Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. 60 Special
    60 Special
    from Omaha Ne.
    I would say, just from that first partial picture, you have gained at least four foot on that one side of the car! Good for you, never enough garage space!! 60 Special
  2. Six Ball
    Six Ball
    from Nevada
    Like the DIXCO pressure gauge . I recently replaced a cheap new tach in my '53 pickup with an old DIXCO unit. still need to clean up the wiring some. It looks much better.
  3. Outback
    Outback
    from NE Vic, Oz
    I noticed it too. Not familiar with the brand though. Love your work @J.Ukrop
  4. Joe Blow
    Joe Blow
    Stogy, Ragged Edge, tr_rodder and 5 others like this.
  5. Dubonet Garage
    Dubonet Garage
    from France
    Hmm, it looks pretty neat and tidy for the moment but I'm sure that's going to change soon!
  6. Six Ball
    Six Ball
    from Nevada
    This is the model I have.
  7. winduptoy
    winduptoy
    my Silver Eagle (Trailways) coach has Dixson Speedo and Tach but is no hot rod....
    Stogy, Outback, Joe Blow and 2 others like this.
  8. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks for sticking with me. The NOS Dixco gauges were a gift from @corncobcoupe back in 2023.
    It’s fun to reflect on the state of the insert at that point too.
    Anyways, I made some major strides on the garage organization this weekend. Tools are mostly where they need to be, and I’m really liking the direction the place is headed. I need to install a few more lightbulbs and organize some shelving before I post a “finished” photo.
  9. Six Ball
    Six Ball
    from Nevada
    Does the new place have 220v for a welder & compressor? I hope the new neighbors are as accepting as the last ones.
  10. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Although it does have 220v, the place comes with its own set of big city challenges that I'll discuss more later.
    Stogy, Ragged Edge, Six Ball and 5 others like this.
  11. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    As I finally prepare to set up my front wheel bearings, I had to buy a new (old) set of channel locks. Figured you guys would get a kick out of the previous owner's customizations. IMG_1590.jpg
    Also, I'm happy to be giving 2.0 a little taste of the good life.
  12. Tim
    Tim
    from KCMO
    Man I spray way to many sparks and shards of metal to ever have a rug under the car be anything but a grinder dust born piece of sandpaper but it sure looks cool under a hot rod!
    Stogy, J.Ukrop, Six Ball and 3 others like this.
  13. drdave
    drdave
    I think of that every time I see pics of Verne Tardel's shop with all the carpet on the floor....how is that not just full of metal shavings waiting to s****e you up as you slide under the car? LOL
  14. Outback
    Outback
    from NE Vic, Oz
    I have some Whitworth spanners with my G'pa's initial like that
    RMcCulley, Stogy, warbird1 and 5 others like this.
  15. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    This morning, I woke up early, ran a few errands, and then spent a little bit of time on the car. Being new to the apartment building, I'm trying to limit the amount of noise I make. That said, I had a couple of holes to drill so, when the neighborhood was quiet, I broke out the tools and got to work.
    My first task? Finding a home for the master cutoff switch. IMG_9838.jpg Longtime readers will remember this plate. It was the first piece I made for the car, and I originally mounted it to the top of the Model A framerail. Well, now that things are configured differently, I decided to install it on the seat riser. Mostly out of sight, but perfectly within reach. I'll take a picture of the finished setup next time I'm down in the garage.
  16. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    While the holesaw was still hot, I cut through the floor channel to create some clearance for the negative battery terminal bolt. With a quick bit of filing, we were in business.
    For my final task of the morning, I hit the bottom of the seat pan with the holesaw so that I could connect the cables from the cutoff to the battery. I'm waiting for my grommet, but in the meantime I'll finish up all the heavy duty battery wiring.
  17. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Although not much of an update, I can't begin to explain how good it felt to get back to work on the car after all the moving and traveling. The first part of the morning was spent looking for tools and wrestling with holesaws, but once I hit my stride I felt as if there was no place I'd rather be. Next time I'm down there, I'm focusing on more wiring. Then, over the long weekend, I'm finally addressing the front wheel bearings and seals. As you know, I'll keep you all in the loop every step of the way.
