Technical 1949 pontiac silver streak
Discussion in 'Traditional Customs' started by dmoz, Aug 9, 2025.
  1. dmoz
    dmoz
    from Texas
    I am completely new to pontiacs. I am about to purchase one that has no drive train but was previously set up for an SBC/T350 combo. Its still has the original rear-end. It's my understanding that these cars are similar to chevy's of that period but only in appearance. Having done a rearend swap on a 51 styleline to a camaro rearend, will this work for the pontiac? I'm told that the pontiac is wider but i can't find rear end specs on these old pontiacs anywhere. Thanks in advance for any helpful responses!
  2. Wait till ya get the car
    Pontiacs were open drive shaft
    mgtstumpy, Robert J. Palmer and dmoz like this.
  3. bchctybob
    bchctybob
    Google shows a tread width of 59” and 60”. You have to figure in a little wheel offset but in those days they were mostly pretty close to centered. So, 59”- 60” should be in the ballpark.
    dmoz likes this.
  4. Why would you want to?
    The Olds, Pontiac rears were the 9" Fords of their day.
    bchctybob, Oneball, Just Gary and 8 others like this.
  5. dan c
    dan c
    mebbe the same as an olds, only the '49 olds was torque tube...
    dmoz likes this.
  6. 302GMC
    302GMC
    from Idaho
    If your '49 was an 8 cylinder hydro, the existing 3rd member will be perfect ... if not, an Olds or Pontiac 3rd member thru '55 bolts in ...
    bchctybob, skooch and dmoz like this.
  7. dmoz
    dmoz
    from Texas
    Any idea what the gearing was in the 49?
  8. dmoz
    dmoz
    from Texas
    Thanks for all that replied. I'm picking it up on Saturday so i will post pics and follow up info soon. Thanks again.
  9. 302GMC
    302GMC
    from Idaho
    Not without knowing what engine & trans were in it ...
  10. skooch
    skooch
    I concur that there is no real good reason to replace the rearend. They are plenty strong and in 49 should have freeway gears of either 3.08 or 3.23 depending on the model.
    flynbrian48 and dmoz like this.
  11. skooch
    skooch
    ^^^ for some reason had it in my head that this was a Hydramatic. Gearing will be much steeper if it’s a manual.
  12. BJR
    BJR
    I am almost positive this is wrong. Olds was an open driveline, Buick and Chev used torque tube driveline.
  13. fyrffytr1
    fyrffytr1
    Does the Silver Streak side emblem have an 8 between Silver and streak? If so it is the 248.9 ci straight 8. If there is no 8 then it was a 239.2 six cylinder. It could also have a manual 3 speed transmission in it.
    And just for your education the Silver Streak was not a model designation. It was a trim package. There were two models in 1949, the Chieftain coupe and the Streamliner. The Chieftain was available in four versions, Sedan, Sedan Coupe, Business Coupe and Deluxe Convertible Coupe. The Streamliner was available as a sedan and a sedan coupe. Sedans were 4 door while Sedan Coupes were two door.
  14. BJR
    BJR
    What about station wagons?
  15. skooch
    skooch
    Correct me if I’m wrong but I believe all Pontiacs of this era were considered silverstreaks due to the center hood trim that ran from the front to the back.
    31 B'ville likes this.
  16. 302GMC
    302GMC
    from Idaho
    Catalog says they're Chieftains ... 1950 Pontiac Foldout full line-07-12.jpg
    leon bee likes this.
  17. bchctybob
    bchctybob
    Dmoz, did you get the car? Take pictures for us?
  18. fyrffytr1
    fyrffytr1
    The SilverStreak trim did refer to the hood waterfall and sometimes there was a trim piece on the trunk. It was not an official body style though.
    "The "Pontiac Silver Streak" refers to the prominent chrome or stainless steel trim that adorned Pontiac cars from 1935 through 1956, running the length of the hood and sometimes the trunk to create a streamlined, futuristic look. This design element was a distinguishing feature of Pontiacs during that era, with its form evolving over the years until it was phased out in 1957."
    SS327 and JohnLewis like this.
