Projects Pontiac torpedo
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Jul 27, 2025.
  1. Just Gary
    Just Gary
    Inline six and three-on-the-tree.:cool:
    I'd drive it.:D
  2. A few years ago, this same guy dropped off a Mustang.
    The mechanics cl*** overhauled a 302 for it and sourced an AOD.
    My guys started stripping the car. It needed the firewall, upper cowl, A posts, roof, both Qtrs and a complete floor. So that car got pushed outside.
    Then he bought the Pontiac.
    I guess we could use the SBF :)
  3. Sharpone
    Sharpone
    Small block Ford PERFECT!!!!!
    Dan
  4. Wow! That Poncho looks like my family's first car, a '41 Torpedo (my avatar photo). I can almost smell the musty mohair from here. I can't wait to see what you do with it. Here's another photo: Sugar, our shepherd; sister Pamie; Handsome Harry (dad) and me in my Eton suit, getting ready to go to church.
    alanp561, Stogy, williebill and 7 others like this.
  5. RodStRace
    RodStRace
    I dug a bit in the olds rear pumpkins.
    Mid 3 series for them, the bigger engines/higher trims had taller gears.
    Went from a 50 3.64 to a 52 3.42.
    https://www.jalopyjournal.com/forum/threads/1949-1952-oldsmobile-pontiac-rear-end.1088908/
    https://www.jalopyjournal.com/forum/threads/pontiac-olds-rearend-tech-post-it-here.129676/
    IIRC, 55-up was different.
    If you have a hollander, it might help pick what you want, especially if you are going with shorter rear tires. While a 3 speed is era correct, I'd look at either a th350 or a 5 speed manual. A few more bucks, but much better drive experience.
    Tow Truck Tom, porkshop and Sharpone like this.
  6. dogwalkin
    dogwalkin
    from tn
    you can use a center section out of a rear end up to 56. 55 and 56 had 3.08 in the automatic cars.
    Auto city cl***ic in Minnesota probably has the disc brake parts you need.
    Stogy, Tow Truck Tom, skooch and 3 others like this.
  7. DDDenny
    1. Request a blank check.
    2. Keep it all Pontiac.
    3. Source a 421 Super Duty and a four speed.
    4. Install #3.
    What's so hard about that!
    alanp561, Stogy, 427 sleeper and 4 others like this.
  8. That sounds like a hot rod
    This one needs to be low and slow
    and cast iron is cast iron
  9. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    300 Ford
    ...with a Pontiac script on the valve cover.
  10. downlojoe33
    downlojoe33
    My vote goes to the Pontiac OHC 6……if you can find one.
  11. 57JoeFoMoPar
    57JoeFoMoPar
    If you have that SBF/AOD, that would be awesome.
    Would be a good running and performing package. Your students would get the benefit of not only working on the car, but also the opportunity to think like car builders. Encounter problems in the reengineering of the car with a powertrain that wasn't its native habitat and work through them to find cost effective solutions.
  12. Jack E/NJ
    Jack E/NJ
    from NJ
    AM >>I guess we could use the SBF>>This one needs to be low and slow>>
    Yes. It would meet your 'slow' criteria.
    Stogy, dogwalkin, SS327 and 6 others like this.
  13. MCjim
    MCjim
    from soCal
    What it really needs:
  14. atch
    atch
    Anthony,
    You said originally that you have a 250. HOWEVER, should you decide to look for something else I wholeheartedly agree with some other folks on here that a Pontiac overhead cam six should be the only engine choice. That's ***uming of course that you can actually find one.
  15. Paladin1962
    Paladin1962
    My Aunt Beth had a '41 Pontiac with a straight six and manual trans... drove it through her high school years (late '60's) and I almost had my folks convinced to let me take it (she said I could have it since she drove a Rambler then)
  16. ClayMart
    ClayMart
    Does this Pontiac still have the original flathead 6 or 8 engine? Will it turn over or is it seized? Or does it just cost stupid money to refurbish these engines?
  17. HOTRODPRIMER
    HOTRODPRIMER
    Bet I know someone that would drive it and probably will before the owner gets it back! :D HRP
    ffr1222k, Stogy, 427 sleeper and 4 others like this.
  18. Engine and trans is gone
    the 250 or any other straight 6 would fit the easiest
  19. rusty valley
    rusty valley
    I'd do the 250 and auto. Like you said, make it go and stop. very cool car
  20. Paladin1962
    Paladin1962
    Keep it GM and roll with the 250..... it's not like it's going to be hitting the dragstrip
    Stogy and Tow Truck Tom like this.
  21. Hotwyr
    Hotwyr
    I belive Canadian Pontiacs used the Chev 6, so you'd be keeping it all Pontiac. I used to service one of those when I worked at the gas station. Elderly lady hardly drove it.
  22. Bandit Billy
    Bandit Billy
    I thought he would want to make a G***er out of it.
  23. If the guy drops this of for you to do, I bet he is looking for cheap and reliable over cool factor. The cheapest, best simple GM engine you come up with will meet the end goal. And then you can drive it. Here’s hoping your shop gets incorporated into the new school, without to much erosion.
  24. Wouldn’t even let the car in the shop if that was the plan
    Stogy, porkshop, J. A. Miller and 6 others like this.
  25. Dave G in Gansevoort
    from Upstate NY
    With that big a boat, maybe you should look for a 292. Might need the torque…
    Stogy, porkshop, 427 sleeper and 4 others like this.
  26. I’ve got one on my engine stand now.
    But that one’s mine:)
    We did a reseal on one last school year.
    Pulled from a s**** yard beater. Mechanic students ran it in their run stand. Had great compression amd oil pressure. My guys cleaned it up, replaced a bad dampener and timing cover and built the PS and alt brackets.
    Pic during the bracket mock up stage. It all worked out great and currently being used in a 61 Chevy truck
    alanp561, ffr1222k, Stogy and 5 others like this.
  27. Sharpone
    Sharpone
    You can drive a g***er slow, not so much low tho
    Dan
    Tow Truck Tom likes this.
  28. Id don’t hate em
    I recognize their place in auto history.
    But they look so goofy. Not one of man’s brightest moments.
  29. Sharpone
    Sharpone
    I was just jacking with ya, you would drive one right? He he ha ha
    Dan
    Tow Truck Tom and anthony myrick like this.
  30. Sure would. With a big ole cheesy grin.
    If I kept it I’d correct the goofy by dropping it :)
    Stogy, Tow Truck Tom and Sharpone like this.
