Art & Inspiration How far should my Torque Tube shaft protrude??
Discussion in 'The Hokey Ass Message Board' started by D2Denny, Aug 7, 2025.
  1. D2Denny
    D2Denny
    In the process of building a low buck AV8. Cobbled together 3 roached V8 banjo rears to make one. In the process mixed up all the parts. Shortened the tube to fit and had the shaft I thought was its mate shortened the same amount I took out of the tube. In the photo I have 1/4' of shaft sticking out past the torque tube bell. Is this in the ballpark??
    Sharpone and chryslerfan55 like this.
  2. pila38
    pila38
    In all seriousness, I wish I could help, but this topic is not in my wheelhouse. Sorry.
    jet996, Sharpone and chryslerfan55 like this.
  3. 28rpu
    28rpu
    Over the years of working with banjo rear axle ***emblies I have seen the drive shaft flush with torque tube bell end, 1/8 " deep and 1/8" proud. You'll probably be okay.
  4. rusty valley
    rusty valley
    I've done several, usually the chamfered end of the splines is about an 1/8", and thats what sticks out when you lay a straight edge across the bell. Same thing if you look at a stock shaft & tube.
  5. Kiwi 4d
    Kiwi 4d
    What you have sticking out now looks pretty much right from memory . Oh wait I can check my 32 PU it has no engine or trans at present. Awaiting a leaking trans rebuild and a mystery heart murmur in the cragar head B4.
    26 T Ford RPU and Sharpone like this.
  6. D2Denny
    D2Denny
    I crafted my words very carefully to portray my situation.
    I'm shocked that some of the good and honorable people here on the HAMB could have interpreted it differently!
    From the shaft length responses from the people in the know, I think I'll shorten mine up about 3/16" as when I had it installed it seemed the trans was somewhat tighter than without.
  7. theHIGHLANDER
    theHIGHLANDER
    I'm not familiar with the shaft exposure of others. I know where I want mine to be, and which lube works best, but for others I'd have to say do what feels right to you when you're ready to penetr...insert the shaft. If the 2 parts are already familiar there shouldn't be a lot of concern as to whether it will hurt anything going in. Clearly you'd want it in the right spot because if it got shoved in where it didn't belong that's some **** you wouldn't wanna deal with. And I'm sure you'd hear a lot of noise after, none of it pleasant. Most have plenty of depth and can take anything near standard sizes. In fact its designed to go in and out for a lifetime so it would have to be really long to cause an issue. Does that help?;)
  8. theHIGHLANDER
    theHIGHLANDER
    Ok, real answer now. One look into the U-joint should tell you how deep the splines went in and how much in/out travel was normal. It is a slip joint of sorts and as long as it isn't bottomed out you're fine. It looks ok in the pics.
    Rickybop, Sharpone and RodStRace like this.
  9. What an unfortunate thread ***le, the replies went as expected. That being addressed, Mac Van Pelt would be the one I would check with. If anyone could say for sure it's him. From where I'm sitting your shaft looks good where it is.
    Sharpone likes this.
  10. Sharpone
    Sharpone
    PS the car in your avatar is way cool!
    Dan
  11. Bandit Billy
    Bandit Billy
    Good and Honorable? You sure you weren't looking for the Ford Barn?
  12. Kiwi 4d
    Kiwi 4d
    I have looked at a 46 and 32 TT neither stick out but probably 1/4” reccess behind the TT bell.
    Tow Truck Tom and Sharpone like this.
  13. 62pan
    62pan
    Since I didnt see this mentioned the main concern is the speedometer drive. If it fits with the snap ring in place all is well. If you cant get that ring in place that's how much it still needs shortened.
  14. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Yeah I have a '48 that looks the same.
  15. D2Denny
    D2Denny
    Thanks to all who responded. I confess. I worded my topic purposely to be "click bait" and you all bit. Hope everyone got a chuckle out of it, and I ***ume we all got a good handle on the proper length of our shafts now. I know I did and will make the necessary adjustments thanks to the tribal knowledge of the HAMB.
  16. pila38
    pila38
    I don’t know you…but I like you
  17. Sharpone
    Sharpone
    ^^^^^^^^^^ What he said.
    Denny you’re alright
    Dan
    lothiandon1940 and RodStRace like this.
  18. rusty valley
    rusty valley
    Welp...I cant imagine the shaft 1/4" inside the bell. Before my auction about 2 years ago I had about 20 Ford rearends here, and all had about an 1/8" proud of the bell. Perhaps we should look at a different view, measure from the bottom of the cavity where the bearing rides to the snap ring groove as mentioned above by @62pan. It does not need to be precise, but needs to be close or the speedo drive gear can float around, perhaps cause problems? Don't know, I always used the 1/8" proud plan
    RodStRace, theHIGHLANDER and Sharpone like this.
  19. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    I just Edited the ***le to more focused and deleted off topic posts.
    Lets stay on topic,
    Thanks
    RICH B and Kiwi 4d like this.
  20. BOOO!!:D:D
    Ben
  21. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    When other fellas report it that their on topic posts get knocked down the pages a lot faster, Mods clean it up.
    That’s understandable.
    Thanks.
