Projects 1929 Ford Roadster
Discussion in 'Traditional Hot Rods' started by Mikko_, May 31, 2025.
  1. Deutscher
    Deutscher
    from Germany
    I took out 2 leaves, the 9th and 8th,
    but I also installed a 32nd axle,
    which adds another 1inch.
    Greetings Harald
    Stogy, 51 mercules, winduptoy and 2 others like this.
  2. Mikko_
    Mikko_
    from Sweden
    Stogy and Outback like this.
  3. Mikko_
    Mikko_
    from Sweden
    Got the front spring greased, ***embled and painted.
    I decided to move the top 3 leaves to the bottom of the pack.
    Then I bought a reverse eye spring for the rear, just 30 min from home.
    It's 3 years old and I got it for 1/3 of the price of a new one.
    Stogy, GuyW, winduptoy and 7 others like this.
  4. Mikko_
    Mikko_
    from Sweden
    After that I kept on dis***embling the front end.
    Got the perches, wishbone and brake drums off.
    Happy to see that the brakes appear to have been recently rebuilt.
    Stogy, Acres, winduptoy and 14 others like this.
  5. Mikko_
    Mikko_
    from Sweden
    Made a mess and got the rest of the front end dis***embled.
    Time for cleaning, painting and rebuilding.
  6. Mikko_
    Mikko_
    from Sweden
    After some cleaning and painting things are finding their way back to the car.
    Still need to install some cotter pins here and there and new grease fittings for the shackles.
    Next up is painting the spindles, install new bushings and find someone with a reamer for those.
    Can't wait to see it back on the ground with the new stance.
  7. I sell these here in the HAMB in "Parts for sale", they'd look good on your Roadster.
    Stogy, Mikko_, Outback and 1 other person like this.
  8. Mikko_
    Mikko_
    from Sweden
    Yes I've seen those.
    I'm just not sure on how to solve the payment since I live in Sweden and I believe you don't do Paypal?
    Stogy likes this.
  9. Mikko_
    Mikko_
    from Sweden
    Brought the spindles to work today and spent the lunch break with sandblasting them and pressing in new bushings.
    Now I just need to find someone with the correct reamer for these.
    Stogy, winduptoy, Thor1 and 2 others like this.
  10. Jeff34
    Jeff34
    I took mine to the local machine shop to have them honed instead of using the reamer. Came out perfect!
  11. Acres
    Acres
    from Sweden
    This is coming together nice.
  12. Mikko_
    Mikko_
    from Sweden
    Stogy and Acres like this.
  13. US dollars or International Postal Money Order work. $355, Shippings included in that price.
    Stogy and Mikko_ like this.
  14. leadsled
    leadsled
    I spent 3 weeks looking high and low for the self-piloting reamer .8125". I gave up and did them on a piston pin hone. Snyders antique auto has it for around $300
    Stogy, osage orange and Mikko_ like this.
  15. Mikko_
    Mikko_
    from Sweden
    Dropped off my spindles and king pins at a well known early Ford experts shop today for reaming.
    On to something else, awhile back I mentioned that I cut 2 inches out of my windshield stanchions.
    Well, earlier this week I had a coworker who can weld aluminium put them back in one piece and then I smoothed out the welds.
    I'm very happy with the new height, would just like them leaned back a tiny bit.
    I might try and make a pie cut in them, heat them up a bit and bend them, hoping they don't crack since they are cast aluminium.
    Stogy, Outback, winduptoy and 12 others like this.
  16. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Stellar man, dig the roadster!!!!
    Stogy, winduptoy and Mikko_ like this.
  17. Mikko_
    Mikko_
    from Sweden
  18. Mikko_
    Mikko_
    from Sweden
    Got some more cutting, welding and grinding done on the windshield stanchions and now they have a little more rake to them.
    Hard to tell in the kinda close up photo but it looks much better than they did with just the chop.
    Stogy, Outback, Tim and 6 others like this.