  18. richard noble
    richard noble
    Good to have you back, Joey.
    Stogy, winduptoy, J.Ukrop and 2 others like this.
  19. Tim
    Tim
    from KCMO
    Man that’s a tight fit! Glad to see you back in stride. What’s the plan for the floor board there?
  20. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Feels great to be back. I'm very much looking forward to lots of garage time this weekend.
    Thank you! The picture is actually a little bit of an optical illusion. The top of the battery bolt is about 3/4-inch beneath the floorboard. I just clearanced it so I could easily get a box wrench in there.
    RMcCulley, Woogeroo, Stogy and 9 others like this.
  21. Looks great!!
    Stogy, J.Ukrop, osage orange and 3 others like this.
  22. winduptoy
    winduptoy
    nothing like hot metal chips to warm your morning....
    good lick Joey and I can sense your excitement about a weekend session....
    Stogy, J.Ukrop, Outback and 4 others like this.
  23. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Little jump start on the long weekend.
    First, I made a friend at the auto parts store on my way home from work. The owner said she just had this vintage Cushman shipped from Nebraska. It had a really neat white interior with Stewart-Warner gauges. Hope to see it around!
    Back at HQ, I pulled the drums so I can install the bearings and seals tomorrow. I also sealed up the quickchange for the first time and torqued everything to spec. It'll be ready for oil tomorrow night (!!) IMG_1710.jpg
    That's all for now. The ball keeps on rollin'!
  24. Tim
    Tim
    from KCMO
    Rolling down hill man! Won’t be long and you’ll just have to jump in and pop the clutch!
  25. Six Ball
    Six Ball
    from Nevada
    Pretty soon now all that white paint will tell us how well the fluids are contained.
  26. Tim
    Tim
    from KCMO
    Ok man you should be caught up on sleep by now, how’d the weekend go??
  27. winduptoy
    winduptoy
    inquiring minds....
    J.Ukrop and Outback like this.
  28. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I had a lot to say about how excited I was to work on the car over the long weekend. That may have been foolish of me. Although I faced frustrations and didn't even get close to finishing my to-do list, I ended up spending a lot of time with some of my best friends. I have an early morning tomorrow, but there's no time like the present to try to bring this ever-evolving story up to speed. Here we go.
    On Friday morning, I rolled up to my favorite hot rod shop in the world to spend the day with David. As I walked in, I was greeted by Sean's roadster sitting at the center of the freshly swept floor. David had recently driven it to a cars and coffee at Frank Lloyd Wright's Marin County Civic Center, and he was working out the bugs. I took a moment (okay, many moments) to appreciate all the hard work he put in on it. The new rear spring setup really changed its at***ude.
  29. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    My task for the day? Install the front bearings and seals. On my drive up, I discovered that there was some spalling on my original bearings. Since everything was already taken apart, David called Petaluma Bearing, who had a suitable replacement. He rode over on this two-wheeled terror as I supervised. IMG_1721.jpg David taught me how properly grease my wheel bearings and tap in the seals. He used a hammer and a flat disc with a screw-on aluminum handle. Tap. Tap. Tap. "Listen to the sound change," he said. "That's when you know it's seated."
    IMG_1732.jpg We spent the remainder of the day turning wrenches and enjoying our time in the shop. Before it was time for me to go home, David took me for a spin in a customer's 1946 Willys Jeep. It's a one-year-only column shift and it was extremely fun to roll around the block on a warm North Bay evening. "How would you say this compares to a stock Model A roadster?" I asked David. "It's much peppier," he said.
    A perfect way to end the summer.
  30. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    That's all for tonight. More updates soon.
    P.S. I'm posting a bunch of stuff for sale in the cl***ifieds. If you need flathead or 'banger pieces from me, now is your chance!
