Technical Wheel coming loose
Discussion in 'The Hokey Ass Message Board' started by chrisp, Aug 7, 2025.
  1. 19Eddy30
    19Eddy30
    from VA
    Some times a ""Centering register"" for wheel / Rim needs to be made,
    I.D to O.D
    Illustrious Hector likes this.
  2. Hollywood-East
    Hollywood-East
    Righty tighty, Lefty loosy..
    Remember old jeeps, An mopars had left hand threads.... Dr. Side
  3. jimmy six
    jimmy six
    These are the same Americans I bought. I started with just the conical nuts. I just didn’t think them safe as they didn’t have 1/2” of threads on the stock studs. Let’s face it they are a thicker wheel. I bought 20 Gorillas with extended threads into the wheel which also helps in centering. Much safer
  4. Boneyard51
    Boneyard51
    After looking close, it appears you need the flanged washer type lug nuts! Someone at some time put the angke lug nuts on a making what appears to be a mating surface, but I think it is just because it’s soft aluminum!
    Bones
    deathrowdave and ClayMart like this.
  5. Mr48chev
    The guys at the tire store I have gone to for the past 47 years always tells me to come in a hundred miles or so and have the lug nuts retorqued with the rigs that have alloy wheels. That is wheels I bought from them and oem wheels.
    oldiron 440 likes this.
  6. oldiron 440
    oldiron 440
    Yes but I’m talking of a different problem, if you put a standard thread nut on a metric stud it will not stay torqued no matter how many times you retorque it.
    Boneyard51 and Tickety Boo like this.
  7. twenty8
    twenty8
    By the look of the galling on the nut shown, they may have just been over-tightened until they stayed on.
  8. chrisp
    chrisp
    I did not, but will do.
    As you can see on these 2 studs they seat inside the small pocket on the hub, all seat correctly on both hubs.
    The knurled part was not protruding much compared to the shank diameter, I actually thought the knurled part was short (probably just a tad over half of the thickness of the hubs) and not very agressive. I didn't like them very much in fact.
    Wheel center bore : 83mm
    Hub : 70.6mm
    Wheel stud bore : 0.63
    I do not have mag lugs, they are 60° conical without a shank.
    The nuts fit snugly on the studs. 12mm is 0.9mm bigger than 7/16" if you engage it by hand, you will feel it rocking and know something ain't right, if you engage it with a socket you won't. If you torque it with a gun you might strip something. But I'll double check anyway, I'd rather be safe than a ****y idiot.
    Lastly ARE responded that the wheels take 60° conical nuts, I gave them the part number and date that are on the wheels, hopefully the guy checked that and didn't just gave an answer pertaining to their current production.
  9. Boneyard51
    Boneyard51
    My friend always said “ one cross thread is worth two lock washers” , maybe it will work with SAE and metric threads? :D
    Bones
  10. GlassThamesDoug
    GlassThamesDoug
    My set of Americans used the shanked ones shown here. Shop called them ET style lugs.
    anthony myrick likes this.
  11. ramblin dan
    ramblin dan
    Buddy of mine had the same issue. Found out that the shank was just long enough to bottom out on the brake drum before it was fully seated to the rim.
    down-the-road likes this.
  12. jimmy six
    jimmy six
    That’s why they all changed to conical nuts. In the beginning the washers were all 1/4” thick. As more manufacturers made wheels the washers got thinner. I expect that unknowing individuals mixed wrong parts and wheels fell off/got loose causing lawsuits….
  13. chrisp
    chrisp
    Here's ARE final answer:
    We switched over to conical seat lug nuts way before 2018, so you will need to run a 60 degree concial seat lug nut.
    The other thing to check for is the hub size on the wheel verse what the hub size is on the car, if they are not the same you will need to run a hub centric ring to center the wheel.
    That is more probably what the cause of the probably is, is that the wheel is not center and is causing the lug nuts to back out.
    This was pointed out immediately by Zuffen then confirmed by others.
    Rings are on order as well as 60°ET nuts. We'll see, I'll keep you posted.
    The rings are 2 month out so don't expect an update next week.
    Thanks to everybody.
  14. If you know someone with a lathe, the rings can be turned out in an hour or so.
    Oh, and thanks for letting us know what the wheel mfg had to say.
  15. I smell BS.... The conical lug nut answer I expected. Shank-style nuts have been gone for 20+ years with a few exceptions, primarily cast multi-fit wheels like Cragar SSs and some others. ET uni-fits used conical nuts almost from the beginning and ET licensed the design to Keystone for at least a while. Cragar tried to rip off ET and got sued for patent infringement so came up with their slotted hole design with large washers currently used.