  19. Mikko_
    Mikko_
    from Sweden
    Picked up my spindles today from reaming.
    Just need some paint now and I can get the front end back together.
    The gentleman who reamed my bushings was doing some cleaning in his parts stash when I came by and he offered me two 17" wire wheels for a vey low price so they came back home with me.
    They look worse than they are, just need to find two more and we are in business.
  20. Acres
    Acres
    from Sweden
    Those wheels are a really nice upgrade, both in looks and performance
  21. Mikko_
    Mikko_
    from Sweden
    Went on a roadtrip today to pick up a 28-29 commercial grille shell.
    I already bought a chrome/nickle one a few weeks back but I do prefer the look of a painted one.
    Stogy, 51 mercules, Outback and 2 others like this.
  22. Mikko_
    Mikko_
    from Sweden
    Touchdown.
    Garage is a mess but got my newly reamed spindles installed and just had to do a quick mock up of the brake stuff so I could check out the new ride height for motivational purposes.
    Tomorrow I will have to pull the drums off again to try and figure out why the brakes on the right side aren't working, they did before I took the front end apart and now when I pull on the brake actuator arm it is barely moving at all.
    Hard to tell from the picture in my small garage but I like the new stance of the front end.
    flat Ike, Stogy, Outback and 7 others like this.
  23. Mikko_
    Mikko_
    from Sweden
    Got the right side brakes working.
    Was an easy fix, the operating pin for the brakes wasn't correctly seated in the wedge on the bottom of the backing plate.
    So I went on and packed the wheel bearings with grease and got the drums installed.
    Also installed cotter pins where they are needed.
    Next up is to do some refurbish of the steering linkage and the front end is done for now I think.
    Stogy, Thor1, Deutscher and 1 other person like this.
  24. Outback
    Outback
    from NE Vic, Oz
    Nice work, the car is coming together nicely
  25. Mikko_
    Mikko_
    from Sweden
    Thank you.
    Step 1 is to get it nice enough to p*** ***le and safety inspection.
    Step 2 is to go back and replace some more sheet metal, like that rear floor that is kinda crusty, and I would also like to put a 32-36 front axle under it in the future.
    Stogy and Deutscher like this.
  26. Mikko_
    Mikko_
    from Sweden
    Got the tie rod and drag link hooked up and now we have steering again.
    Tomorrow I'm gonna start on the not so fun job of installing my reverse eye rear spring.
    Borrowed a spring spreader from a friend so hopefully all will go somewhat smooth.
    rwrj, Stogy, Thor1 and 3 others like this.
  27. Deutscher
    Deutscher
    from Germany
    Great work,
    I was also very respectful of the rear spring when installing it.
    Greetings Harald
  28. Mikko_
    Mikko_
    from Sweden
    @Deutscher Those rear springs are very scary, I will take it very carefully for sure.
    Stogy, osage orange and Deutscher like this.
  29. Mikko_
    Mikko_
    from Sweden
    Got the old rear spring out without any accidents.
    Luckily the center bolt was not cut so I could release some of the tension on the spring during removal.
    And of course the bushings in my new spring are too small for my shackles so I'm gonna remove the bushings from the old spring since they are in good condition and install them in the new spring.
    Perfect lunch break project during the upcoming week.
    Since I wasn't ready to call it a day just yet I decided to do something fun, so I brush painted my rear wheel wells with some satin black Rustoleum and I'm liking the result.
    The whole car will eventually get brushed with the same paint but this gave me a motivational boost for now.
    rwrj, Stogy, set me on fire and 5 others like this.
  30. Mikko_
    Mikko_
    from Sweden
    Reverse eye rear spring is in, have a few small things to finish up before I can put the wheels back on and see if it got any lower.
    It was quite the task to install, no fun at all.
    Had to install just the main leaf first to even have a chance of spreading it enough to get the shackles in.
    rwrj, Stogy, osage orange and 4 others like this.
