Hot Rods Looking to get some aluminum polished
Discussion in 'The Hokey Ass Message Board' started by Shoeboxdriver, Aug 6, 2025.
  1. Shoeboxdriver
    Shoeboxdriver
    from Holmen, WI
    I just sent some pics of an aluminum intake I'm considering having polished to folks I have used in the past for stainless steel and aluminum polishing. I understand everything costs more these days but I was ASTONISHED at their estimate. Perhaps they are spot on but I would like to get another estimate, does anyone have a recommendation for a person or business that does metal polishing? Thanks.
  2. Hubnut
    Hubnut
    image000001(3).jpg image000000(5).jpg Oklahoma Elite Metal Polishing did these pieces for my buddy. Not cheap, but possibly cheaper than you what you were quoted.
    alanp561 and dana barlow like this.
  3. Bandit Billy
    Bandit Billy
    How much was it? And post the pic of the intake.
  4. Shoeboxdriver
    Shoeboxdriver
    from Holmen, WI
    IMG_2611.JPG $900.00 estimated.
    tractorguy likes this.
  5. Shoeboxdriver
    Shoeboxdriver
    from Holmen, WI
    Looks like they did excellent work, I'll touch base with them. Thanks.
  6. Rickybop
    Rickybop
    $900 does seem like a lot. But I suppose established businesses have to cover their overhead and everything. Still, that intake doesn't even have too many crazy divots nooks and crannies.
    It's the crannies that get ya.
    Just Gary likes this.
  7. Just Gary
    Just Gary
  8. Bandit Billy
    Bandit Billy
    Hmmm, 900 bones is a bit rich in my book. That "Edmunds" lettering is not in there very deep. Sanding and polishing that area is going to take some time and effort. I'd guess it would take $100 in materials (small Dremel and die grinder polishing heads for the tight bits around the bolt stands and a box of abrasives for the flat areas). If you are a novice and want that lettering to remain, I wouldn't advise it.
    If you do attempt it, I'd hit that lettering area with 1000 max. That is the front of the manifold and the easiest seen, it MUST look good. If you were closer, I'd tackle it, but my price plus shipping and insurance will cost you as much as the local price quote. If you were local, I'd tackle that for half of what they quoted.
    If you do pay to have it done, make sure you want that logo lettering as sharp as possible (there has to be some deterioration in the process). It loses value as well as interest if the lettering is destroyed.
    If you do it yourself, I'm happy to help with tips, products, tools and compound recommendations. It isn't rocket science; you can do this and buy yourself some new tools in the process if you don't have them already. My quest is to make the hot rod world a shinier place to live.
  9. Mr48chev
    Check with Andy Tants (he is in Columbus Ohio) I don't have a phone number but he is on FB (20+) Facebook and did a beautiful job on my 292 valve cover that I got in rough casting from 12 Bolt Tom.
    I'd find a machine shop that does a lot of work on aluminum engine parts that has a cold tank to soak aluminum in and have it cleaned that way before I sent it to anyone though.
  10. Bandit Billy
    Bandit Billy
    For example, this was done by my chrome shop for a friend of mine. $300. It's very nice, could have been tighter in the valleys around the bolt stands but I would run this on anything I own. He chose not to polish the Eddie Meyer logo as he is going to paint that area. I would have polished the raised areas of the logo. $900? damn.
  11. Dave G in Gansevoort
    from Upstate NY
    Sounds like a well I’ll do it if you want to spend exorbitant amounts of money quote, ie I don’t really want to do it…
  12. HEATHEN
    HEATHEN
    from SIDNEY, NY
    It's unfortunate that your Edmunds intake is one of the few that wasn't polished at the factory. The majority of Edmunds intakes I've owned or seen over the years were.
    deathrowdave likes this.
  13. Joe H
    Joe H
    How often do you have to republish them?
  14. 19Eddy30
    19Eddy30
    from VA
    If aluminum here and there just keep clean .
    If magnesium about every four days
    Bandit Billy likes this.
  15. 57 Fargo
    57 Fargo
    As some who once made a living polishing aluminum I wouldn’t even touch that intake for $300-$400. There is untold hours of sanding and polishing to get a “show” finish. I honestly don’t think they are far off.
    19Eddy30, tractorguy and Just Gary like this.
  16. 57 Fargo
    57 Fargo
    I should say that it’s certainly not difficult either just time consuming
    j hansen, Just Gary and 19Eddy30 like this.
  17. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yes. I polished a rough cast aluminum side cover for a 235/261, and it came out nice. I would consider the time I had in doing it preferable to spending $900.00.
    57 Fargo and Just Gary like this.
  18. Shoeboxdriver
    Shoeboxdriver
    from Holmen, WI
    Billy,
    Big thanks for your comments, recommendations, and precautionary advice regarding preserving the Edmunds script. I have polished stuff and am aware of the time involved. I polished the Edelbrock intake in the attached pic and was so burned out that when it came to the heads I shot them with gloss Cerakote ceramic and called it good. I contacted the folks that Hubnut recommended and was given a quote almost half as much, will be using them. Thanks again man. IMG_2542.JPG
    lostn51, 2devilles, Motorwrxs and 3 others like this.
  19. GuyW
    GuyW
    If it were mine, I'd consider acid etching the existing script to deepen it
  20. Bandit Billy
    Bandit Billy
    That sounds like the correct price for a nice polish job. Glad to be of help.
  21. Bandit Billy
    Bandit Billy
    Oh, and nice-looking flatty in the pic. That intake looks good! It takes a lot of time and patience to turn something out like that. I laughed at your comment about being burned out and just coating the heads. I polished a 5 speed this year, once I started, I was regretting the decision :cool: When you get the intake polished you might refresh your thread and post a picture of it. I never tire of looking at polished hot rod parts.
    akoutlaw and Just Gary like this.
  22. 19Eddy30
    19Eddy30
    from VA
    Same here ,Burnt Out with Polish magnesium
  23. Shoeboxdriver
    Shoeboxdriver
    from Holmen, WI
    I WILL do that when I get it back. I too have always loved shiny hot rod parts. When I was 17 I rebuilt a Plymouth flathead 6 and even then I had some Bling on it. 1939 Plymouth Engine.jpg
  24. Shoeboxdriver
    Shoeboxdriver
    from Holmen, WI
    I WILL do that when I get it back. I have always like shiny hot rod parts. At 17 my first engine build was a Plymouth flathead 6 and even it had some Bling on it. 1939 Plymouth Engine.jpg
    GuyW and Bandit Billy like this.
  25. jimmy six
    jimmy six
    lostn51, tractorguy and Just Gary like this.
  26. patsurf
    patsurf
