Technical World War Two oxygen tank question
Discussion in 'The Hokey Ass Message Board' started by GEZSFRK, Aug 2, 2025.
  1. GEZSFRK
    GEZSFRK
    I’ve seen some old World War Two oxygen tanks used as fuel tanks but are they capable of being converted to use and air ride storage tank? Has anyone on here done that?
    Thanks
  2. deathrowdave
    deathrowdave
    from NKy
    Should be no problem as long as operating pressure is below test pressure
  3. GEZSFRK
    GEZSFRK
    But how do I know what psi they are capable of holding?
  4. Gary Addcox
    Gary Addcox
    My Dad built an air compressor for pointing cars with one of those tanks. It reallly looked sharp with the bands running around its cir***ference. It worked for me years later.
  5. studebakerjoe
    studebakerjoe
    If I recall correctly I think they were rated for about 400psi
    LWEL9226 and chryslerfan55 like this.
  6. RodStRace
    RodStRace
    Materials degrade over time. They had a very high operating pressure, but that was long ago.
    They can be tested like any other tank, but I really doubt anyone who certifies would get involved without serious money.
    So that leaves you with giving it a try and hope you are lucky, or going with a new tank.
    BTW, previous threads on these say they hold about 8 gallons. If you are planning on doing a system, volume is one thing that should be specified.
    More here
    https://www.practicalmachinist.com/forum/threads/surplus-stainless-oxygen-tank-safe-pressure.222995/
    mohr hp and GEZSFRK like this.
  7. jet996
    jet996
    from WY
    All of them i've got with stencils still readable say 400 psi operating pressure, FWIW.....
  8. Squablow
    Squablow
    I've seen tons of them used as air compressor tanks, I think they're rated for way more than you'd ever use in an air ride car, and I'm quite sure several have already been used for that purpose. You could use two for double volume if you needed more capacity. They're stainless steel and quite well made, I'd be really surprised if they degraded much over time.
    Personally, I'd trust the quality and worksmanship of one of those over a catalog-ordered air ride tank.
  9. Blue One
    Blue One
    from Alberta
    How do you point a car ? ?
  10. RICH B
    RICH B
    Aren't they stainless?
  11. alchemy
    alchemy
    Yes they are stainless, and I’d trust the workmanship of US WWII factories over modern Chinese factories.
    Ziggster, RICH B and 1952henry like this.
  12. mr.chevrolet
    mr.chevrolet
  13. patsurf
    patsurf
    69fury likes this.
  14. 1biggun
    1biggun
    Dad has one that we fill to 140 PSI every time its used as a air tank for at least the last 6o years he has had it or more . I used it for 20 at the races to fill tires . there SS so there not going to rust out and and for home or auto air stuff there likely never filled more than 120 PSI f as that's what most compressors are maxed out or less these days so there are likely never over stressed or near 400 PSI there rated for .
    If its not all beat to **** id run it at 100 PSI and not worry .
    My Grandfather had like 20 of them tanks when I was a kid . He made a dog bowl out of one . he had one rigged as a fuel tank on a wood splitter .
    RodStRace likes this.
