Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. Fortunateson
    Fortunateson
    I do the same thing for the same reason...
    osage orange and Six Ball like this.
  2. Six Ball
    Six Ball
    from Nevada
    But if you can store the wooden clothes-pins on the fuel line to prevent vapor lock. :)
    jet996, LAROKE, 2devilles and 2 others like this.
  3. jnaki
    jnaki
    Hello,
    That is a great idea that has been around for a while. The clips we see most are in two sizes. They are on some of the brand name loaves of whole wheat bread.
    upload_2025-7-25_4-27-58.png about the actual size
    We used to use the smaller opening holes as they were the ones on the bread we used to buy. But, we changed the types of bread we buy and now, the clips are a little larger in openings. The clips still open and close to keep things organized.
    The 4tb external hard drive is handy as it can be placed in a jacket pocket easily and the dangling wire is safely curled. The larger hole bread clip is clipped onto the curled cord and now, it keeps the small (smaller/thinner than a cigarette pack) hard drive in the pocket or purse.
    Jnaki
    We have several 4 tb versions with the latest stuff we have saved. They are handy and are a part of our “emergency grab bag” for such things that happen or are about to happen. The clips keep the wires all neat and tidy. There are two small hard drives with the same stuff copied on to them. (back up to a back up.)
    When our granddaughter was a teen, she was staying with us and happened to hear some noise outside of our house. So, we investigated and the street was busy with police cars, red fire captain’s cars and a small fire truck. Up the street toward the taller mountain, we could see the taller hook and ladder truck spraying water down the other side of the hill. Then slightly down the trail from the watering truck, flames were shooting up higher than the top of the hill.
    So, we got our grab bag and told our selves what to do if we had to leave fast. We watched for a little while and went back inside. 30 minutes later, the commotion died down and now the flames were not shooting high and it seemed to be under control. There were more fire trucks spraying water from all directions. Soon, the fire was out. And we put our “go bag” back in its closet space. With the portable external hard drives all located inside. All important papers are copied onto the hard drives. Grab and go...
    Note:
    If the house burns, we will be sad, but then we will start rebuilding a new house… our current small house is 40 years old, but nice.
    There are varying colors as manufacturers have their own choices and products. It is not the color, but the opening “mouse ears” inside as to giving you more room... YRMV
    Sharpone, Six Ball and osage orange like this.
  4. Wobbly
    Wobbly
    from UK
    While recently being treated in the back of an emergency ambulance and struggling to keep good oxygen levels I was given 3 oxygen bottle nebulisers. During the course of this I came up another use for the air/nebuliser hose that fits from the oxygen bottle that I was using . I asked if I could keep the hose as the paramedics were only going to bin it as bio waste.
    Chopped it to a shorter length and it makes a great brake bleeding pipe. It can even be joined up when not in use.
    jet996, 61Cruiser, Robdski and 7 others like this.
  5. Six Ball
    Six Ball
    from Nevada
    So they are trying to keep you alive and you are thinking of how to better use their equipment?
    Friggin' hot rodders.
    rpm56, jet996, X-cpe and 13 others like this.
  6. Sharpone
    Sharpone
    @Wobbly has his priorities straight!
    Dan
    Hudson31, Butler 32, fauj and 8 others like this.
  7. Fabber McGee
    Fabber McGee
    I brought home a couple of those hoses many years ago when my dad was in the hospital. The ones I got had a little rib on the inside that kept them from sealing on a standard fitting. About all they were good for was siphoning small amounts of liquid. Like getting the antifreeze out from under a layer of oil in a bucket.
  8. patsurf
    patsurf
    shows how valuable antifreeze is up there!!-wow...
    Wobbly and Sharpone like this.
  9. Fabber McGee
    Fabber McGee
    At 20 bucks a gallon, I'd say it's pretty valuable everywhere. If you buy 50/50 mix at 17 bucks and consider that half the volume is water which most folks get for free, then your ethylene glycol cost you 34 bucks a gallon.
  10. Fabber McGee
    Fabber McGee
    Another way to get a little oil off the top of a pan of antifreeze is to lay an oil absorbent pad on top. They soak up the oil, but won't accept any antifreeze.
  11. X-cpe
    X-cpe
    Newsprint will work the same.
  12. Fabber McGee
    Fabber McGee
    That's cool. I wonder what the science is behind that.
    Sharpone likes this.
  13. Bandit Billy
    Bandit Billy
    Saw this home-built buffer on-line. Has potential.
    fauj, Cooon, ModelAMitch and 9 others like this.
  14. studebakerjoe
    studebakerjoe
    I seem to recall a similar one in an old Popular Mechanics or Science.
    Tow Truck Tom, Sharpone and Six Ball like this.
