Technical Mallory distributor part number list
Discussion in 'The Hokey Ass Message Board' started by Moriarity, Dec 3, 2017.
  1. drtrcrV-8
    drtrcrV-8
  2. Beanscoot
    Beanscoot
    I wonder how many of those part numbers were actually represented by a physical example.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
  4. Moriarity
    Moriarity
    SUPER MODERATOR
  5. Moriarity
    Moriarity
    SUPER MODERATOR
  6. Moriarity
    Moriarity
    SUPER MODERATOR
  7. cretin
    cretin
    Hey guys, I have recently acquired some Cadillac 331 stuff, in which a Mallory Magspark distributor and transformer were included.
    So looking at the tag, it is model ZCM, which seems to mean that it has both centrifugal and vacuum advance, 24875-b circuit breakers, and is designed for use with the Magspark transformer. All good there. But, the type stamping has me a little confused. It is stamped 248 AB, which is indeed the type for a '49-'51 cadillac, but the AB has been restamped, with a deeper AX over it. What would that mean?
    It also appears that possibly the M on the model designation could have been stamped at the same time as the AX.
    Also, and I see the Magspark is a dual spark, I would ***ume that im missing a set of points inside the distributor. Is this going to be a hard item to replace? And the last question, I have just gotten it and have not dug into it at all, but the rotor will only turn about a half an inch and it hits something to prevent it from turning any more. Obviously, I have to open it up, but any ideas on why that might be? Maybe there is something common with these?
    rod1 likes this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    there never has been a real good description that I have ever found as far as the suffix letters other than the different suffix letters are different advance curves. maybe the advance was modified on yours and that is why it was re stamped. and yes it is supposed to have dual points
    cretin likes this.
  9. Fordors
    Fordors
    You need an additional set of Mallory 24875 points and if you do use the MagSpark transformer the point sets are not connected to each other, they are wired independently to the MagSpark transformer.
    You did not mention your distributor cap but I suspect it is the later Mallory 4004 black cap. Your rotor is the Mallory 24215, it has a spring under the contact and the contact is longer interfering with the contacts in the 4004 cap. A Mallory 4215 rotor will be compatible with your black distributor cap and be much cheaper than paying for a good brown 24004 cap.
    1Nimrod and cretin like this.
  10. cretin
    cretin
    Awesome. Thank you guys.
    Fordors, it has a brown 24004 cap in fantastic shape. The issue with it not spinning, is still an issue with the cap off.
    The number on my points plate is 24878, and you are correct on the rotor, it is 24215
  11. Beanscoot
    Beanscoot
    My guess is that Mallory had an "-AB" distributor in stock and got an order for an "-AX" unit. So they just recurved it and restamped it before sending it out.
    The restamped "M" is over an existing "M", maybe they just wanted it more bold.
    cretin likes this.
  12. Hey thanks for this, going to come in really handy
  13. Moriarity
    Moriarity
    SUPER MODERATOR
  14. tubman
    tubman
    Thanks Mark. This thread has been very helpful to me.
    (There is a remarkable amount of Mallory stuff still out there in some strange places.)
    Moriarity likes this.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    bump for swap meet season
    stillrunners likes this.
  17. Great info! I missed this the first few times it came up. Coincidentally, I finally found a source for the vac advance dash pot that was bad on the Mallory for the 390 in my OT ‘68 F250. She runs like a champ now!
  18. nrgwizard
    nrgwizard
    from Minn. uSA
    & that source is??? An interchange?
    Marcus...
  19. Finally found this guy through some truck forums. He has all the old Mallory dash pots. Called him up and $65 and 3 days later I had one in the mailbox. bob@system1filters.com
  20. 57Fury440
    57Fury440
  21. ***istance please ! ! !
    Just picked up this last night. Mallory dual point YD 356 A 2
    I know its a dual point Chebby
    I find the 356 A 2 in the mile long list posted but not the A2? 20250808_050224.jpg
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    that is a marine distributor. the 2 means that it has a mech tach drive
  23. Well thats kinda a UGH !
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    looks like one of the later red cap versions. just because its marine does not mean you can't use it in a car
  25. tubman
    tubman
    Yeah. They make real good black plastic paint that I have used on the red and blue(?!?) Mallory caps several times and it works real good. I got one pf these a while ago (although it was the earlier "flattop" version) that I am having "Charlie NY" convert for use in a Ford flathead. I found a real neat NOS SW mechanical drive tach to go with it.
  26. I was just hoping for something special, IE:Corvette or such. And yes I know That marine can be used in car applications. Not much difference between the 2. Engine blocks Marine adds 5% more nickel for corrosion protection . Carbs have the vent tubes longer bent back into the throat, Electrical rotating ***emblies are exposer/explosion proof to help not to cause a fire from gas fumes.
    I guess this dizzy would be good for a period correct flat tracker also.
