History jalopy fuel tank capacity
Discussion in 'The Hokey Ass Message Board' started by s.e.charles, Aug 12, 2025.
  1. s.e.charles
    s.e.charles
    anyone know how much a jalopy fuel tank holds?
    based on the ***umption the stock fuel tank of the '32-'40 tanks were located in the vulnerable rear of the rear axle, and rules either mandated or suggested, the fuel tank be moved to a more amidship location and possible the real estate less due to roll cage bracing and perhaps a relocated battery, too.
    i know there would be pit stops along the race for anything of interesting duration, but how much would the driver have to start the race?
    thanks
    sid
  2. Hollywood-East
    Hollywood-East
    How much to roof my shop?
    A pic. Is worth a ...
  3. s.e.charles
    s.e.charles
    well fer cryin' out loud!
    if i could walk that way, i wouldn't need the tal*** powder, now, would i?
    spudshaft likes this.
  4. greybeard360
    greybeard360
    Is it a 1 gallon tank or 5 gallon?
    What kind of tank is it?
    Kind of a dumb question if you ask me.
  5. s.e.charles
    s.e.charles
    if i knew what it was, i would need to ask.
    didn't you learn there are no dumb questions? just dumb . . . never mind.
    but if i were not this dumb, you just might not look that smart.
    but as long as you have the cl***'s attention, perhaps you would like to demonstrate you arithmetic prowess.
    if i have a cylindrical tank , the dimensions being 10" diameter, 20" long, and filled 100% full with [in this case gasoline] how much gasoline would it hold.
    don't know how much mileage a roundy round race car would get, but let's say 5 miles per gallon. how many laps could it make before pitting for gas?
    thanks in advance,
    sid
  6. ClarkH
    ClarkH
    The cylinder you describe (10" diameter, 20" long) would hold 6.8 gallons, according to this online Tank Volume Calculator.
  7. A 2 B
    A 2 B
    from SW Ontario
    Aproximately 6.75 gal. fuel capacity, depending on manufacturer.
    s.e.charles likes this.
  8. s.e.charles
    s.e.charles
    thanks. so would that be a practical volume of gas for a race car to hold?
  9. Dave G in Gansevoort
    from Upstate NY
    When I was a child attending the races at Lebanon Valley Speedway, in the era when racing of this sort was transitioning from flatheads to overheads, the norm was to use beer kegs, 15 gallon size. Mounted in the trunk above the frame rails tucked between the rear rollcage braces, ***umed to be adequately protected. Yes there were fires! My friend Jim spent 6 months in a burn ward after one such incident midsummer 1962. Usually the keg mostly survived, but what seemed to be the weak spot was the filler, somehow attached to the keg at the bung hole. Most likely it would have been just a short section of pipe sized to fit the hole, with a coupling screwed to it, and a plug with a piece of rebar welded or brazed, depending on the pipe plug material, to form a handle. And then just hammered into the bung hole. Not many people could weld on aluminum, and those seem to have been used the most.
  10. s.e.charles
    s.e.charles
    that's terrible. i've been watching tons of YT videos of old stockers and every driver interviewed after a crash mentions how lucky he was to get out because either fire did not happen, or it just licked his heels as he fell out of the car.
    even the announcers mention the F word as the crashes happen. scary stuff, that.
  11. s.e.charles
    s.e.charles
    thank you. more helpful details in that explanation than you realize.
    appreciate the response.
    sid
  12. Dave G in Gansevoort
    from Upstate NY
    Late 60s and the first car I had, I bought (and mom was NOT happy) while in high school, sophomore year. It was a 57 Chevy and had a keg in it made that way. Bought a rougher one for the parts, 55 Ford, same thing. The first 3 cars I helped on, same thing. Fuel cells were not required until mid 70s. And even then the rules allowed things called fuel cells that had no outer metal containers. I used a 40 gallon sprint car tail tank, made of HDPE and no inner bladder in my modified. And it was held in with railroad banding fastened in with homemade turnbuckles. It never came loose, so I guess we just got lucky.
  13. s.e.charles
    s.e.charles
    i'mma gonna believe you didn't fill it to the top. if you did, please don't tell me so . . . .
    Dave G in Gansevoort likes this.
  14. 5window
    5window
    A 40 gallon tank would hold over 250 pounds of gasoline. Did you really want that much weight in your car?
  15. Dave G in Gansevoort
    from Upstate NY
    Well, we ran methanol, roughly 6-3/4 pounds per gallon. So approximately 270 pounds hung over and behind the rear axle. No, not the best place for that much weight. But being a sprint car tail tank, it kept a considerable amount behind and below the rear axle. The trick was to try to set the car up for the end of the race, if we could guess what the track was going to be like. And we tried to fill it up with as much fuel as we could squeeze in it. The night I had 5 gallons of nitro, the rest methanol, gave us about a 12% nitro blend. Our little injected 350 gained 100-120 hp that night. And ran through the fuel in 33 laps of the 35 lap feature! Led 94% of the race, just not the most important part…
    But to say that it had 40 gallons, no, probably only 39+. May have had a little bit of an air gap on top. I can’t imagine what a dirt champ car with a 65 gallon tank must handle like at the start of a 100 lapper on a mile track!
  16. s.e.charles
    s.e.charles
    jeebus. may as well just light the fuse and get it over quick.
    nitro + methane + gasoline . . . ka-pow!
  17. Dave G in Gansevoort
    from Upstate NY
    No gasoline except for starting cold. Then it’s just a squirt down each injector.
    Probably why the filters were off here.
    WC145 and s.e.charles like this.
  18. s.e.charles
    s.e.charles
    oh . . . so the methanol was the majority of the mix.
    hell; i still wouldn't want to be sittin' on top of the mix.
