldn’t individual pipes flow the easiest?
    Yes, collector tubes are popular, but the high performance motors of drag racers all have individual pipes. Ever see a top fuel dragster with collector pipes? Yes, it has/had been done on Jr. Fuelers to see if it improved performance, but all reverted back to individual pipes.
    upload_2025-9-11_4-28-58.png If the headers are for an open wheel roadster, then the smooth design still plays an important part. Parallel to the body or frame.
    An old Friday Art project or...
    outside of the frame with even shaped header pipes leading into a collector, if so desired.
    Jnaki
    Inside or outside of your Model A Roadster still calls for a smooth evenly spaced flow of exhaust pipes. Those crazy curves/short lakes pipes do nothing except to stick out and get in the way. YRMV
    Remember, the fad of collector pipes were created with the stock racers in mind. No stock bodied race cars had the room to use individual pipes for their street legal builds. The Gas Coupe Race Cars had collector pipes due to the rules restrictions. When the rules became lax, then most went to individual pipes as a header systems. Increased performance was had and so the story goes…
    GuyW, Okie Pete and Sharpone like this.
  19. -Brent-
    -Brent-
  20. BobRob72!
    BobRob72!
    Sharpone and Just Gary like this.
  21. -Brent-
    -Brent-
    Kinda true for all headers, no?
  22. lostone
    lostone
    from kansas
    Look at fenderwell exit headers ...
    Okie Pete, Sharpone and Just Gary like this.
  23. 34Phil
    34Phil
    I fabbed a header for a Pinto/Volvo with cones from Coneeng and VW stinger muffler inserts in each one and a turn out at ends.
  24. banjorear
    banjorear
    This. I had my builder make them to get around the '32 box on the '32 frame with a flathead. Used a '35/'36 driveshaft split in 1/2 and they dump right behind the door.
  25. theHIGHLANDER
    theHIGHLANDER
    Well since this woke up I'd like to suggest cleaned up rams horns. Ceramic maybe, but what a rodder would do back in the day because headers were sometimes out the que$tion. Want more power? That means Vette rams which aren't a cheap date but still kool. No manifolds at all? Tri-Ys always look kool, and will rock your midrange world (where these cars live most of their lives anyways).
    Just Gary likes this.
  26. Tim
    Tim
    from KCMO
    Not a Chevy or a model A but they are close enough for inspiration and are probably my favorite set of headers I’ve seen someone build in the last ten years IMG_2371.jpeg IMG_2370.jpeg ***us built these in 17 I believe .
  27. Blues4U
    Blues4U
    from So Cal
    Sanderson makes these "Jayster" headers for several engines, including SBC:
    Okie Pete and Just Gary like this.
