Technical Fender Welt Help Please.
Discussion in 'The Hokey Ass Message Board' started by 31 Coupe, Jul 27, 2025.
  1. 31 Coupe
    31 Coupe
    Hello all, I'm looking for your valued advice on the correct/best fender welt to use on our 1946 Ford Tudor rebuild.
    Here in Australia we also suffer from high UV levels so that may effect the choice.
    So far I have only seen these two typical versions ..... one style that is made from a grained vinyl sheet material with a 3/16" or 1/4" nylon chord sewn in between and the other is an extruded hollow 1/4" bead rubber profile, though some are advertised as a Chevy product.
    https://thirdgenauto.com/product/1930s-40s-50s-new-25-foot-roll-of-fender-welting-2/
    https://www.joesantiqueauto.com/black-fender-welting-b-16070-20
    https://cwmoss.com/products/fender-...6N7k1Bd1YZXeNO7FWaZ65hjWFPiN22vyO4p4E#details
    https://www.dennis-carpenter.com/tr...VNnEPxHlPX0EUbpv4phrxnlEDZoyPTFiBOIsCCzp7ABSV
    https://www.cl***ychevusa.com/index..._id=1820/category_id=41/mode=prod/prd1820.htm
    The other part of the question is whether the welt can/should be painted ..... or not, and if so, what prep is required.
    Thanks in advance, I'm looking forwards to your replies.
  2. alchemy
    alchemy
    Don’t paint it.
    I’d bet any welt will last a good long time. At least as long as any of the other rubber based products on the outside of your car. You could even get some custom made of upholstery vinyl to perfectly match your paint if you want.
    winduptoy and 19Eddy30 like this.
  3. tb33anda3rd
    tb33anda3rd
    I like the grained vinyl with the smaller bead. when I see the larger bead I always think someone was trying to hide a misfit panel.
    I have painted it many times, clean it well, light coat of primer and a quality paint. to paint it it can be hung or stapled, stretched between to saw horses.
    winduptoy likes this.
  4. 19Eddy30
    19Eddy30
    from VA
    Watercraft / boat Materials
    Upholstery shop.
    I recently was looking for some custom
    Wind welt to be made thinking $100 plus ,
    $40ish
  5. 1971BB427
    1971BB427
    from Oregon
    I bought some VW fender welting that's a tougher product, and also a smaller bead. It came in 25 ft rolls for about $25 and has a nice wide belt as part of it that makes it easy to work with. It takes some cuts in places where it makes tight turns to keep the flat part laying flat, but that wasn't any problem with decent scissors to make Vee cuts. Just stop 1/4" from the bead to keep the cuts hidden.
  6. 31 Coupe
    31 Coupe
    Thanks to all that's contributed.
    1971BB427 ..... Thanks for the VW heads up, that is looking like my preferred option at the moment and I've requested info from a few different suppliers.
    I also found your earlier HAMB contributions to this subject after searching VW welting.
    https://www.jalopyjournal.com/forum/threads/fender-welt-welting.1239757/
    Thanks again everyone.
    winduptoy and gimpyshotrods like this.
  7. Try the local rubber supplies (U.E.S.), they have branches in most states. They have the black PVC? type, it hangs in there well.
  8. mohr hp
    mohr hp
    from Georgia
    Juliano's/Yogi's has good stuff in several colors.
    tb33anda3rd likes this.
  9. 31 Coupe likes this.
  10. krgdowdall
    krgdowdall
    from Alberta
    I used the Empi #B6-0170-0. Its a smooth rubber extrusion, 1/4 bead 1-1/4 flange.
    Sold for VW beetles, in 25 ft rolls. Worked well and the smooth bead does not trap dust as the textured material does. Lasted for over 20 years.
  11. 31 Coupe
    31 Coupe
    Thanks for that info ..... I've been using UES for many years and never thought of them to have it.
    Gratefully appreciated.
  12. 31 Coupe
    31 Coupe
    Thanks for that info ..... I've already requested tech info from EMPI about their #00-6730-0 and #B6-0170-0 profiles but they're really slow to reply.
    I see that SPEEDWAY have the EMPI #B6-0170-0 in 25ft lengths for $18. Glad that you liked it, it's very difficult to know what's **** and what's not these days.
    MOORE PARTS SOURCE in Cal. are EMPI distributors too and they have been extremely supportive so far.
    Thanks again, much appreciated.
  13. 36cab
    36cab
    I had the upholstery shop sew up some vinyl around a round cord. The vinyl color matched the car's color and the welting practically visually disappeared once it was installed.
