I've seen this type rear suspension rarely used, and wonder why. Generally, most guys go either four-link or ladder bars, but I'm looking for a simpler, less space-consuming design. My reasoning behind this is this isn't for a race car. I'm looking at a lowered custom, so race duty isn't needed, just something to prevent spring wind-up, particularly if lowering blocks would normally be used. I understand that most custom guys would use a four link or truck-arm style suspension with air bags for this, but I have no interest in bags (and their expense/complications) and don't care about 'laying frame'. Retaining ride quality is important also, so ladder bars are out. But because the car is lowered, I also don't want anything hanging down like ******* bars. Fabbing an axle pivot point below the leaf spring would be fairly simple, add the upper links and triangulating them some gives most of the same benefit as a track bar. This would also allow adjusting ride height easily also. Basically the same design as most GM coil-sprung rear suspensions, just with leaf springs instead of coils. Anybody with experience with this? Tips, comments?
Are you meaning semi-eliptic leaf springs, (like half of a conventional parallel leaf spring arrangement)? Why not just use parallel leafs?
I think you’re taking about a quarter elliptical set up? @Malcolm has it on the back of his roadster. Not super un common to see on hot rods
The idea is to use the OEM parallel leafs with upper links. I also wouldn't be clamping the front half of the spring together like the Mopar pro stockers. Kind of a 'traction masters' arrangement, with the bar above the spring instead of below.
Using the springs and upper links is what Chrysler did years ago. Leak link is what they called it. Harsh set up .
Shelby did exactly that on GT350R's except they were call "Traction Override Bars" Ford also did thie OEM on English Mk1 GT Cortinas [except they were inboard slightly] This system works well if there isn't too much arch in the springs [due to forward thrust]
Correct from what I remember, We did this under a Fairlane and it seems to me you had to put floaters on the axle also. That has been decades ago for me.
All you need is a single Traction Master type link for a reaction point. Arrange it so a line drawn through the pivot points coincides with the front spring mount.
On my '48 Ford p/u I moved the spring hangers up on the frame and removed a couple of leafs. The springs were weak enough to wrap up and I broke a couple of u bolts holding the u joint. It was a 10 bolt GM rear, so I built a couple of links from the stock cast brackets out to the frame. I put 100K miles on it. Rode great, handled great.
Yeah if your going to run leafs with upper links just put a full floating kit on it and then it gives you alot more options....
Jaguar uses two coil over shocks per side on the IRS. Four total coilover shocks. Sent from my SM-A102U using The H.A.M.B. mobile app
I've built a couple leaf ling rear axles setups. They work , but not as well as a four link. But they are easy to do. The pictures a couple posts back are pretty much the way to do it. Upper bars should be as long as possible for pinion angle changes. And a Panhard bar sure helps. I have an S10 running around with a stepped and narrowed rear frame half, 31" Micky's and a Blown 400 small block and he has never broke anything in over 20 years. It also runs 10s in street trim.
So what I'm getting out of all this is a leaf-link isn't the best choice for drag racing but would be suitable for a street deal. That's all I'm after, the car is a 4000 lb convertible and I just want to eliminate any possibility of axle tramp. Do my homework and pay attention to the geometry and it should be fine. I'm not adverse to the Jag rear (I've got four of them... ) but that's a different can of worms. Gear ratio changes are expensive/difficult and while their Dana 44-based center section is pretty stout, it's not as tough as a 9" which is already in the car...
Steve 59 - 62 Corvette had what you are talking about with the bar above the rear. Simple and seemed to work fine. Pat
@Crazy Steve Ist generation Explorers used leaf springs with a top mounted link, similar to @Mimilan comment and photo for the Shelby GT350R. Ray
When I fabricated the rear suspension for the Comet I used leaf springs with tubular bars mounted under the housing going forward to the front eye of the spring. The leafs are relocated inboard 2 1/2”, the front of the bars mount to the same through bolt that locates the front spring eye, the rear of the bar in in the center line of the axle under the housing. I put 1,000 miles on the car before the weather closed in and I am very pleased with the way the rear suspension works. There is no bind and the car rides well. My opinion is that if the geometry is correct a Leaf/Link system a good option.
I know this is an old thread (sorry) but I did not want to start a new thread as this one has some good info already. I was thinking of adding 2 lower arms to my rear end similar to what @kabinenroller has above but longer and made of 2x2 box. I would then be adding airbags to that. I can not see any downside but wanted to see if anyone has tried this or sees something I am not. (I know how to set up arms so there is no binding and all that fun from my off road fab experiences) I currently have 2 leaves and 3 inch blocks in the rear. It is an air over leaf setup and rides pretty stiff/bouncy due to the high pressure needed to get the car up and as many know with minimal leaves we get axle wrap which will eventually break the leaves. Also the suspension travel is limited to the bag travel which would only come into play if I needed to change a tire. I thought if I could add some 2x2 "traction" bars to the bottom of the rear end and run 2600 bags off those arms to provide the lift that would work. It would minimize the axle wrap acting as a traction bar which would extend the life of the leaves and it would provide me a better ride due to the 2600 bags being an air over link design. I am not wanting to go to full 4 link because I do not want to modify the body (Rear seat area). Also if I tried parallel 4 link the pan hard is right where the gas tank is. I have searched everywhere and could not find any info except this thread.
I'd check out mini truck and slammed air ride forums. They have got to have more experience than most here. The air over leaf thing seems like a partial solution. The leafs have to support and locate the rear axle, but also flex enough that air changes ride height. The front pivots would need to be strong, yet compliant and quiet. This lost the pictures. https://www.jalopyjournal.com/forum/threads/1956-mercury-monterey-on-airride.924102/ Bad chad did one. I just found the link, didn't watch. www.youtube.com/watch?v=nMzW35rgOZo
Austin seven rear suspension. Quarter eliptic springs and torque tube. Doesn't get much simpler than this.
I appreciate the links. I read that 56 merc thread before I posted in here. Found pics of his car (Really nice) but none of the actual suspension set up. I did see the bad Chad vid previously. He is running a mono leaf with blocks and shockwave bags. Very similar to my current set up. The mono leaf is scary to me and he is going to have a similar ride as mine unless the shockwaves are that much better then a bag and a shock. Plus the axle wrap would be even worse then my 2 leafs (***uming my extra leaf actually helps). Basically the leafs in my idea would locate the axle front/back and side/side. The bars would simply provide anti axle wrap and act as the actual spring due to the air.
Bruce Mclaren's first race car was an Austin 7. They are still popular with vintage race series today.
I know this is an old thread but '29 Gizmo's post a few posts back seems to have hit on what the original post was asking about. I think the Austin 7 with an addition of upper links to handle torque is on target. Seems many posts went different directions....which is traditional HAMB practice. Someone who I think was from Iowa built a Model A with quarter elliptics and upper links a few years ago and actually did some drag racing with it. As I recall I think it worked quite well. Lynn
