Technical ***August 2025 Banger Meet Thread - Yes, Already***
Discussion in 'Traditional Hot Rods' started by Jiminy, Aug 1, 2025.
  1. I tested the prototypes of those too...
    fur biscuit, G Baese, dwollam and 6 others like this.
  2. Bonneville 2025
    The week started off with a single run to qualify and a backup run to set the record in V4F/GMR, simple, right?
    Then we became greedy and reentered as a FMR fuel, you know nitro and all that stuff
    Oh well, we will go looking for the lost #2 cylinder later this weekend.
  3. winduptoy
    winduptoy
    congratulations!!!!....and for #2 son Rodney leaving the scene...you aren't so much a back of the envelope guy ...more of a push the envelope....
    Outback and jet996 like this.
  4. chlsnk
    chlsnk
    Found a 32' air "cleaner" I'm liking the looks of on my engine. 20250802_112111.jpg
    mvee33, G Baese, dwollam and 8 others like this.
  5. Stovebolt
    Stovebolt
    That air cleaner
    Outback and winduptoy like this.
  6. Outback
    Outback
    from NE Vic, Oz
    That's awesome on the record, well done!
  7. Dan from Oakland
    Dan from Oakland
  8. Stovebolt
    Stovebolt
    x 2
  9. Jason Lemon
    Jason Lemon
    Not sure if this is ok to add in here. I am trying to buy a Rocket 428 speed head for a banger build. The guy hasn't been making the heads but says if he gets 20 people he will take a $400 deposit to start a batch of heads. Would take about 4 months. $850 per head. Is anyone in here interested in one? I just got on the list as #12. I would say we need about 10-12 more people incase someone backs out. If you are interested, Please go to his website and email him to get on the list.
    https://www.secretsofspeed.com/rocket-428-images
    secretsofspeed.1@gmail.com
    Jason
  10. wuga
    wuga
    Charlie Yapp has been building those heads for a long time. We are running both a Lion head and a Rocket head here. Have you checked with Jim Brierley to see if he is casting or has any new heads?
    Warren
    winduptoy, Outback and s.e.charles like this.
  11. Kevin Pharis
    Kevin Pharis
    from Califunny
    Made a new hub nut for a Houk #4 wire wheel set last weekend. The original special hub nut is cast aluminum, and houses a hub mounted Veeder odometer unit, factory accessory for a Detroit Electric automobile. A little time on the lathe, and some twisting and turning in the new mill, just about DUN!
    G Baese, Crazydaddyo, burl and 9 others like this.
  12. Outback
    Outback
    from NE Vic, Oz
    winduptoy and 4BangerDean like this.
  13. Jason Lemon
    Jason Lemon
    Charlie is gonna do another run of heads IF he gets enough interest. Have not asked Jim
    G Baese and winduptoy like this.
  14. Kevin Pharis
    Kevin Pharis
    from Califunny
    Thanks! The next project will also be wheel related… but much bigger! We’ll see how it goes…
    winduptoy and Outback like this.
  15. ‘Been out of it for a while.
    Looking to replace a leaky flexible fuel line to BNGR’s carb.
    Tell me again what’s THE hard line to use please.
    Thx
    Art
    Outback likes this.
  16. Crazydaddyo
    Crazydaddyo
    Nice work John, congratulations.
    Outback likes this.
  17. Dan from Oakland
    Dan from Oakland
    Steel brake line works pretty well for hard fuel lines.
    winduptoy likes this.
  18. wuga
    wuga
    I use Nicop for fuel lines and cooler lines. It looks good and won't crack with vibration.
    Warren
    jet996, winduptoy and Outback like this.
  19. Thanks All
    It has been an Honor to work with these folks
    Creel, Nelson & Nelson and Kendall
    John
  20. Gary in MN
    Gary in MN
  21. brjnelson
    brjnelson
    Gary,
    they race small Badgers in Wisconsin ?
  22. 2 year olds....
  23. Gary in MN
    Gary in MN
  24. Kevin Pharis
    Kevin Pharis
    from Califunny
    Looks like a bonafide hot rod to me! McDowell…?
  25. Dan from Oakland
    Dan from Oakland
    Looks like Ford trans also, etc, but what's with that frame? Dropped axle yea, but a dropped frame??? Steering column laid back pretty far so...........
  26. wuga
    wuga
    Need some help here.
    Late in 2023, I acquired a Jim Brierly 7:1 head and a Yapp Equalizer dual intake. They were installed and ran well all through 2024 and into early 2025. A while back the car started to run poorly and idle at 2000. Earlier this summer in talking to Jim Brierly, he mentioned that I should be running the 18 degree FSI and not the 28 degree which was in engine. I installed an 18, but perhaps too late. This past weekend on a hot rod tour, the engine suddenly overheated and stopped. I could not restart it. Today I tore the engine down and this is what I found.
    The BEST gasket was burnt out between 3&4 and starting to destruct between 1&2
    Cylinder 3 was clean (left to right 4,3,2,1)
    Combustion chamber 3 was clean (left to right 4,3,2,1)
    The plugs looked a little carboned but the gap was correct. (left to right 1,2,3,4)
    The engine was built by Bert’s some years ago, but only came to life in the past four years. It only has about 1200 miles on it. The new head was torque to 65lbs and the surfaces appear to be flat. I’m not really smart on engines and was wondering if anyone had insight.
    Warren
  27. winduptoy
    winduptoy
    Hate it when the fun comes to a sudden stop...
    I can't tell for sure, but the mating/coverage of the fire ring on the gasket to the head looks suspect. Do you have a new head gasket to lay on the head to look at that way? Does Brierley say to use an A or a B head gasket with his head? If there is any fire ring not covered by the head, that is suspect in my mind.
    65 ft lbs is more than I go, you don't want to draw the threads out of the block. I don't know what you have for head studs. Chrome/moly at a minimum
    I always torque to 55 ft lbs and start the engine without any coolant in it and let it idle until the head gets too hot to touch.
    Then I re-torque it hot to 55
    let it cool and re-check it to 55
    fill the cooling system with water, then drive it and drain and re-torque when it is cold
    Fill it with coolant and worry about other stuff
    Savage Coupe and Outback like this.
  28. wuga
    wuga
    That is a Best 573 gasket for a model B. The Best 509 is the 28-31 gasket but Snyder's say to use the 573 on Hi-Comp heads. I just ordered a new gasket set from Olson's and I don't know which copper head gasket it contains. It was Jim Brierly who advised me to go to 65lbs.
    What is the difference between the A and the B gasket? Should I use the 509 A gasket if it comes?
    I am using ARP studs, washers and nuts. I like your sequence and will use it when putting the head back on. I think with this sequence I will also only go to 55lbs. There will be updaates.
    Thanks Larry
    Warren
    Outback and 4BangerDean like this.
  29. winduptoy
    winduptoy
    G Baese and Outback like this.
  30. 29Sleeper
    29Sleeper
    from SoCal
    I think Jim mentioned last Saturday he had 2 heads left and was going to possibly get more castings (which have jumped in price - again). Don't forget Jim's heads are a little taller for better cooling so you'll need to use different studs. Jim uses ARP and generally sells them with the head (if he has them).
    jet996, Outback and Stovebolt like this.
