Projects FLIPPING THE FRONT AXEL ON A 59 F100
Discussion in 'The Hokey Ass Message Board' started by ALLDONE, May 17, 2025.
  1. ALLDONE
    ALLDONE
    it's not as bad as the camera makes it look... probley 3'' or better..
  2. twenty8
    twenty8
    lodaddyo likes this.
  3. In the 50's my friend did this on his 56 Ford Pickup and the axle beat a hole in the engines pan. He modded the pan and raised the engine a little.
    ALLDONE and GuyW like this.
  4. theHIGHLANDER
    theHIGHLANDER
    Nobody just does a simple big n little rubber rake any more? I don't mean to tell the whole crowd you got a corn kernel on your lip. Simple n cheap parts chaser/shop truck. The less mods the better? You spoke value. 50 guys want it closer to stock and easy to service, there's maybe 4 of us who think dropped axles and s****ing speed bumps is fun.
    Or I can just shut the fk up and keep watching, I love these trucks.
    GuyW and ALLDONE like this.
  5. ALLDONE
    ALLDONE
    I put it back how it was... and it does have tire rake..probley gonna stay that way... I bought a new coyote powered f150... but don't wanna haul nothing in the bed so the shop truck needs back on the road soon..
    GuyW and theHIGHLANDER like this.
  6. Okie Pete
    Okie Pete
    Call Sid he will drop you an axle
    Jibs and warhorseracing like this.
  7. lucky ink
    lucky ink
  8. patsurf
    patsurf
    theHIGHLANDER, GuyW and ALLDONE like this.
  9. ALLDONE
    ALLDONE
  10. ALLDONE
    ALLDONE
    so here's where I'm at.... I have 4 f series trucks... all have F'd up suspension..my 56 f-100 has a drop axel... IMHO ..hokey... my 51 F-1 has lowering springs...hokey,.. my 59 lowered springs... hokey.. and my 64 is stock... works kinda good.....I'd like to find a good way to go that modernizes the suspension... back in the day these trucks all got (most all) Camero front clips... and thy worked good... hokey? yep... but worked... now what is there??? not a fan of the crown vic...and no more fat man??? whats the absolute best way to go now days???
  11. ALLDONE
    ALLDONE
    on my 56... drop axel with sway bars frt and rear.....here's what I notice... but trying not to... boarder line wants to bump steer...camber is neg about 3/8'' probley started at zero but slowly bent because of the huge drop in the axel...all ch***is ride good on smooth new paved roads... but thats not real life..... so.. to make theses trucks ride like the new trucks... whats the best fix???
  12. flynbrian48
    flynbrian48
    I have some news for you, it's NEVER going to ride and drive like a new truck (if that's your goal), it's always going to drive exactly like what it is, a 65 year old pickup truck without changing the front suspension. If that's what you're wanting, chuck the entire existing stock axle and get a Heidt's, Art Morrison crossmember, whatever, with control arms, T'bird style rack with MII spindles and do that. If you're paying someone else to drop your stock suspension, by putting axle on top of the spring, dropped axle, de-arched springs, whatever, it's going to end up costing you the same amount of money as going to a more modern, independent front suspension and it will still be a 65 pickup truck. My '48 Diamond T one ton I built using a late 90's Chevy 3/4 ton front crossmember and suspension, and guess what? It rides and drives like a 1948 one ton truck, although the steering is early 90's Chevy pickup zero road feel easy.
    Very good looking truck, BTW.
    warhorseracing likes this.
  13. lucky ink
    lucky ink
    C notched frame after got stance.
  14. lucky ink
    lucky ink
    Moved steering box onto top of frame shortened column. There was a thread on here years ago someone did this. Have to do some digging. 1960s ford bonneville truck.
  15. Can answer the “other options” better on the OT forum.
    Might need this moved.
    however, I picked up a dropped axle for my 49. I hope it drives and steers like it did in 49.
  16. lucky ink
    lucky ink
    Found it was wrong look up this. It worked. Screenshot_20250922_182101_Chrome.jpg
    ALLDONE likes this.
  17. ALLDONE
    ALLDONE
    still wanna lower the 51, 59, and the 64
  18. ALLDONE
    ALLDONE
    so here's where i'm at... got a Sids axel for the 51... and gonna get a Sids for the 59...might, or should I say have to mod the steering...after I get those done... I'm doing the 64...like I said I have a new f150... but never drive it....but if I find a need to go modern suspension, I'll just drive the new one....I love driving the oldies.... it's such a joy when you go some where and make it all the way back home.....
    warhorseracing and Tim like this.
  19. HSF
    HSF
    from Lodi CA
    Sid's is the way to go. No bump steer, coolest dude to deal with. Been driving with his dropped axle for almost 15 years now. This is my newest vehicle and gets driven a lot. Screenshot_2025-10-14-19-33-01-45_965bbf4d18d205f782c6b8409c5773a4.jpg
  20. ALLDONE
    ALLDONE
    cool truck!!!
  21. ALLDONE
    ALLDONE
    so with sids axel... I should 2-3'' more drop???? right???
  22. HSF
    HSF
    from Lodi CA
    3 inches plus I put a mono leaf from Sac vintage Ford. That was another 4 inches. Flipped the rear and pulled 3 leaves.
  23. HOTRODNORSKIE
    HOTRODNORSKIE
    Here's what I did on my 57, the first time around I did a poor man's drop just reversed the load bearing and removed some leafs drove it all the way to the twin cities that way. Second and final time I installed a Chrysler torsion bar now I wish I would of went with a dropped axile the thing is way to heavy up front with the YBLOCK bit I have been driving it this way for the past 25 years. 20240522_201843.jpg 20241020_145729.jpg
    dwollam and warhorseracing like this.
