Projects 61 F100
Discussion in 'The Hokey Ass Message Board' started by LeoSmalls, Aug 11, 2025.
  1. LeoSmalls
    LeoSmalls
    I never posted any kind of build thread so I might as well post an update, as much for the common interest, as in an effort to re-spark some interest from me in the stalled project.
    A couple of years ago I picked up a couple of F100s a 61 with a 223 and a 64 with a 292. The 292 was locked up (hood up, no air cleaner for years) and believe it or not it was in worse shape, rust through the roof, drip rails, etc so I sold it to help offset costs on the 61.
    As found, it was last tagged in '98 and had been sitting there since.
    IMG_3013.jpg IMG_3008.jpg IMG_3011.jpg IMG_3010.jpg PXL_20220912_221145482.jpg IMG_6083.JPG PXL_20220912_221154250.jpg PXL_20220912_221145482.jpg
    Chief 64, RMR&C, jaracer and 6 others like this.
  2. you’re killin me smalls.
  3. LeoSmalls
    LeoSmalls
    Now in hindsight, I should have put a better plan together and prioritized work based on getting the thing rolling under its own power, but I wanted to see changes and do fun stuff so I kind of just took a shotgun approach.
    I started off taking the bed rack off of it and just in general cleaning out the years of dirt and debris. PXL_20230116_222035220.jpg PXL_20230116_222017407.jpg PXL_20230116_222000790.jpg
    The previous owner told me first gear was out of the 3 speed, so I opened it up and it was pretty nasty, looked like it had been run dry and got hot. I cleaned it up, washed it out, new seals and gaskets and a fresh speedo gear. Then resurfaced flywheel and new clutch.
    Had Nastalgia Sid drop my axle and put new bushings, Posies, and shocks all around to try and help the stance.
    dwollam, Chief 64, Toms Dogs and 4 others like this.
  4. patsurf
    patsurf
    time for an fe----figured i'd go first.....
    LeoSmalls likes this.
  5. LeoSmalls
    LeoSmalls
    Put in a new Dual pot master, I think for a '68 mustang? New steel lines and brakes all around.
    Started playing with wiring and most of it worked! Lights, wipers, even the blower for the heater.
    At some point in here I picked up a set of TT knock offs and I think it helped the look.
  6. And the paint is perfect
    Lucky
  7. LeoSmalls
    LeoSmalls
    Now is where I started to stall.......rust. I have ZERO body experience. Both pans and cab braces are shot, it needs cab corners, and the bed steps and the bottom 6" of the rear fenders. The tailgate looks like it has a had a telephone pole dropped on it, picked up a suitable replacement while on the hunt for the bed steps. Then the usual stuff, the seat is on bad shape, window seals are all cracked and half gone, fuel tank clips, fuel tank and I'm sure a few things I'm forgetting.
    I picked up a rear leather seat from an off topic super duty pickup that actually looks ok (and has cupholder). Picked up a new tank and sender, window seals and other parts I could source that I new I would need to make it drive able.
    But I stalled on the floors. I don't have any idea what I am doing so after I cut the driver's side out, then kept removing metal until I found something solid, I realized I was going to have to build patches without a reference as most of what was gone is what the cab mounts weld to. Needless to say after fighting it for a while and getting frustrated more than I should I haven't touched it for a few months. PXL_20240303_231817964.jpg PXL_20240303_231758708.jpg PXL_20250224_024008261.jpg PXL_20250302_231732128.jpg
    My short term plan was to get the floors done and save the cab corners and whatnot for the future, just get it safe to drive. But now I'm just trying to figure out where to head with it.
    dwollam, Toms Dogs and chryslerfan55 like this.
  8. LeoSmalls
    LeoSmalls
    Well the 223 runs, but I also have a couple of 292s on a shelf that I could probably build one of them if I needed to.
    More power would be great, but I'd like to just be able to cruise.
    dwollam and chryslerfan55 like this.
  9. LeoSmalls
    LeoSmalls
    Some of it has cleaned up ok. Left vs right PXL_20231028_224916687.jpg Screenshot_20250811-211118.png
  10. patsurf
    patsurf
    LeoSmalls and chryslerfan55 like this.
  11. LeoSmalls
    LeoSmalls
    From those that have been here with a project beyond their ability to do "right", would it be crazy to just patch the cab/inner fender and get the cab mounts and floors in? For what this truck will be can I get away with lap welding the pans in?
    I know there is a better way, and aside from just the skill, it would require tearing into the rockers and steps as well. But I don't imagine this will ever be a complete resto job. If I'm being honest I imagine getting it rolling and cruising, and just enjoying it until I can save/sell it to get into something more solid in the future.
    I fell bad for a half ***ed approach, but chasing perfection could add years.
    dwollam and Toms Dogs like this.
  12. Budget36
    Budget36
    Lap weld them and lay a mat on the floors.
    LeoSmalls and Chief 64 like this.
  13. patsurf
    patsurf
    and following in this vein-just spray under coating on the bottom! (if you do)
  14. Toms Dogs
    Toms Dogs
    from NJ
  15. Turns
    Turns
    I prefer to **** weld sheet metal however floor pans are fine to be lapped. Once you have seam sealer over the join and some stone guard the repair is quite presentable.
    dwollam, LeoSmalls and Chief 64 like this.
  16. finn
    finn
    Don’t fret about **** vs lap until you buy the panels and see what’s involved to fit them. Once they’re in hand you’ll figure out your skill development path. For a first project you’ll probably be lap welding. Nothing to be ashamed of, and it can always be redone ten years from now.
    complete pans / floors for the entire cab are available now, albiet pricey.
  17. dosrancheros
    dosrancheros
    I would just do whatever it takes to get it on the road quickly so you can enjoy it and do cool stuff with your brother...***uming you have a brother.
    dwollam, RMR&C and LeoSmalls like this.
  18. LeoSmalls
    LeoSmalls
    Says my literal brother.
  19. LeoSmalls
    LeoSmalls
    I have pans and braces from Carolina Cl***ics, on loose fitment they seem like a pretty good fit.
  20. LeoSmalls
    LeoSmalls
    Some more pics from the work so far
    The trans when I opened it up
    Clearance after lowering it
    Rear wheels were wider than I expected
    Toms Dogs and dwollam like this.
  21. dwollam
    dwollam
    Wheels look perfect to me!
    Dave
