Customs 1963 Rambler Classic 770 build
Discussion in 'The Hokey Ass Message Board' started by Bruce A Lyke, May 15, 2025.
  1. Bruce A Lyke
    Bruce A Lyke
    It may be a bit before those are on, its 18 days until Back to the 50's and I need to focus on more urgent issues with the days that will be available. The spinners will be a nice touch for sure whenever they get on:cool:
    osage orange, Sharpone, hrm2k and 3 others like this.
  2. Bruce A Lyke
    Bruce A Lyke
    Update 4
    Let's just sat the past week and a half might make for a good TV show with lots of things popping up. fortunately as of tonight, the Rambler is back on the ground and starts. found some good sources for parts that are very hard to find, they seem to be priced accordingly. The new fuel pump arrived today and after a few calls determined it is correct and the one that came with the car is an aftermarket that was not properly installed.
    The big news is the car is back on track for going to Back to the 50's in 10 days
    Need to do some local test drives and fix a few more things but they should go fairly well:rolleyes:
  3. Bruce A Lyke
    Bruce A Lyke
    With a day to spare the Rambler cl***ic 770 is ready for Back to the 50's Friday
    Still lots to do, but for now it is "Roadworthy" RC READY 1.jpg RC READY 2.jpg
  4. Beautiful car, only original once. I love chrome.
  5. Pontmerc
    Pontmerc
    from Finland
    Never would gues that 100% original rambler 4d sedan fits in hamb customs.
  6. Bruce A Lyke
    Bruce A Lyke
    It is not really that original, it was repainted at some point with the original colors and is a ten footer.
    We will see what the end of the build will be. I will try to do and modifications in a way that they can be reversed later if the next guy is so inclined.
    the dash is a good example
  7. Bruce A Lyke
    Bruce A Lyke
    Working on replacing the master cylinder. the only replacement has smaller fittings, trying to get the double flaring to cooperate:rolleyes:
    brakes went out on my way home from Back to the 50's
    fortunately, I had fixed the emergency brakes:cool:
  8. stuart in mn
    stuart in mn
    Did you simply remove the cracked dash pad? I wouldn't have expected the paint on the metal underneath it to be so nice. As long as you're not in a head on collision, it looks great. :)
  9. Greenblade
    Greenblade
    Woah! Didn't expect to see another '63 Cl***ic build here on the HAMB. Yours is in really good nick. Rare too see such nice paint and chrome.
    I got a '63 550 2 door. Not as pretty as yours but a load of fun to drive 20220904_144103.jpg 20230618_091209.jpg
  10. Bruce A Lyke
    Bruce A Lyke
    yes, i was hoping the paint would be good under the pad, since it looked like the pad was only on the 770 (maybe an option on others):cool:
  11. Bruce A Lyke
    Bruce A Lyke
    love the look of yours!
  12. In_The_Pink
    In_The_Pink
    Good to see you both driving and enjoying your Ramblers, despite a few bumps in the road, so to speak.. Maybe you can both aim for attending the 2028 Kenosha Homecoming Show. :D:cool:
  13. Jumping Jehoshaphat!!, my brother and I used to cruise around in one of those when we were in high school. Same color scheme even.
  14. Greenblade
    Greenblade
    Here is a cast 4 door I have. Same color as yours but with a black top PXL_20250729_230429452.jpg PXL_20250729_230420137.jpg PXL_20250729_230404518.jpg
  15. duecesteve
    duecesteve
    The deep steelies look cool or chrome reverse might look neat :)! Nice cruiser by the size of the exhaust pipe I'm thinking you not running a 6 cyl? @Greenblade
  16. Greenblade
    Greenblade
  17. hrm2k
    hrm2k
    Lee's Driving School in Birmingham AL had a 63 Rambler 770 but in a blue color with Air Conditioning. I took my driving test in it. The fat guy who gave me the test sure did enjoy that A/C.
    Enjoy that cl***ic
  18. Paladin1962
    Paladin1962
    I had a '65 4dr with the 238(??), had a bent valve on no.1 that I replaced, swapped in a later Duraspark ignition setup, really nice old ride. I see you're in Minnesota? Lots of salt? Be sure to check the front fender troughs OFTEN for rust. And the cowl air intake on the p***enger side; they love to rust out there.
  19. duecesteve
    duecesteve
  20. zman
    zman
    from Garner, NC
    I miss mine, funny thing is I ran into the present owner, there is chance I could get it back, though someone painted it flat black.
  21. Bruce A Lyke
    Bruce A Lyke
    The car was originally from down south, very little rust, one of the reasons i decided to buy it.
  22. duecesteve
    duecesteve
    It's only paint! We can rebuild him,better, faster!
  23. Bruce A Lyke
    Bruce A Lyke
    Progress update
    Finished the master cylinder and new brake line to the rear end, however the bleeders are broken off, should have checked:(
    New wheel cylinders ae on order:rolleyes:
  24. Very nice! My first car in high school was a '60 Rambler.6 cylinders with a push ****on automatic.And yes....fold down seats!:rolleyes:
  25. mgtstumpy
    mgtstumpy
    A friend had a similar Rambler and loved it, eventually selling it to a club member Wintersun10-4.jpg
  26. Bruce A Lyke
    Bruce A Lyke
    Picked up a couple of items i needed at French Lake Auto Parts, and the work goes on:rolleyes:
  27. Bruce A Lyke
    Bruce A Lyke
    Think I'm finally done with the brakes... unless i have my wife help do a final bleed
    Not sure the vacuum pump is 100% (if not it is likely doe to operator error):rolleyes:
  28. Bruce A Lyke
    Bruce A Lyke
    Looks like everything on the "Must List" is done and hopefully I will be driving it a bit tonight.
  29. Bruce A Lyke
    Bruce A Lyke
    Update, still have some strange intermittent sounds from either the transmission or rear end.
    Was hoping to have it looked at by a shop but didn't get it set up before having surgery to remove a cancerous kidney two weeks ago. Recovery is pretty slow but as of today I'm seeing the trend keep getting better. 4 more weeks before being able do any wrenching on the car.
    The car has ended up needing a lot more than planned, but i still like the car and will get a plan going forward before the snow flies. :cool:
  30. Looks great!!:cool:
