Lincoln V12 engine needs a car build around it
Discussion in 'Off Topic Hot Rods & Customs' started by mk e, Jul 26, 2025.
  1. mk e
    mk e
    Thank you for the photoshop and this! And yeah, the issue is the rear wheels need to move back from the seating area which leaves a lot of bad options appearance wise. Keep the long nose or even make it longer to maintain proportions? Then wheelbase.....how long to go in the interest of looks, for performance the front wheels want to follow the rears wheels back, keep them forward and they have very little weight on them. Wheels/tires, I sketched what would be 27" OD tires thinking 20x12 rear, 20x8 front thinking that is about right width balance give the expected rear weight bias.....300hp doesn't need 12s but....looks. I hadn't really thought a ton about the wheel style.....yeah spokes are likely the "right" choice for a 30s look but my heart is saying something very much like the " spoked" audi wheels below would look good if maybe not correct.
    A buddy pointed out the rear fenders in particular are an issue....they endup above the body which is maybe an odd look and more something you see in the ratrod genre where everything is slammed. I'm pondering back tracking on the cool modern engine mods and just putting the blower on top and carbs on top of that so the rear deck needs a big hump at the least to cover it and that will get the body profile taller than the fender. and give a good way to pull air in to cool everything a bit...but then 300hp is maybe a stretch goal unless I can find E85.
    Then @Ned Ludd makes the excellent point...what the heck is it supposed to be?....I was kind of hoping I'd know it when I saw it but hope is not a plan :p I want to play a bit with pointing the project in this direction as inspiration
    https://cl***icmotorsports.com/cars...s-prototype-race-car-2011-r18-tdi-ultra-lmp1/
    My thought is that design has come nearly full circle...big wheels in the corners, fenders mostly separate from the body, teardrop shapes......I'm trying and so far failing to wrap my head around what a 30s version of this type car looks like
    porkshop and Ned Ludd like this.
  2. James D
    James D
    I rather feel like modern wheels, as per the Audi racer you show, kind of make the vintage engine slightly less relevant.
    Reminded me...yes, again... of the Audi Rosemeyer concept. The wheels on this seem like a good modern/vintage style mix, with something of the style of the Bugatti type 35 alloys.
    porkshop likes this.
  3. Ned Ludd
    Ned Ludd
    A full-on Photoshop seemed a bit excessive for an idea which is really tangential to your thinking, so a very rough pencil sketch will have to do:
    RMR&C, porkshop and James D like this.
  4. James D
    James D
    Ned Ludd likes this.
  5. Ned Ludd
    Ned Ludd
    I've seen that!
    My only beef is the location of the front axle, which offends against a principle often emphasised on the HAMB.
    And 900bhp out of a Riley "16" four, with its turbocharger blowing through a pair of SUs, would have excited me much more than that Audi — 5-cylinder noises notwithstanding.
    James D likes this.
  6. RodStRace
    RodStRace
  7. AmishMike
    AmishMike
    Construction of all these body styles is mind blowing. Think lotus 7 style, especially fenders.
  8. AmishMike
    AmishMike
    I thought engine with blower/turbo was prime piece to show, not the body
  9. mk e
    mk e
    Let me think on that......its true of course, no question there but the thinking comes in how much I want to be authentic and how much hotrdding is allowed. Like, slide f/r wings in the design if I round the ends like a wwII fighter? The wheel pods are aircraft like so maybe right? Same on the bottom....can I take some liberty so the running boards become part of a larger a ground effects package?
    I really don't know what I'm doing it seems....I know its not right yet but I'm really struggling with what exactly is wrong and how to fix it.
    Ned Ludd and porkshop like this.
  10. mk e
    mk e
    Ha! Pod fenders sitting above the body line and what sure looks like a front wing
    rod1, Ned Ludd, James D and 1 other person like this.
  11. Adriatic Machine
    Adriatic Machine
    I’m not sure if this helps or hurts but I’ve always been a fan of the 1936 Auto Union Type C. Maybe add some fenders to this design and work from there? And nothing is cooler than dual rear spoke wheels!
    Just Gary, Deutscher, rod1 and 2 others like this.
