Technical Ford steering wheel to shaft taper?
Discussion in 'The Hokey Ass Message Board' started by ActionYobbo, Aug 12, 2025.
  1. ActionYobbo
    ActionYobbo
    I got a fancy ford 39 banjo wheel to go on my 39 ford truck buy it won’t fit. The taper is different. It goes on halfway and has a lot of movement. I have the steering wheel that came off the truck and another truck steering wheel I got of eBay that both fit but this car steering wheel has a different taper.
    I want to make this banjo wheel fit do I need to find the correct taper for I can get a reamer.
  2. 19Eddy30
    19Eddy30
    from VA
    Splined taper or
    Taper with Key way ?
    It taper & key way , with out us seeing pic & there is enough material, taper steering wheel same taper of column shaft & file in the key way with mini files or jewelry files
  3. Doublepumper
    Doublepumper
    from OR-WA, USA
    I seem to recall (or not), that the taper is the same as a tie rod end, at seven degrees. If there's enough meat in the hub to ream it, that should work.
  4. 31Apickup
    31Apickup
    If it’s a big truck, the shaft is bigger, if it’s a pickup the shaft and taper is the same as a p***enger car.
  5. ActionYobbo
    ActionYobbo
    yep I have a truck and I am trying to fit a car steering wheel.
  6. tubman
    tubman
    What's chances that nice banjo wheel isn't from a Ford? Other makes had 'em too. But I agree that here should be enough meat to ream it out.
  7. ActionYobbo
    ActionYobbo
    It looks like a ford wheel. There is a name on the back of the finger grooves. Best I can make out is sheller or sneller. The second letter is damaged. There is plenty there to ream out. But what size & taper?
  8. tubman
    tubman
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Have that but prefer this for a situation like this thread. IMG_4539.jpeg It also fits the hub bore. ;)
  10. ActionYobbo
    ActionYobbo
    would I have to pull the steering shaft out to use that?
