Technical Ospho for headers or best exhaust for early Dart
Discussion in 'The Hokey Ass Message Board' started by Sharpone, Aug 8, 2025.
  1. gene-koning
    gene-koning
    I've pounded the **** out of a lot of small block Mopars (318- 360s) in A (and B) body Mopars. If you are not on the drag strip where 10ths of a second count (or heavy duty real street racing), headers are a waste of time and money!
    Manifolds (even the 318 manifolds you had) with dual exhaust is all you need for street driving (I did a lot of street racing), they are good up to around 4500 rpm (above that, put an H pipe in the dual exhaust just after the trans crossmember). Above 5500 rpm, that small block better have some good stuff inside of it. Real life experience.
    If you are seeking the best exhaust manifold for higher rpm performance, the Magnum motor exhaust manifolds have better flow then any other small block Mopar exhaust manifold (including the famed 340 TA 6 pack exhaust manifolds). Of them, the 93 Dakota truck (one year only) was the best, only because at the connection at the exhaust pipe, the manifold exhaust exit port was a 1/4" larger diameter (you better have a normal Magnum manifold to compare the opening to). I believe much of that improvement was because the original Y pipe (yes, single exhaust) was also a bit larger diameter at the manifold connections. The replacement Y pipes are all the same diameter and bolt onto the 93 manifolds. Read that as many times as it takes to understand that the very best flowing exhaust manifolds Mopar made for their small blocks were connected to a single exhaust system. The famed Dakota RT had single exhaust, and the legend Little Red Express trucks of the late 70s had (not great flowing) exhaust manifolds and dual exhaust.
    I have never installed a magnum exhaust manifold into an early A body, I suspect it could be a challenge due to the rear pipe connection.
    Change to the mini starter. Rid yourself of the old, heavy, large, gear reduction original.
    49ratfink, Tow Truck Tom and Sharpone like this.
  2. Sharpone
    Sharpone
    Thanks Gene I have Dakota RT exhaust manifold, at present it doesn’t fit if you look at photos 1 and 2 it hits the column tube and the coupler. The tube I figure I could remove the shift lever and cut 3 or so inches off reinstall the bearing and seal. I will not grind on the coupling however I might be able to grind enough off the manifold for clearance. I’m not against mini starters but don’t want to spend money if not needed.
    The manifold that came with the engine absolutely won’t fit it dumps right at the steering box.
    I’ve been told and have read that the single exhaust works very well indeed. My sources tell me a min of 2-1/2” and up to 3” will handle any HP I ever intend to make.
    Gene have you ever shortened a steering column tube? Can I simply cut 3” off remove the shift lever and reinstall the bearing and seal? I’m going to install a floor shifter so don’t need the column shifter. I wouldn’t even mind the column shifter although it would an absolute nightmare to make work.
    Dan
    Tow Truck Tom likes this.
  3. gene-koning
    gene-koning
    Dan,
    I owned and built stock bodied Mopar dirt track cars for years. I've probably done any modification to most any part of the car you can imagine, and probably many parts you can't imagine.
    The steering column on your A body is a 3/4" two piece shaft with the "collapsible" section (I don't remember what year the collapsible was introduced, before that would have been a one piece shaft and non collapsible outer tube) carefully mounted inside the outer tube (with a collapsible section) with an upper bearing (or bushing) and a lower bearing (or bushing). Mopar used the outer tube to mount the column into the car, and to hold things like the turn signal switch and a bunch more stuff as the years added on.
    On our dirt track cars, we eliminated the outer tube most of the time. The 3/4" shaft needs to be supported at the top of the shaft, and at the floor level. The 3/4" shaft can be shortened (or lengthened) as needed, there are companies that specialize in steering U joints and couplers and anything else needed to safely accomplish this task. Borgeson (I'm sure that is incorrectly spelled) was the 1st company creating the steering shaft parts and is likely the most expensive, Flaming River is another, there are several.
    On a street driven ride, I would not eliminate the outer tube, but the bottom bearing can be relocated farther up inside of the tube and the excess tube can be cut off. There may be modifications that may need to be done so the bearing fits correctly into the tube (its been a long time since the A body cars, and there were a few changes through the years).