  12. mk e
    mk e
    @Adriatic Machine - it helpd define what I DON"T what to built :eek:
    That auto union car kind of set the stage for what a grand prix car is....can you imaging how fast it would have been had they not been pulling intake air for the low pressure behind the car? (I just noticed where the engine air inlet is) . I think the 6 tires also explains exactly why early mid-engine stuff was so rare....tire technology just wasn't there to deal with a fat a$$
    To me, the roundness is car makers copying airplanes and not understanding cars are not airplanes are we do not want them to fly. For sure the proportions are what you get with this layout but the era is kind of known for long hoods....hence my strugles with the project so far.
    Adriatic Machine likes this.
  13. Adriatic Machine
    Adriatic Machine
    Lol ok I’ll just keep lurking while your vision evolves.
    Are you rethinking the custom connecting rods / shortblock mods or just keeping the fuel & ignition old school?
    rod1 likes this.
  14. RodStRace
    RodStRace
  15. mk e
    mk e
    Just the fuel and blower bit.....if I want to add height a roots blower and carbs will add....12" on top vs efi and a side/low mounted setup? it will still need a solid short block and the more flow there is the less boost I need.
    I got of my last call of the day a few minutes ago and I'm trying to figure-out what to draw......there are so many ideas that have been shared and all of then, even the auto union, have elements I like/appreciate. I have at least a few months I can spend planning until the the car from hell is running again and I can actually start building this....side note way back I thought making this badge was kinda funny
    The car is a quattrovalvole, and I realized gemmelocattivo was the same number of letters so I made a badge in kind of the same size and font.....but it roughly means "evil twin" which I thought funny given the hp bump and how hard I worked to keep it all looking kind of stock......but its taken the evil bit to heart I fear and the project just refuses to die.
  16. mk e
    mk e
    How's that?
  17. RodStRace
    RodStRace
    Ned Ludd and mk e like this.
  18. mk e
    mk e
  19. RodStRace
    RodStRace
  20. mk e
    mk e
    first this thing must be enormous or that is a really well proportioned midget
    I've always like the auburn
    and this grill is also something that could work
    last the bmw 328 is basically the only car ms copilot ever "created" for me...over and over and over
  21. RodStRace
    RodStRace
  22. James D
    James D
    I pulled and stretched the Mercedes W154 around and added some just-about-1940s Halibrands. Wheelbase is probably off.
    mk e likes this.
  23. mk e
    mk e
    @James D ...thats kind of interesting. For whatever reason the fender shapes look better, to the point of "yes, I think so" sitting next to the other changes you make
    I did a little work on the tail, less pointy now and thought the exhaust exit there helps it makes sense ala F1 car since inspiration is coming from grad prix. Mostly I'm learning how to get the software to do what I want, I don't normally draw this kind of stuff. Next I was headed to the nose to do a bit of what you just did. I thnk so flatness to the top of the grill and hood though......maybe not.....but I"m trying to picture the flatter sides of most stuff and the flatness of modern prototype cars....
    James D likes this.
  24. mk e
    mk e
    That's a bit better in the body....time to get after the fenders
    Ned Ludd, Baumi, James D and 2 others like this.
  25. Baumi
    Baumi
    holy ... carb! I have nothing to contribute other than that I´m gonna sit back and watch.
    This is gonna be good!
  26. mk e
    mk e
    I'll call this rev2. I need to think a little bit now......
    Ned Ludd and James D like this.
  27. mk e
    mk e
    and rear. Sitting here with a drink poured (ok it was a straight to the rocks moment) I'm thinking the corves in front cut away the place the upper a-arm should mount....I'll need to fix that in rev3
    James D likes this.
  28. noboD
    noboD
    Does it HAVE to have a windshield? That's the only thing that looks out of place to me. Not that my opinion matters.
    mk e likes this.
  29. mk e
    mk e
    So, the first comment over on gr***roots was
    and honestly, looking at it, you're both right. I'll need to think about it.....
  30. Adriatic Machine
    Adriatic Machine
    I’ve always been fond of the boat style windshield. Two pieces of flat gl*** and three heavily raked stanchions, flanked by a pair of wind windows, one on each side. Extra points for using aircraft solid rivet type construction, there’s a lot of room for creativity.
    Yea I know I’m beating a dead horse with the aviation references.
    Just Gary, rod1 and Ned Ludd like this.