  15. Onemansjunk
    Onemansjunk
    from Modesto,CA
    602FAA63-1197-422F-B31E-6C01B324FA0D.jpeg 41734251-61BD-4773-AF88-7C3C0064C60B.jpeg 32083860-CA50-45EB-8EF8-8C5CBF1E2490.jpeg 4392A860-4872-4EFB-8E94-F111ACA1A954.jpeg 986F2464-B2A7-467E-B217-9044DE047F38.jpeg
    I made mine from an old treadmill, little more compact.
    jet996, GuyW, 2devilles and 11 others like this.
  16. Onemansjunk
    Onemansjunk
    from Modesto,CA
    191F09D0-F77B-4353-B01C-6EACCFB4BED8.jpeg 1951BBCF-DE5F-48A2-94BF-51C0A3C0509C.jpeg 2AB00F8C-1014-4C38-897C-4FEB1A33BB15.jpeg FA3D2E95-B92E-40B7-8868-120EAC55A5FB.jpeg This little guy is a big help. Keeps my soldering iron from melting me and everything else. Made from Junk.
  17. Donut Dave
    Donut Dave
    Made one for my heat shrink gun.
  18. patsurf
    patsurf
    rpm56, Onemansjunk, Sharpone and 2 others like this.
  19. Fabber McGee
    Fabber McGee
    Treadmill motors are perfect for a drill press too.
    jet996, tguptill, Sharpone and 3 others like this.
  20. Six Ball
    Six Ball
    from Nevada
    And for a lot of old machine tools for those of us who don't have 220. Finding the right ones can be confusing.
    Tow Truck Tom and Sharpone like this.
  21. leon bee
    leon bee
    I had a little hand tool save my *** yesterday. I may have first heard of it here on the HAMB, a Vessel Impacta screwdriver. Only needed it a few times, but really needed it. A light duty impact screwdriver, for small stuff, JIS tip, like Phillips, but fits Japanese style screw heads better......works fine on ragged old small Phillips. Good for brand new screws, too, saves marking them up. No picture, Google find it easy.
    RICH B, jet996, Tow Truck Tom and 3 others like this.
  22. blue 49
    blue 49
    from Iowa
    My old wood-cutting bandsaw re-powered by a treadmill motor. Jackshafted down to cut steel. The motor controller is from E-Bay.
    Gary
    Sharpone, jet996, ekimneirbo and 8 others like this.
  23. Onemansjunk
    Onemansjunk
    from Modesto,CA
    FD720507-AA67-45E2-81F7-40A76D945182.jpeg 947141D3-C173-47F8-B429-842BC72A2B42.jpeg 1D40FFDA-09F3-4DF2-A450-6CA9E0377AC9.jpeg Who knows what Dad was up to.
    Sharpone, loudbang, TagMan and 3 others like this.
  24. Six Ball
    Six Ball
    from Nevada
    Heating the shop or thawing the pipes? Making coffee?
  25. jnaki
    jnaki
    Hello,
    I knew there was an old photo of the variety of cords to be rolled up on our devices. The old photo was taken on a leather couch we gave to our granddaughter. It was a sectional sofa to allow her to have a nice place for her friends to sleep on late night "girl's night out" adventures. It was too low and wide for us old folks after several years.
    But, it made a nice flat platform location for the myriad of corded items in need of some order and neatness. Now, when I grab one item out of the digital file container, I only grab the corded one I need. not a bunch of loose wires.
    Jnaki
    This arrangement has p***ed My wife's seal of approval for neatness and organization. She even uses the Apple phone charger corded clips and other wires all rolled up neatly in her own drawer for Apple products. There are a few Android cords/chargers in that photo, too.
    (Plus, the ever present 4 TB external hard drive )YRMV
  26. ekimneirbo
    ekimneirbo
  27. arse_sidewards
    arse_sidewards
    from Central MA
    Fed honeypot solvent traps make great weld on breathers. 2 for $10 on Amazon and they even come with O-rings to seal the filter to the breather. The knurled grip area gives you a place to weld into without getting into the threads like a proper weld washer. This one is installed on a rear axle.
    Screenshot 2025-08-24 at 11.52.00 AM.png attachment(830).jpg attachment(829).jpg attachment(831).jpg
    LAROKE, Sharpone, LOST ANGEL and 3 others like this.
  28. Fabber McGee
    Fabber McGee
    Just looked on Amazon. They have 64 hits in various sizes. What are they originally made to do?
    Sharpone, Six Ball and Algoma56 like this.
  29. Wobbly
    Wobbly
    from UK
    A little tip when installing rear brake shoe return springs. Like most people I don't own return spring installation pliers and used to pull my hair out getting the return springs onto the anchor pin only to have them shoot off the screwdriver under full tension with the resulting shockwave making the brake ***embly fall apart. I overcome this by joining up 3 long cable ties and looping them around the cir***ference of the brake shoes to hold the complete ***embly in place. Once the cable ties are tight you can now take as many shots fitting the return springs without ***embly/re***embly of the brake components.
    Sharpone, HemiDeuce, Six Ball and 7 others like this.