    I don't know your skill level nor what equipment you have, and I understand tight budgets, but, the factory location of the bottom steering column mounting point can probably be modified by enlisting some of the steering shaft u joints and other parts. Moving the bottom of the steering column an inch or two may change the exhaust picture completely. That may require making a new bottom bearing mounting point on the floor and the addition of a couple U joints. Done correctly, the steering column shaft does not wobble as it turns, if it wobbles, its not correct and needs to be corrected. I need to warn you that the rubber piece sandwiched into your steering column joint is NOT intended to be used as a U joint, it is simply to reduce vibrations in the steering column. If its used as a U joint, it may fail pretty quickly, and then you loose the steering.
    I have relocated the bottom steering column mounting point on several street driven vehicles (including both of my current modified street driven vehicles). On your early A body, you may have to modify the upper column mount so the shaft angle can change a bit, as needed. The newer A body upper column mounts have some factory built in angle adjust ability.
    I like to see at least 1/4" of clearance all around the entire length of steering shaft rotating components at all times, as the shaft rotates.
    With specific pictures and questions concerning your car, I can help guide you if you wish to venture into the bottom mount relocation. Just remember, my knowledge exists from years of experience dating back into the early 1970s, it just has to be aligned with what you are dealing with now.
  4. Sharpone
    Sharpone
    Thanks Gene,
    I’ll get out in the shop later today. I’ll get better pictures of the tube, shift lever and coupling. I sure would appreciate guidance on my project. Mopars are new to me and am learning as I go. I have fair to good fabrication skills and I’m not afraid to tackle almost anything. I do like to know the pros and cons of my modifications especially anything in regards to safety. That is Steering, Suspension and braking I definitely want right.
    Dan
    Tow Truck Tom and RodStRace like this.
  5. Budget36
    Budget36
    If the plan is to make a set next year, to match what you want to make fit.
    Why not modify them as-is, run them and just keep the hood down for the time being.
    bchctybob and Sharpone like this.
  6. Sharpone
    Sharpone
    @gene-koning @RodStRace
    The engine mount is about 3/4” up on drivers side. If I cut the column tube back at the yellow mark that will clear. If I replace the coupling (marked X) with a u joint that has a OD of 1.225 I think it will clear. The coupling is 2” at the widest point and 1.375 at the narrowest point. I can’t move the steering column at the dash without cutting up the dash which I don’t want to do.I could maybe move the column 1/4” at the floor. I will remove the steering shaft and column set the engine all the way down and take Some measurements . I know where the shaft sits so I’ll know if using a u joint will give me the needed clearance. thank you for the help.
    Dan
    IMG_3417.jpeg IMG_3418.jpeg IMG_3412.jpeg IMG_3414.jpeg IMG_3416.jpeg IMG_3415.jpeg
    bchctybob and Tow Truck Tom like this.
  7. gene-koning
    gene-koning
    The fourth picture, if you did a floor shift, you could cut the outer housing at, or even above the floor pan and move the bottom bearing up to that point. You will probably have to cut the steering column above the shift lever on the shaft. With the steering shaft in the column cut, you can install a weld on, or pinned U joint (with column end being round 3/4", or whatever your shaft measures) onto the shaft at the bottom of the freshly cut column. Point the steering shaft towards the left side inner fender (you will probably need to buy a short piece of Double "D" (DD) steering shaft and another U joint), you can buy U joints with one or both ends DD, and something different on the other end of the U joint). A steering shaft bearing mount for the extra shaft might be a needed item to stabilize the short shaft. Then you should be able to connect the end of the DD shaft to another U joint, to replace the piece on the steering box. That piece is held in place by a hollow pin, drive it out, pry the coupler off the steering box, get a spline count and diameter for the short shaft out of the steering box. The U joint for that place will have one side to match the size and spline count of the steering box shaft, and the other side of the U joint will have the DD end on it. You will likely be able to move the steering shaft out of the way to clear the manifold, the limiting factors will be the angles the U joints can operate within. With 3 joints, a shaft bearing mount, and a 12" length of DD shaft, it is not a cheep modification, but less then a set of headers.
    You can cut up a 3/4" round wood dowel from a lumber company to see how much clearance you can get before you cut anything up.
    You may be able to improve the U joint angles if you can shim two of the 3 bolts holding the steering box in place with a washer or two between the box and the K member. An 1/8" change at the K member makes a pretty big difference 8" away from where the steering column connects.
