Hot Rods Model A spring shims
Discussion in 'The Hokey Ass Message Board' started by Bikelessbill, Aug 2, 2025.
  1. Bikelessbill
    Bikelessbill
    Does anyone make degree shims for traverse spring front suspension? Been looking but can't seem to find any. Problem is aftermarket crossmember with plenty of clearance at rear of spring but looking like it will contact crossmember at front.
  2. 1946caddy
    1946caddy
    from washington
  3. Bikelessbill
    Bikelessbill
    Already have the adjustable perches . Issue is with front side of spring rubbing inside of crossmember. Wanting to tilt spring back a little.
  4. hotrodA
    hotrodA
    As was posted above:
    You can get various degree truck shims up to 4” width, and just trim off and use the thick end. Drill a new hole for the center bolt.
    Most truck alignment shops have a 5 gal. bucket of take-offs from caster changes. Probably free for the asking.
    They are made in steel and aluminum if it matters.
    Most truck parts stores will have NIB.
    Tow Truck Tom likes this.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
  6. pprather
    pprather
    It would seem that shimming the front side of the spring will reduce caster?
  7. Bikelessbill
    Bikelessbill
    I have adjustable perches so that's not a problem.
  8. pprather
    pprather
    I think the adjustable perch will allow for different spring length variations, but I don't see how they adjust caster.
  9. Bikelessbill
    Bikelessbill
    Adjustable perches allow the axle caster to be set regardless of what angle the spring is mounted.
    GuyW likes this.
  10. I may not be reading your description correctly. It reads to me like you have Gap between the rear vertical wall of crossmember and spring and No space on the front side. That reads to me like the Aftermarket crossmember center hole isn't on center. Another issue could be the vertical walls are Not 90 degrees to the Top Plate. Maybe I need more Coffee to get my head around this. How about a photo or 2 for this Old Silverback? Under "Normal" conditions you never use wedge shims when mounting a Buggy Spring. Probably why you can't find them.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ I was thinking along similar thoughts. Something isn’t right. But I just went along with op’s request. “The customer is always right”
  12. Bikelessbill
    Bikelessbill
    Kind of hard to get good pictures ***embled but here you go. 20250803_120208.jpg 20250803_120058.jpg
  13. Happydaze
    Happydaze
    Why would you need to lay the spring back some when you have adjustable perches? I can see you might need to move the axle, probably rearward, in order to align the spring to the perches in order to avoid binding though.
    Edit. Just seen the pics. The spring needs to go back some. Will slotting the center hole in the crossmember help? You could put a piece of steel stock, 1/4 square on the front of the spring to **** it back, as a test? The hairpins or whatever might need adjusting shorter though.
    Chris
    ALLDONE likes this.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Stock wishbone, split bones, hairpins? What would happen if axel wasn’t secured to any of the above? In other words. Would the spring lay back under relaxed conditions?
    GuyW and Pist-n-Broke like this.
  15. Bikelessbill
    Bikelessbill
    Adjusting the hairpins with adjustable perches only moves axle not spring. I was thinking a small degree shims between top of spring and crossmember might work.
  16. If your spring center pin head is in the center hole of the crossmember, then I would bet that hole is off center to the front. As Johnny Gee mentioned, Disconnect the shackles on both ends and just bolt the spring in place. If it doesn't center between the walls find out why. Any kind of shim isn't going to be your answer.
    05snopro440 likes this.
  17. 1biggun
    1biggun
    About 5" of flat bar a grinder and a drill and a few minutes of time can make you any shim you want to angle your spring back . Id first make sure the hole is centered or if you can slot it to reposition the spring in the cross member.
    Sounds like your cross member is not welded in at the correct angle and your trying to compensate for it slightly
    Guys are not understanding your not trying to change caster but trying to get the spring to Not interfere in the cross member.
  18. I'll go out on a limb here being I have a little extra time. I think we all know this but often forget to include it in our search for problems. EVERYTHING to do with suspension travel no matter how short or long moves on an Arc if it's anchored on one end. I doubt anything past your spring contact problem has created the issue. 4-bar, Hair pins or split bones only Locate the Axle. Poor adjustment or Arc swing can load the spring but for it to make contact with the front wall the center bolt should be out of socket or Sheered off at the head of bolt letting again move forward. Were it me I'd be doing Nutz-n-Bolt investigating and take the "make-a-shim" idea and put it on the shelf for now.
    GuyW and pprather like this.
  19. woodiewagon46
    woodiewagon46
    from New York
    I see a lot of welds and if I'm not mistaken the crossmember is really leaning back. Have you measured your wheelbase on both sides of the car? I believe something else is going on with your front end. I would step back and start taking some measurements to figure out what is really wrong. A shim is just a band aid!
    clem, Johnny Gee and Pist-n-Broke like this.
  20. I agree with woodiewagon46. I believe your problem is a Result of a separate issue but I'm not here judging your ch***is, just trying to help determine why you think you need shim.
  21. Bikelessbill
    Bikelessbill
    Frame is on stands now and way above ride height. When level crossmember is at 5 degrees . Crossmember is from Welder Series and have about decided it was bent on front side just a little more than should be. Slightly more narrow at bottom than top.
  22. pprather
    pprather
    I'd put a pipe wrench of front side of the crossmember and get it parallel to back side?
  23. ALLDONE
    ALLDONE
    does this look the same both sides??? why does the cross member have such a bow?? if you un hook the wish bone or what ever you have does the problem go away..., to me some thing is pushing the axel too far forward... which would mean hair pins too long, what did pete say?
  24. ALLDONE
    ALLDONE
    the shim will do nothing because the axel is solid mount....you un hook the spring and cycle the axel...adjust the hair pins or what ever,,,, if it's wish bone the cross member is too far back..
  25. ALLDONE
    ALLDONE
    how bout a pic of how the axel is mounted
  26. ALLDONE
    ALLDONE
    but the caster is set by the hair pins, or what ever,,, correct????
  27. ALLDONE
    ALLDONE
    this^^^^^^^
  28. There is so much more to a good riding smooth handling I Beam than just having all the pieces in place. Remember the Arc swing I mentioned a while back. The spring angle also needs to be included in that formula.
  29. 05snopro440
    05snopro440
    If the crossmember is too narrow at the bottom as you say, why couldn't you use a porta power to spread it?
    pprather, ALLDONE and Pist-n-Broke like this.
  30. Good thought however, a porta power distributes pressure both directions evenly. To make that work you would need to brace the back side, so it doesn't move at all. Doing that could easily create a new problem and not really cure the first one.
    Johnny Gee likes this.
