I inserted key into the trunk lock on my 58 Ford Fairlane and the key and lock spin in a circle and will not unlock. Will spin just as easily clockwise or counter-clockwise. I have never had a problem with the trunk latch and the SOB worked fine literally 5 minutes before! Any thoughts would be greatly apprciated1
Tumbler stays in the latch. I was hoping the problem was in the lock, but the pot metal arm off the lock shaft is broke. I will see if I can find one, or fab something up. Thanks.
Thanks! I got to check out a 56 Fairlane and 57 T-Bird at show and they appear close enough to work. Now to find one or the “ copy it in br***” suggestion sounds like a viable option!
