Technical The upholstery thread to end all threads
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 5, 2021.
  1. F-head
    F-head
    The cotton if stuffed correctly will make a very full rounded looking pleat
    I always use 1/2” scrim foam and I don’t glue the vinyl to the scrim
    I just sew it
    Wider pleats come out a little flat though
    Here’s some of the tuck pleated panels that are in my coupe 116B85EF-453C-4193-A4F8-981B50158F63.jpeg IMG_5576.jpeg
  2. gassersteve
    gassersteve
    im cutting on the black line and sewing the yellow. 2 1/2" wide pleat to start. finishing with 2" wide after sewn back together.
    f-head, the material shop i have been visiting said the 1/4" scrim is for the door panels and the 1/2" is for seats. 1/4" so the door handles clear
    Okie Pete likes this.
  3. F-head
    F-head
    I still use 1/2” scrim on the door panels
    Haven’t had any problem on handle clearance
    1/4” just looks too flat to me
    3quarter32 likes this.
  4. gassersteve
    gassersteve
    ill give the 1/2" a try for the door panel if the cotton does not work out. im interested to see how the cotton stayes inside the pleats when I cut for the handles to attach
  5. gassersteve
    gassersteve
    why does the thread seem to split as it's going through the needle into the fabric?
  6. F-head
    F-head
    Needle might be worn out
    The thread can wear the hole in the needle causing part of the thread to catch on the needle
    Otherwise don’t know
    gassersteve likes this.
  7. gassersteve
    gassersteve
    I tried to get fancy with a French seam. this is how it turned out.
    Squablow, Okie Pete and Dick Stevens like this.
  8. jakesbackyard
    jakesbackyard
    from ND
  9. jakesbackyard
    jakesbackyard
    from ND
    Okie Pete and 6inarow like this.
  10. gassersteve
    gassersteve
    I found some youtube videos by the lucky needle. seems pretty informative. I saw the way he is doing tuck and roll so im going to try it his way. he gives all the measurements to use also
  11. lostone
    lostone
    from kansas
  12. jakesbackyard
    jakesbackyard
    from ND
  13. RICH B
    RICH B
    Wondering if anyone that has switched to a servo motor drive would compare the feel and controllability as compared to a regular clutch. I'm asking because of ankle problems and general loss of feel to "feather" speed.
  14. Dick Stevens
    Dick Stevens
  15. RICH B
    RICH B
    Upholstery Social Forum is the second to the last under the "art" category.
  16. K13
    K13
    You have to be signed up to a social goup to access it. The links work if you are a member of that group.
  17. F-head
    F-head
    I put a servo motor on my Consew
    I love it
    So controllable, and I can drive along in granny gear
  18. RICH B
    RICH B
    If you click on the little square thing on the far right by "private" ; it should ask you to join group.
    But; yeah, the social groups don't seem to be used much. Lot of good info in the upholstery group.
  19. RICH B
    RICH B
    That sounds promising. I noticed the links in social forum to the "good" conversion kits seem to go to out of stock or error pages.
    Anyone have any advise on something to purchase.
    There is a Consew unit on Amazon; twice as much as the weird Chinese branded things; but looks like a better idea.
  20. F-head
    F-head
    I think my servo motor and speed control setup was under 200$ on evilbay.
  21. Dick Stevens
    Dick Stevens
    When I move the cursor over the little square it reads "RSS" and when I click on it it says
    "<errors>
    <error>
    <![CDATA[ The requested page is unrepresentable as RSS. ]]>
    </error>
    </errors>"
    I give up trying anymore :(
  22. RICH B
    RICH B
    Maybe try this; I just joined several with no problem (other than spending time reading a bunch of interesting posts).
    Here is a sample of how one join-up went.
    Go to Social Forums.
    Click on the main category; like "CUSTOMS"
    Click on the group; like like "MOONGLOW"
    Click on "social forum tools"
    Click on "join social forum"
    And you should end up in the posts.
  23. K13
    K13
    I wonder if it's just that particular model no longer made as it was years ago that I bought mine. Reliable still makes servo replacement motors that are inexpensive.
    https://reliablecorporation.com/products/sewquiet-6050sm-220v-servomotor?currency=USD&variant=30732326470&utm_source=google&utm_medium=cpc&utm_campaign=Google Shopping&stkn=d4fbd6cbae1e&cmp_id=210679989
  24. Dick Stevens
    Dick Stevens
    I appreciate all that you have posted trying to get me where I can join the group, but it just doesn't work for me and I have given up on making any further attempts.
  25. RICH B
    RICH B
  26. Squablow
    Squablow
    I put one on my Consew because the old clutch motor was too fast, it was set up for sewing sails for boats. I had to redrill my table to mount it but otherwise it went on fine, but even at the slowest setting on the dial, I still felt like it was a little fast. So I bought the smallest pulley I could find that would fit the motor, to slow it down even more.
    I've seen kits that have like an idler pulley with two different diameters, that slows it even more, and then there's two belts between the motor and machine instead of 1. If a guy had the money to spend, I think that'd be the way to go, along with the servo motor. You can always crank the speed up if it's too slow, but I never felt like it was.
    The motor setup I bought was the
    Consew CSM550-1 Sewing Machine Servo Motor
    Bought it off of eBay new, was about $163 all-in. (looks like they're about $200 now)
    More practice is likely needed by me more than an even slower motor setup. But the servo does make it nicer to work with.
    RICH B likes this.
  27. There are a few ways to do tuck and roll. I am learning the stuffed style and pleated then fold and sow. Here are how different styles I am learning
    gassersteve and GuyW like this.
  28. gassersteve
    gassersteve
    if I could get thise reverse to stop fraying the thread i will be trying the fold and sew method also
  29. gassersteve
    gassersteve
    I had the needle inserted 180° off. I spun it around and rethreaded it and I got reverse again without fraying the thread.
    I feel I got to know how the knobs and dials effect the outcome. I think the s***ch length is good and bobbin tension as well as the top thread tension is set.
    go one way and see the results. go the other way and see what it does. I counted the number of clicks for the s***ch length and went for the middle
  30. jakesbackyard
    jakesbackyard
    from ND
    Door panels I just finished for the ‘57 Ford Courier wagon I did the seats for a while back.
    Johnboy34, 6inarow, Okie Pete and 6 others like this.
