Hot Rods coil over shocks ?
Discussion in 'The Hokey Ass Message Board' started by putz, Aug 6, 2025.
Tags:
  1. putz
    putz
    from wisc.
    is it possible to run shocks without coils ?
  2. Budget36
    Budget36
    You need something to hold the vehicle up. Or am I missing the question completely?
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Then how would vehicle stay suspended if one did such a thing?
    Joe Blow and 19Eddy30 like this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Joe Blow likes this.
  5. Bandit Billy
    Bandit Billy
    You arent missing anything, something has to suspend the car. Maybe the OP has a spring and needs shocks. If so, they wouldn't be the best looking shock but you could remove the spring and run the shock, providing the top mount unscrews like a QA-1.
    putz and Budget36 like this.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Wouldn’t that be like buying Champagne to pour out then refill with beer. Why?
    uncle buck and lostone like this.
  7. Dave G in Gansevoort
    from Upstate NY
    More information on what you want to do is needed.
    Johnny Gee likes this.
  8. Kerrynzl
    Kerrynzl
    yes!
    As long as it has other means of springing
    Good answer
  9. DDDenny
    These are coilovers.
    Joe Blow, swade41 and Johnny Gee like this.
  10. DDDenny
    These are not coilovers.
  11. swade41
    swade41
    from Buffalo,NY
    Come tell this to my neighbor, he'll try and convince you that they are to the point of arguing about it. Lol
  12. Clydesdale
    Clydesdale
    Technically they are, the ***istor coil is over the damper.
    They are not spring preload adjustable coilovers, which most folks term as 'Coilovers'
    In answer to the OP question, you can run coilover dampers without springs no problem, obviously you need some form of spring to suspend the vehicle but I'm pretty sure you already have that.
    The only negative I can see is the aesthetics of having a threaded body, If they're hidden or you aren't bothered by looks then go for it!!
  13. '29 Gizmo
    '29 Gizmo
    from UK
    Coil over shock - coil over = shock.
    Just Gary likes this.
  14. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Air Shocks- the kind Back in the seventies, that would pound their way through the trunk floor on tri-five Chevys.
    klleetrucking likes this.
  15. gene-koning
    gene-koning
    Back in the 70s when I worked at the gas station, this style of shock was called "overload shocks". the intended use was to add additional weight support to the rear of the car or truck. They were often bought to lift the rear a bit when the rear springs were getting weak, or if the car was expected to have to carry extra weight (like many station wagons did). Overload shocks could be pretty hard on the shock mounts. Shocks were not designed to support the vehicle weight.
    Yes, these were what we called coil over shocks. Their intended use was to eliminate the original coil (in most cases) springs. These started to become popular in the late 1970s.
    The advantages were lighter weight (especially after the original springs were eliminated), and most had the ability to be adjusted for ride height. Most were used on street rods or off street race cars.
    The disadvantage was they often required extra mounting bracket reinforcement.
    There were also McPherson struts that have the spring mounted above the shock, which many mistakenly call "coil over shocks" as well. These were what the original coil over shocks (the 2nd grouping) were designed from.
  16. putz
    putz
    from wisc.
    what I have are Viking coil overs ... can I run with out coils is the question .
  17. Marty Strode
    Marty Strode
    I saw a pair of those in use as coil overs on a bracket car from California. The guy was thrifty.
  18. Marty Strode
    Marty Strode
    Yes you can.
    putz likes this.
  19. putz
    putz
    from wisc.
    I do have ch***is eng. springs on it , I bought the coil over for a better ride and handling ... 40 Ford pick up
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    You do not need anyone’s support to use them. Just do it.
    leon bee likes this.
