Technical Sbc factory aluminum intake ID help
Discussion in 'The Hokey Ass Message Board' started by Moriarity, Jul 27, 2025.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
    Ok guys any ideas on this? There is a 1/8 npt vacuum port on each pair of runners IMG_4969.jpeg IMG_4970.jpeg IMG_4971.jpeg IMG_4972.jpeg IMG_4973.jpeg IMG_4974.jpeg
    Deuces and Sharpone like this.
  2. Rumors are those are military.
    Maybe someone here knows why all the extra holes are there
  3. squirrel
    the scant internet consensus is "marine". But military pops up also.
    No idea on the extra vacuum holes.
    mad mikey, Deuces, hrm2k and 2 others like this.
  4. Hubnut
    Hubnut
    Hey Mark, there was an old thread on these several years back where the unofficial decision was that they were military or possibly marine. Apparently the M114 was 283 powered and utilized some aluminum components according to someone on the tri-five Chevy forum who posted a picture of one of their engines.
  5. Here’s a military gm v8
    The extra holes by the thermostat housing are for picking it up
    There’s a vacuum line coming from the intake runner. Or looks like it under the other lines. IMG_7554.jpeg
  6. squirrel
  7. Internet rumors are a date code located under the heat shield.
    Rumors
    mad mikey, deathrowdave and Sharpone like this.
  8. M114 info.
    Engine diagram shows the ports in the intake
    not very good engine pic
    But the 2 holes next to the water neck and extra bosses behind the carb can be seen with stuff bolted to it
  9. JD Miller
    JD Miller
  10. DDDenny
    Not a rumor!
  11. Fordors
    Fordors
    I bought two of these pumps years ago, they were also described as being from a military application. No snowflake so they weren’t cast by Winters, but can anyone shed any light on the origin? I’ve done some prep work for polishing, it showed having been sand cast.
    Two things in particular are different, the byp*** hole on top is only 3/8-NPT and there are two 1/2-NPT (heater?) ports also.
    Bill Jenkins said it was military in one of his books.
    I just noticed another detail, the byp*** hole to the No. 2 cylinder was blocked.
  12. Sharpone
    Sharpone
    I’m looking at the carburetor bolt pattern, What carb was used? Just curious.
    Dan
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    Wcfb
  14. Sharpone
    Sharpone
    Thanks
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
  16. brigrat
    brigrat
    from Wa.St.
    Rumors are Steve Mc Queen was in the Marine Core, ***igned to a tank, tried to hot rod the motor and it blew up, lost a stripe over the deal Did you find that tank and are adding to your collection?
  17. rusty valley
    rusty valley
    Same engine in the M116 husky, aluminum hull amphibious troop carrier. I had one back in the 80's missing lots of parts so I moved it on.
  18. Fordors
    Fordors
    mad mikey, Joe Blow, Deuces and 3 others like this.
  19. Beanscoot
    Beanscoot
    Too bad Gimpy no longer has access to the GM inside info.
    mad mikey, Deuces and Sharpone like this.
  20. redo32
    redo32
    When I was a wee little lad in High School (cl*** of '67) working at the Richfield station in town, there was a guy with a yellow chopped '32 5w with what was claimed to be an original '57 Vette 270HP motor. My Corvette buddy pointed out the twin towers on his heads and commented on how rare they were. I have seen little info on the internet to corroborate.
  21. Paul
    Paul
    Editor
    interesting
    and not all runners have them,
    only every other in firing order.
    must be to run multiple bells and whistles
    mad mikey, Moriarity and Sharpone like this.
  22. Joe Blow
    Joe Blow
    mad mikey, Deuces, deuceman32 and 6 others like this.
  23. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I've had more than one swap meet seller insist that because this intake is aluminum, it just HAS to be from an early Corvette.
  24. carbking
    carbking
    I would be interested in exactly which carburetor was used for my records.
    According to the Carter master carburetor index, no WCFB was ever sold to Chevrolet specifically for a 283 military engine.
    The contract for the M114 was signed in 1961.
    Carter had a couple of WCFB's around that time with 283 applications: 2818s (S/T) and 3059s (A/T).
    The index also listed number 3058s which was ***igned Chevrolet part number 3796894. There is no record in the Carter index this carb was produced, nor is there an application suggested. There are no catalog pages, and if a TFN exists, I don't have it.
    Of course, there were also the dual quad WCFB's but I didn't list them.
    Anyone have a copy of the military TM for the M114? Reprints are available on ebay, but I really don't need another book just to get a single part number.
    Jon
    mad mikey, Sharpone and Deuces like this.
  25. This came up in a military site for a part number
    Guy was asking what carb for a 1965 m114
    One place list a teapot carb. I think that PN comes up one of those
    kinda looks like one in the previous pics posted
    mad mikey and Sharpone like this.
  26. carbking
    carbking
    Thank you Anthony.
    That makes a lot of sense. While the haystack Holley seems to be almost universally despised on this forum; the military used quite a few of them due to their reliability.
    Unfortunately, Holley does not list most of their military carbs in their master index; and the last military Holley TM to my knowledge was printed in 1953 ?
    Just thinking out loud, I don't remember a haystack Holley with the rectangular bolt pattern; they were the early 3 3/4 x 3 7/8 (almost square).
    Jon
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    bolt pattern on the manifold is 4 1/4” wide by 5 5/8 center to center
  28. carbking
    carbking
    Thank you Mark.
    After further review, to quote a sports cliche, I have a listing in my database for a haystack Holley type 2140-SG, list number R-1960-1. superseded by R-1960-2A for the Chevrolet military 283. The Chevrolet number is 3823489, which agrees with the post by Anthony.
    For those not familiar with the "SG" suffix, it meant "with governer".
    EDIT: and after even more review (my records show I fabricated several kits for these about 25 years ago), the R-1960 (both the 1A, and the 2A) use flange mounting gasket 8R-634 with is the thicker version of the 3 3/4 by 3 7/8 bolt pattern.
    I wonder if an adapter plate was bolted to the intake ???
    Jon
    pprather, mad mikey and Sharpone like this.
