Projects Fun Project or Nightmare? Fixing a 46 Ford
Discussion in 'The Hokey Ass Message Board' started by WhatDidIDo, Aug 15, 2025.
Tags:
  1. WhatDidIDo
    WhatDidIDo
    Hi all, hoping to get some advice on a 46 Ford Deluxe I purchased at auction. Appears to have had a heavy object crunch the rear end, wondering if it's worth fixing or swap parts over to a shell sitting somewhere in a field? Also if you have a body sitting in a field somewhere let me know. Or if you've ever repaired something like this let me know ow how you'd go about doing it. Best wishes, prayers, advice much appreciated.
  2. lostone
    lostone
    from kansas
    I usually find they start out as a fun project and slowly turn into a nightmare much like some of the women I used to date... but ahhh that's another story...
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    You didn’t list your location in your profile, maybe someone local to you has body parts but we don’t know where you are….
    This one is at a salvage yard nearby but is a 2 door IMG_5308.jpeg View attachment 6492750
  4. WhatDidIDo
    WhatDidIDo
    Good call, I am in Central Texas
  5. Y’all gonna need a body hammer bro.
  6. Car was probably inexpensive enough that you can play and make mistakes on it while you get it back in to shape, and hone your skills.
    You'll be surprised what bottle jacks, wooden posts and some hammer work will accomplish.
  7. catdad49
    catdad49
    As Algoma said, what does it hurt to try moving that metal back? It looks like the trunk lid is good and it's amazing that the rear side window survived. Deconstruct enough to see all the inner structure damage, that should tell you, fix or replace. Fat fenders are still relatively cheap, so keep that in mind.
  8. Jalopy Joker
    Jalopy Joker
    maybe make into a pick up truck
  9. Looks like a candidate for a tudor/coupe conversion, or Carson type top. In the mean time nothing ventured nothing gained, if you have a farmer friend, ag tractors are a good source of hydraulic power to pull out body panels.
    enloe, porkshop, Algoma56 and 8 others like this.
  10. lothiandon1940
    lothiandon1940
    That could be saved. It's beyond my skill level, but it could be saved.
    enloe, porkshop, Algoma56 and 4 others like this.
  11. BJR
    BJR
    Id either make it into a Ranchero / El Camino type of pickup, or cut it at the windshield posts and replace the back with a coupe or 2 dr body section. Why waste your time on trying to fix a 4 dr, unless you like a challenge, or want to learn how to do bodywork.
  12. A couple of questions that will help with the advice on this car-
    Are you a welder/fabricator or have experience in these fields?
    Can you do body work?
    Many have suggested a Tudor/coupe conversion which is a good idea but still requires some major welding, fabricating, metal working skills.
    Like the Carson Top convertible, but this does require fabrication or wood working skills depending on how the roof frame in build, as will also require upholstery.
    Photo from Custom Car Chronicle-
    upload_2025-8-16_8-44-56.png upload_2025-8-16_8-45-27.png upload_2025-8-16_8-45-58.png upload_2025-8-16_8-46-34.png upload_2025-8-16_8-47-30.png
    Photo from Google-
    Photo from the H.A.M.B.
  13. kb cookout
    kb cookout
    If you could find a sedan delivery body shell ( single back door) and the back door, and graft it on, they use the same front doors and front sheet metal
    later kb
  14. mr.chevrolet
    mr.chevrolet
    as Jalopy Joker said, thats a 'cars made into pick up trucks' project right there
  15. Okie Pete
    Okie Pete
    Looks like a perfect project to convert into a Ute .
  16. catdad49
    catdad49
    Unfortunately, the main part needed for the pickup/ute transformation is the part that needs the most work. There is no Easy way out, but if it were Easy....................! How about a fat fendered phaeton? Giant Carson type top, rear area tonneau, you know more Easy stuff!
    enloe, porkshop, Okie Pete and 2 others like this.
  17. ***Area-51***
    ***Area-51***
    from Ohio
    There are a few here on the hamb that could straighten that out...probably for those that graduated from the advance cl*** but I think it can be done.
  18. Squablow
    Squablow
    I like to do sheetmetal work and have done quite a few major rebuilding projects. I personally would not even bother trying to straighten that, it's too far gone. It's stretched, cracked, it'll take hundreds of hours to work it back into shape.
    If you like it as a 4 door, find a donor section, I suggest everything from the rear door back. You can reuse your fenders, trunk lid and floor. Won't be expensive and could be completed in a week.
    Or, if you'd rather have a Tudor or coupe anyway, find a donor shell, you can still reuse your floor and fenders. Honestly, it won't take any longer, since if you find a good donor you could splice at the windshield pillars instead of the roof skin.
    If this was a Ferrari or a Tucker or something, I might suggest trying to straighten it. It's not impossible, but it's way more work than it's worth.
    enloe, porkshop, Paul B and 8 others like this.
  19. Last edited: Aug 16, 2025
  20. kb cookout
    kb cookout
  21. HOTRODPRIMER
    HOTRODPRIMER
    I don't have a clue as to the location of Central Texas but a Hamber by the name of Flat Top Bob has a 100 acre salvage yard in Wellington,Texas may be able to help with parts or another body.
    Give him a call, he has helped me out with parts many times. HRP
    800-798-2581 -- flattopbob32@gmail.com
    806-447-2581
    3725 us hwy 83 s
    wellington texas 79095
    porkshop, Paul B, jimmy959 and 4 others like this.
  22. HOTRODPRIMER
    HOTRODPRIMER
    I think you can repair the body, I am not a bodyman but I pushed the windshield/drivers door area and drivers side top back in shape after my daughters explorer was rolled, I did a pretty good job for having zero experience with this type of work.
    All it takes is a porta power kit and some trial and error, I was able to get the car to the point of body work in a weekend. HRP
  23. WhatDidIDo
    WhatDidIDo
    I'm considering it, having a wooden bed with period bed sides does sound pretty interesting. Wonder if it's been done before.
  24. goldmountain
    goldmountain
    I agree with HRP. Great place to learn metal working skills. What do you have to lose?
    porkshop, Algoma56 and WhatDidIDo like this.
  25. Hubnut
    Hubnut
    20250412_090811.jpg 20250418_110059.jpg I stripped this 48 Mercury back in the spring. You can see just above the rear fender where I sliced the roof off. I gave it to a buddy of mine, and I'm certain he would sell it or trade it off. It is complete with rear gl*** and quarter gl***. We are in southwest Arkansas. I also know where a couple of other 46-48 Ford and Merc sedan parts cars are.
  26. I’d fix that top. At least make an honest attempt
    it’s just metal.
    people fixed **** like that back in the day
    49ratfink, enloe, porkshop and 5 others like this.
  27. Dan Hay
    Dan Hay
    I’d be looking for a convertible body.
    lothiandon1940 likes this.
  28. Bandit Billy
    Bandit Billy
    I'm thinking station wagon.
    enloe and porkshop like this.
  29. gene-koning
    gene-koning
    I'm with the crowd that says "Give it a shot, you have nothing to loose except the time spent, and you will gain a bunch of real life experience."
    Then, if all else fails, the body swap is still an option. Going that route, unless you really like the 4 door version, I would exchange the old body shell for a coupe or 2 door version. You have a lot of options!