  19. Mr48chev
    On most dirt tracks what you are calling Jalopies the heat races or main weren't that many laps. At least not in Central Texas in the 70's. You just needed a tank that held enough to finish the longest racee you figured to run in.
    lothiandon1940 and s.e.charles like this.
  20. dana barlow
    dana barlow
    from Miami Fla.
    For most oval track racing,between 5 to 10 gal. was enough=tanks were used,before fuel cells,that were often 5 gal jerry cans{ WW2 left over stuff was every were,and Jerry cans were tuff,so pretty safe at the time;; If got the "Q" wrong,I also got "A"...
    I'm old an raced before fuelcells were in the rules..
  21. Dave G in Gansevoort
    from Upstate NY
    Most of the time it was straight methanol. The nitro was given to me by a friend from the Berkshires who raced a funny car in the late 60s and 70s. He ran a speed shop and I was a customer there from the time I was 15. I also raced modified cl*** snowmobiles, with Ed Wynn Tillotsen carburetors set up for methanol. Try starting a Rotax Blizzard engine on methanol in the winter!
    Anyway, the drag racer knew that I bought methanol by the 55 gallon drum, and asked me if I would sell him 5 gallons occasionally. Instead I just gave it to him. There was always a bit more than I could use in the snowmobile days. And in the long term, it paid off with dividends! One benefit being that 5 gallon can of nitro. I was also getting parts from him for cost.
    Funny thing about methanol, it’s not explosive like gasoline. And water soluble, so to put it out in a fire, just use water. It doesn’t take much to make it non combustible. Add the nitro, 12% back then in the modified, and it adds about 100 hp.
    4th of July one year, the Valley always has fireworks. We had a 55 gallon drum on the back of our truck. West end of the pits by the pond. Fireworks are pretty much always fired off just behind the dirt track on the dragstip. The pits concession stand and the gasoline truck are central in the infield, close to the fireworks. And most of the people in the pits were not going to get anywhere near our dangerous “FUEL”! But they stood there next to the gasoline truck! There wasn’t enough firefighting equipment anywhere around the track if that had gone off! Go figure…
  22. s.e.charles
    s.e.charles
    i find that amazing. really gives the methanol some "ooomph!" - eh?
    thanks for 'splaining.
    sid
  23. Dave G in Gansevoort
    from Upstate NY
    Why, yes it does! I’ve only used small percentages, but someone like Marty Strode, who’s used BIG percentages, can tell you a lot more about the effects and how to not waste an engine or 3.
  24. It all deepens Langhorne PA was a one Mile dirt oval until 1965 when it was paved. The track on the New York State Fairgrounds (the Moody Mile) was a one mile dirt oval both held major stock car races.
    The Moody Mile hosted stock car races from the 1950s until 2015.
    Langhorne National Open was a 100 lapper for NASCAR Modified/Sportsman from the 1950s to the tracks closing in 1972
    The New York State Fair race stayed flathead 6cylinder until 1966!
    From the 1966 race-
    Ray Kennedy's Stovebolt (261) powered Pontiac coupe. Winner of the 1966 New York state fair race (One mile dirt oval) with Larry Nye driving.
    upload_2025-8-14_18-35-33.png upload_2025-8-14_18-35-55.png upload_2025-8-14_18-37-47.png
    The track on the NYS fairgrounds was destroyed in 2015 for a bigger Mid-Way and a parking lot!
    I am just as angry and bitter today as when the announcement was first made by New State!
  25. As far as big tracks there was also Trenton NJ...
    Fuel capacities were enlarge for these races, sometimes with catastrophic results!
    The infamous 1951 Langhorne Fire-
    For the 1964 Salt City (not State Fair race) at Syracuse a 55 gallon drum chained in the car. Which made Wimble nervous so he practiced escaping from the car which was a good thing!
    Bill Wimble fire:
    Salt City race, 1964.
    upload_2025-8-14_19-29-8.png upload_2025-8-14_19-29-34.png upload_2025-8-14_19-30-6.png upload_2025-8-14_19-30-39.png upload_2025-8-14_19-32-28.png
    "Wild" Bill Slater's 1964 fire at Trenton.
    jet996 and s.e.charles like this.
  26. gene-koning
    gene-koning
    I ran an old VW bug gas tank in most of my dirt track hobby cl*** cars. It was 13 gallons, one of my sponsors was a local gas station, we got $25 worth of gas and supplies every week we raced. We had to pack the track (1/2 mile dirt), ran a few hot laps after that, then a couple laps doing time trials. The heat race was 10 laps, the feature was 20 laps, we average using 5-6 gallons of gas in the car every race night, we would fill up the truck that pulled the open car trailer, and get a bag of ice for the cooler with that $25. The good old days, mid - late 70s & most of the 80s.
    That was before fuel cells at our track, most of the drivers were more worried about getting burned then getting hurt. By that time frame, most of the gas tanks were pretty well protected.
  27. s.e.charles
    s.e.charles
    now These guys are coping me!
  28. s.e.charles
    s.e.charles
    the likes are not for the fires, but for taking the interest to share the photos.
    fifty-five gallon drum ..... whew
  29. Part of the reason Wimble was nervous was because he was one of the five men who pulled Marvin Panch form the burning 427 Ford powered Maserati he crashed at Daytona in 1963!
    The names are not in order with the photo-
    Ernest E. Gahan, William R. Wimble, DeWayne L. Lund, Stephen E. Petrasek, and Jerry A. Raborn
    Bill Wimble 2nd from left-
  30. dirt car
    dirt car
    from nebraska
    I believe that is Tiny Lund on the far right .