    It does look pretty tight at the dash piece. Modifying the bracket to lower the column might gain you a bit of angle change, but that would also lower the steering wheel in the car. If I remember correctly, the steering wheel sits pretty low to begin with.
    I think you should be able to gain what you need with the bottom end of the column.
  8. Sharpone
    Sharpone
    Thanks Gene, I’m going to pull the steering column and cut the tube and go from there. I can’t get the coupling to budge from the steering box. My son will help me later tonight or tomorrow. We have some very good farm and ranch stores that may have the needed u joints and D shafting I’ll look tomorrow.
    Thanks again
    Dan
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    this might sound stupid but can you have manifolds machined on the face that goes to the heads maybe 1/4" or more ? is there room for them to be closer to the engine??
  10. Sharpone
    Sharpone
    Good question but no because a couple spots on cylinders 1 & 7 flange is only 1/4” and removing would make an awfully narrow sealing surface. I’ve thought about making a taper shim to place between the manifold and head but that would require spot facing the bolt area. Machine shop rates would make it pricey to make the tapered shim and spot facing. Dang I retired to early, sure miss the machine shop. My photo ****s but it shows the thickness 7-3/4 to 8
    Dumb question can I use a straight coupling / basically a piece of tubing instead of a u joint if everything is lined up in other words in a perfectly straight line?
    Thanks
    Dan
  11. X-cpe
    X-cpe
    Borgeson shows a bunch of them.
    Sharpone and Tow Truck Tom like this.
  12. Sharpone
    Sharpone
    Actually my shim drawing is b*** ackwards the thick side should be on top
    Dan
  13. Sharpone
    Sharpone
    Edited drawing
  14. Sharpone
    Sharpone
    Thanks I’ll get on their site and look around.
    Dan
  15. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Great that @gene-koning can spell out the needed info.
    The thing I wish to add is only that you did right with lighting and capturing the parts.
    Thank You
    Sharpone likes this.
  16. Uncle Lee
    Uncle Lee
    I Ospho headers, then after they set overnight, I cook them with my torch. Makes it where the paint don’t pop off first time it warms up.
  17. gene-koning
    gene-koning
    Indeed, the very clear pictures made it easy to grasp what the challenges are.
    The shaft that comes out of the steering box has splines. You can use a straight coupling if it has the correct splines to mate with the steering box. I'm not sure coming straight off the steering box is going to help you much, unless you can shift the angle at which the steering box is bolted to the K member.
    Those couplings on the steering box don't like to come off easily. Make sure the end of the shaft is really clean, and the whole thing is well lubed. Then, its still a battle, be careful about wedging things between the coupler and the end of the box where the shaft p***es through.
    brad2v and Sharpone like this.
  18. gene-koning
    gene-koning
    After you cook the headers with your torch, do they still give a nasty smell when they get hot again? My main concern is with toxic fumes in a confined area. Under the hood of that early A body Mopar is very small.
    Sharpone and gimpyshotrods like this.
  19. Sharpone
    Sharpone
    IMG_3426.jpeg IMG_3428.jpeg IMG_3429.jpeg IMG_3430.jpeg I removed the steering shaft and column with my son Nics’s help it was a bear. Sprayed it down with Kroil yesterday and again today. We used a piece of 3/8 plate against the steering box and a BFPB once in started moving it went fairly easy. I have the engine shimmed up 3/8” on drivers side and pushed as far to p***enger side as the mounts allowed. Tomorrow I’ll install the transmission and reinstall the eng/trans to make sure it will work.
    The nub on the manifold is deceiving it’s about an inch and a half above the steering shaft. Really wish that was where the interference was as I could grind it off.
  20. Sharpone
    Sharpone
    I’ll also investigate the steering box mount, maybe I can tilt down and then ***emble per your drawing @gene-koning .
    Dan
  21. RodStRace
    RodStRace
    @Sharpone I'll also give you kudos for good pictures.
    Try to consider that once you get all the parts to fit and not try to occupy the same space, you want to also keep heat under control. The steering damper can't handle much, so a replacement joint is important. The inner and outer column is going to get hot, so try to shield/cool this. Next is the master cylinder and lines. Again, shielding and airflow should be part of the plan. If driven over an hour on the road, the firewall and floorboards can get toasty.
