Technical Mystery (to me) 59 AB update
Discussion in 'The Hokey Ass Message Board' started by e z i, Aug 4, 2025.
  1. e z i
    e z i
    I picked up a 59 AB flathead from a friend for my 33 Tudor sedan about a week ago, and I pulled the intake manifold, and heads, to inspect the bores and the overall condition of the block.
    Before I took it apart, I did a garage floor compression test with a 12 volt battery and help from my brother. It had 125-130 in every cylinder, so I was happy about that. Anyway...
    I found adjustable tappets, and close to perfect cylinder bores.
    Also, it has home made looking water jacketed (cooled?) exhaust manifolds.
    And these markings on the pistons, and valve relieves in the block. And input would be appreciated.
  2. e z i
    e z i
    Don't know why I can't upload pictures, I've done it 100's of times here.
    The pistons have stamped on them:
    3 7/16, 1/8 LC
  3. Bearing Burner
    Bearing Burner
    from W. MA
    Wow that's a big bore. I had ond 33/8+.030 and the walls were paper thin. Cracked early.
  4. e z i
    e z i
    Yeah, I don't know, it looks good, and it was a good running engine, according to the buddy I bought it from..
  5. rusty valley
    rusty valley
    Must have been goin in a boat. I would have run it after seeing those compression numbers, just sitting on the floor. let the neighbors know you are still tinkering with cars.
  6. drtrcrV-8
    drtrcrV-8
    Check the stroke, with a Merc crank (4" stroke) that seems awfully close to 302 cubic inches, but if that turns out to be a 4-1/8" stroke that's around 312". A very big Flattie! Any idea when or who built it??
  7. e z i
    e z i
    CSPIDY and warhorseracing like this.
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    1/8 LC {low crown} should be for a 4 inch stroke.
    warhorseracing and Bandit Billy like this.
  9. Bandit Billy
    Bandit Billy
    Yep, Merc crank in there. Healthy engine or was at one point. What was on it for an intake and heads? I'd like to see the exhaust manifolds if you can post it.
  10. e z i
    e z i
    It has/had a stock intake manifold on it. I removed the timing cover, and I see no marking on the cam, so it's probably a stock cam, I guess.
    It also has head bolts instead of studs. The heads are standard 59ab. I'm in Idaho right now, so I'll have to get pictures of the exhaust manifolds when I get home to Arizona.
    Bandit Billy likes this.
  11. NoSurf
    NoSurf
    Is it a 59L block?
  12. alchemy
    alchemy
    I see a factory relief.
    ronzmtrwrx, ydopen and Bandit Billy like this.
  13. Budget36
    Budget36
    Where do you notice the relief at?
    I’m not doubting you, but I don’t see it with the pic of the piston stampings.
    warhorseracing likes this.
  14. I see it too, on my PC, on pic. Good eye there alchemy.
  15. inthweedz
    inthweedz
    I'm thinking it's the shaddow of the block, on the piston, to the left of the 3 7/16 marking..
    Budget36 and Bandit Billy like this.
  16. Bandit Billy
    Bandit Billy
    That's some sharp eyes to pick off that ledge in the block. I had to go back and look for it. I think @alchemy sees it correctly. I read that Ford didn't factory relieve the 59, 59A, 59AB, anyway that is how I heard it, something about soft casting? Truck block maybe? Or it was relieved after the fact. I relieved my 8BA when I built it, rather I paid to have it relieved.
  17. e z i
    e z i
    No, I had an L block once, and I see no L on this one
    RAK likes this.
  18. alchemy
    alchemy
    I’ve got a couple factory relieved blocks but can’t remember what letter designations they are. Kinda think one of them is a 59 X or Y block. They are packed away in different locations so I can’t run out and look.
    The factory relief is really simple, just the straight down notch. Doesn’t follow the edges of the gasket at all.
  19. e z i
    e z i
  20. Budget36
    Budget36
    Now I can see it
  21. drtrcrV-8
    drtrcrV-8
    With all the other "Hot Rodding " that has been done to it, I would really suggest checking out that cam ! you might just be pleasantly surprised...
  22. Ziggster
    Ziggster
    Both my C59 blocks are factory relieved. So, were all such Canadian blocks relieved?
  23. alchemy
    alchemy
    Here’s one of mine that I could get a pic of without moving too much junk. Just a simple factory relief on a regular 59 block.
    This goofy engine was ***embled with 8BA heads, water pumps, crank/rods, and cam/distributor when I got it. I hoped it would be a Merc crank but it wasn’t.
    warhorseracing and e z i like this.
  24. e z i
    e z i
    Don't they usually have a identification stamping on the cam gear side?
  25. e z i
    e z i
    Someone asked to see the exhaust manifolds so here they are. I believe it's a 4" crank also.
    She's got some thick *** piston skirts PXL_20250831_181824851.jpg PXL_20250831_181915590.jpg
    NoSurf and Bandit Billy like this.
  26. Ziggster
    Ziggster
    Looks like marine engine type exhaust manifolds. Must have been in a boat at one point.