    The hub-centric rings. Is it my imagination, or did ARE just admit their machining for the wheel patterns may be suspect? I got talked into buying exactly one set for my last X's ****box when I bought alloy wheels for it and they proved to be more trouble than they were worth. I threw them away, never had any issues. Every other set of custom or alloy OEM wheels I've ran didn't have them and I've never had this problem. But one thing I did learn is nut torque on alloy wheels is CRITICAL. If their not all dead-even, the nuts will loosen. My procedure is to snug them all up, then start the torque sequence. Always use a 'star' pattern, and repeat it at least three times or more until you feel zero nut movement before the wrench 'clicks'. Steel wheels, while they should be torqued, are much more forgiving due to the raised ring around the lug holes. These act as belleville washers, absorbing any flexing and keeping the nuts tight. Cragar now uses dished washers (with the dish turned in towards the wheel) on the SS for the same effect. Flat washers won't do this.
    Lastly, are the hub/rotor and rotor/wheel mounting faces parallel to each other? If a straight edge doesn't lay evenly across each of them, that could be the problem.
    Boneyard51, jimmy six and 19Eddy30 like this.
  16. 19Eddy30
    19Eddy30
    from VA
    If where my own car & parts ,
    I would be using shank No matter if
    was Original 60 deg & the 60 deg is not correct in wheel No longer & I did not have the tool / tooling to fix.
    In my case I have tool / tooling .
  17. Clydesdale
    Clydesdale
    Gotta agree with some comments above, I wouldn't trust what the manufacturer says unless its about a brand new product. Hell the wheels are probably older than a bunch of the staff there!!!
    Sometimes you gotta go with what you see infront of you, sure looks to me like thy need a shanked nut with a washer.
    In ARE's defence @Crazy Steve they will machine for one center bore size and recommend spigot rings to suit the application, otherwise they would need a whole range of sizes and a stock management nightmare.
  18. Clydesdale
    Clydesdale
    Also, after all these are we panicking over ONE wheel coming loose ONCE?
    OP have you put it back together and run it up the road yet?
    427 sleeper likes this.
  19. chrisp
    chrisp
    It's one wheel coming loose twice in a very short period.
    I'm waiting for the parts to put it back together.
    I do have one, rings are dirt cheap and it's a customer car, since I'm eating the cost of this debacle (I consider it's my fault for not noticing this when I did the conversion), I'd rather spend my time doing something more productive and more economically sound.
    down-the-road and Clydesdale like this.
  20. Illustrious Hector
    Illustrious Hector
    Why the spacers? As 19Eddy30 pointed out, Ya got no Register.
    There's a reason the factory cast them into
    axles & hubs. Also why early cars had reverse threads on th left side. The force exerted on the
    fronts from turning would loosen them more readily than the rears
  21. deathrowdave
    deathrowdave
    from NKy
    Verify that the flat seat is not cut deeper than other wheels allowing the shank of the nut to bottom on the hub / hub spacer . If this is so I think this may be the issue . I ran shank nuts on Mag Americans for many miles , it’s always best to retorque or check tighten often . The taper style will hold the nut tight under load when tightened correctly . Flat face mount 10 lug , large truck wheels have issues with keeping the flat seat nuts tight also .
  22. twenty8
    twenty8
    Hub-centric rings work. They help to centre the wheel on the hub and take load off the wheel studs
    They are very inexpensive, an despite what some say, very simple to use. I don't know why you wouldn't.....
  23. BJR
    BJR
    How do you use a hub centric ring with a wheel spacer like the OP has?
  24. Clydesdale
    Clydesdale
    He will possibly have to bore out the ID of the spacer to clear the ring, seeing as he said he had made those spacers himself I cant see that being an issue, the ring will likely be thick enough to account for the spacer and still locate in the wheel ID.
    BJR likes this.
  25. Hub centric spacers
    BJR and twenty8 like this.
  26. Clydesdale
    Clydesdale
    You wont find Hub-centric spacers in less than 10mm thickness though, at least no where near the thickness of the current 'shim'.
    Now there's a thought, at what point does a shim become a spacer?
  27. twenty8
    twenty8
    Boring out the spacer will not work. In fact, the spacer should be a reasonably snug fit on the hub. When the correct hub-centric rings are fitted to the wheel centre-bore they will sit flat with the wheels mounting face. In the OP's pics it looks like there is enough of the hub protruding through the spacer to engage a hub-centric ring. When using thicker spacers, you could use the hub-centric type like @anthony myrick posted above.
    anthony myrick and BJR like this.
  28. twenty8
    twenty8
    The ones below are 3mm thick and are hub-centric. I couldn't find any 2mm with a quick search.
  29. Clydesdale
    Clydesdale
    wow I stand corrected, never seen then them that thin before.
    My comment on the spacer was that if the ID matched the spigot ring then it would be centrally located, with a 2mm spacer there should still be enough register on the spigot ring to fit the ID of the the wheel
  30. 05snopro440
    05snopro440
    The hole configuration in your two photos above are identical. The taper on OP's wheel is obvious when you look at he smaller bore of the hole compared to the recess inner diameter.
    Agreed, the spacer makes no difference. I've been running a 1/4" spacer on the front of my S10 with aftermarket aluminum wheels for 24 years. They fronts came loose once, they had recently been reinstalled. Torqued them and they were fine again.