  22. Sharpone
    Sharpone
    Point well taken
    Actually I think the Master cylinder and brake lines will have decent distance from the exhaust and installing heat shields should be easy. We will see how everything goes together.
    Dan
  23. gene-koning
    gene-koning
    Picture 4: If you can point the shaft on the steering box down and towards the left in reference to this picture (by shimming the steering box mounts), you should have more clearance between the manifold and the steering shaft. Its hard to tell how much clearance will exist from a picture (which are great, by the way), but even gaining another 1/8" of air gap helps a lot. It appears that maybe a straight coupler with splines on one end would clear the manifold, and heat wouldn't have much effect on a straight coupler.
    Gaining extra clearance was also the reason I would put a U joint on the steering box, it would allow the shaft to be moved even more towards the lower left side (based on the 4th picture). The only issue then is you need another U joint to turn the shaft back towards the column, and you would need to support the modified steering shaft neat that 2nd U joint. Then you would need that 3rd U joint to align the new modified angle of the steering shaft to the column shaft.
    I think you are on the right path. There are times when a lot of compromises are needed to fit everything into place, sometimes, you even get to choose what areas get compromised.
    We installed a modern Hemi into a 57 Dodge with the factory power steering (it is a monster sized unit installed from INSIDE of the car), to make it work without a huge undertaking, the Hemi does not sit level from side to side. One side is about 3 degrees higher then the other side. We know it, but someone would have to look pretty hard to see it. Its been operating like that for 12 years and thousands of miles now. The lesson learned? Perfection is a figment of someone's mind, but not an absolute requirement in the real world.
  24. Sharpone
    Sharpone
    Thanks all for compliments on my photography.
    My engine is higher on drivers side haven’t measured it yet, I can’t see how a few degrees will hurt anything. Hell I’ve been a quarter bubble off for years and I’m fine at least I think I’m fine ha ha. I have to finish some yard work then back in the garage.
    Dan
    bchctybob and gene-koning like this.
  25. Sharpone
    Sharpone
    Well on to plan C
    I installed the transmission, shimmed the drivers side mount 3/8” pushed the engine to the p***enger side as far as I could, still not enough clearance. The transmission tail sits a little lower than I guesstimated causing interference even if I used a straight coupling. I looked at tilting the steering box down but would require re drilling a hole at minimum. Then I would need three u joints and a bearing mount etc per Genes drawing.
    Plan C
    I’m using a p***engers side header flange and am fabricating a manifold.
    Pictures to follow.
    Dan
  26. squirrel
    bchctybob, Sharpone and Moriarity like this.
  27. Sharpone
    Sharpone
    I have. A few things about them. One I believe the port size is 1.14 x 1.59 my stock 318 manifolds are 1.125x 1.75, they are expensive, although I found one in a junk yard in Pennsylvania for $140 plus shipping, from the picture it looks pretty Rusty. I also believe the drivers side 273 manifold for early a bodies is pretty restrictive due to small port and curves. I tried to make a ‘92 RT Dakota manifold work, considered by many to be the best SBM factory manifold as it has 2-1/8” outlet. Some people have had luck, I followed info on A-bodies only forums. I might have enough tolerance error stack to keep it from working , rereading, many grind on the manifold and steering coupling which is not acceptable for me. Actually the guy I bought the RT manifold from told me that making one work is iffy.
    At present I’m just running a 318 with 4 bbl and manifold. I’ll add a cam later so I don’t want to much restriction. My understanding is to not have an exhaust with smaller ports than the head. Is my thinking correct? IMG_3408.png
    Thanks
    Dan
  28. squirrel
    There's a tradeoff, getting a manifold to fit might be more useful than having a manifold that doesn't fit but has bigger ports.
    Have you looked at the port size on the 360 manfolds? I expect they're probably harder to find than the 318, though.
    I bought a pair of 340 manifolds at a Chevy swap meet in the early 90s for $100 iirc, I guess they're worth more than that today. This was my wife's car for many years. The third engine it had.
  29. Moriarity
    Moriarity
    SUPER MODERATOR
    you could always get a manifold that fits and then port match it to the head with a die grinder....even without port matching, there won't be any difference that you will notice on a street driven car
    Sharpone and firstinsteele like this.
  30. Sharpone
    Sharpone
    Is that an early a body?
