Technical Stewart Warner gauges , still quality?
Discussion in 'The Hokey Ass Message Board' started by JD Miller, Jul 30, 2025.
  1. JD Miller
    JD Miller
    Are Stewart Warner gauges still quality like they were in the old days or are they junky fakes now days ?:eek:
    I havent bought any since maybe the 1980s
  2. DDDenny
    Bought these many years ago..........hecho in Mexico, still in the box, they seem to be OK.
    Just Gary likes this.
  3. 57Fury440
    57Fury440
    I don't know about the new ones, the ones I have, I bought in the sixties.
  4. mohr hp
    mohr hp
    from Georgia
    I feel they have lost something. My Willys has a mix of new and old S-W Gauges, and the newer ones (Speedo & temp) have problems, but the 70's ones (Fuel and oil) are great. The 15 year old volt gauge is good though.
  5. Bandit Billy
    Bandit Billy
    I have a full set of SW wings in my roadster, they look great with curved glass lenses, crescent pointers, etc. They work, though not great. The odometer clicks off the tenths loud enough for the car next to me to hear, and the temp gauges...well they look good. I have a flathead, so I installed two temp gauges along with a direct fit temp gauge on the engine. At operating temp one gauge reads 195, the other reads 205, the direct fit gauge reads 180. I checked them with my IR handheld, and they are off 15-25 degrees. It still gives me a heads up if it is getting warm so I can deal, but accurate they are not.
    The tach works perfect though as does the fuel gauge and the oil pressure gauge.
    rusty valley and Just Gary like this.
  6. partsdawg
    partsdawg
    from Minnesota
    If I want known quality I buy old stuff.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    Yea , well sometimes ...
    Greenblade, leon bee and Driver50x like this.
  8. Just Gary
    Just Gary
    My HAMB and greater internet research generally showed the new "Made in Mexico" speedo/odometers and tachs are sketchy quality, but the smaller gauges are ok.
    Based on that, I bought an NOS still-in-the-box 1970's speedo from Ebay and brand new 2 1/16" gas, oil pressure, coolant temp and volt gauges and senders.
    I've driven the car for several months and so far, all are working beautifully. :)
  9. Kiwi 4d
    Kiwi 4d
    I have been through 2 new stupid Warner speedometers , the ODO kept failing at 1500 miles . It is a huge pain to get the speedo out due to have the booster inside the car right behind the speedo . So it can stay broken , the speedo still read good.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    I've been buying Stewart Warner gauges at swap meets for over 40 years. A bunch of them were bought for a buck each back in the eighties. I think the last time I counted I have something like 500 gauges here. When I need one I just grab one out of my display case. They always work....
  11. BJR
    BJR
    Which is why there are no old SW gauges to be found in the Twin Cities and surrounding area.:p
    1Shot-Scot, Squablow, RICH B and 8 others like this.
  12. patsurf
    patsurf
    :p
    Moriarity likes this.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    they were there for anyone to buy, for decades....
  14. BJR
    BJR
    Hope you realize that was an attempt at being funny.
    elgringo71, 5window and Moriarity like this.
  15. 40FORDPU
    40FORDPU
    My odometer stopped at 200 miles.
  16. nochop
    nochop
    from norcal
  17. tb33anda3rd
    tb33anda3rd
    my odometer stopped trying to turn the fourth digit [1k] they sent a new one and this one has been fine over 4k miles
  18. nochop
    nochop
    from norcal
    I had a temp sender issue and called there tech line. Tech walked me through how to identify the correct sender. Awesome tech department
    Driver50x, Just Gary and tb33anda3rd like this.
  19. Jack Rice
    Jack Rice
    I have a newer set of the "wings" gauges in my 36 pickup. They're looking and working very well.
    Tow Truck Tom and Just Gary like this.
  20. Belvedere1
    Belvedere1
    from 85050
    I recently put a mechanical oil pressure and water temp in mine and so far no issues. I prefer SW over any of the other options.
    nochop likes this.
  21. Driver50x
    Driver50x
    I bought a new Auto Meter speedometer a couple years ago. It failed completely about one month after the warranty expired, with about 7000 miles on it. It seized up, which also broke the speedo gear in my transmission.
    Tow Truck Tom and nochop like this.
  22. Wait, they make new gauges ?!?!?!?! :D
  23. CME1
    CME1
    I have a full set of SW gauges in my '40 Ford, (tack, speedometer, volt, oil pressure, water temp and gas) black background with white letters. They all work great.
    Tow Truck Tom likes this.
  24. Fordors
    Fordors
    I remember when Stewart-Warner re-introduced the Wings gauges, right away I noticed the thick, molded plastic needles instead of the crisp looking sheet metal stampings.
    No thanks.
  25. nochop
    nochop
    from norcal
    We need a fu*k that button
  26. 31 Coupe
    31 Coupe
    I bought a full set of the newer SW gauges for our '46 Tudor build a few years ago and I then read on here just afterwards about their poor quality so I then bought a set of "Old Tyme Black" AutoMeter gauges from Rockauto.
    Can't report on them as yet so who knows if they're any better.
    https://www.autometer.com/gauges/old-tyme-black.html
  27. Must have been a STRONG cable!
    Ben
    X-cpe likes this.
  28. Stewart Warner had a service bulletin on this issue, some of their gauges, like the wings, require the 280EC sender even though the gauge face is 100-240F and the sender is rated at 100-230F. The senders with the 100-240F rating make the gauge sweep too far making it read hotter than the actual coolant temp. If those are the senders you have, then yea it is gauges themselves.
    Automotive Stud and Bandit Billy like this.
  29. SPEC
    SPEC
  30. vtx1800
    vtx1800
    The SW gauges in the 38 and the Stude are all at least 50 years old and doing fine. I did have to break down and buy a new mechanical heat gauge for another car and so far it is fine. My stash of SW gauges is virtually gone:(
