Projects Bought a Mercury on purpose
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Feb 4, 2023.
  1. Local friction shop rebuild. $105.
    several years ago, an older hot rod guy gave me a beater 51 merc. Rotted with the rear axle ripped out like in American Graffiti. Had the correct core clutch parts. Amd a std merc flatty
    thanks Ralph.
    Miss that guy.
  2. I'm surmising you must have quite the Backyard collection.
    Dick Stevens and porkshop like this.
    Came in handy. For the SBC to flathead I had an adapter I bought for $50 over 10 years ago for the heck of it.
    Had the correct SBC FW and correct clutch pieces in my junk yard plus a few 3 bolt starters.
    Found a nos pilot bushing adapter for $15.
    so when I get a new TO bearing I’ll still be under $200 for the swap.
    Not bad
  4. patsurf
    patsurf
    :confused::eek::(:(:(:(
    someone just made the 'maxwell smart' comment about something else-fits here(yes,pun intended)
    porkshop and anthony myrick like this.
  5. Dyno Dave
    Dyno Dave
    Anthony, enjoying your teacher/student Merc coverage. Was viewing the parts ad and this was posted;
    You have insufficient privileges to reply here. Has someone seen my checkbook balance ?
    Thanks, Dyno Dave
    Okie Pete and anthony myrick like this.
  6. Picked up some H78s last night.
    The big pattern ford wheel have been blasted and painted. So that saves a little work.
    The h78 is a tad taller but these are fine for now.
    Plus I dont need the factory merc wheels that I’ll probably sell now.
  7. guthriesmith
    guthriesmith
    Makes a huge difference even during mockup. :cool:
  8. Kinda adds some inspiration
    Gotta get off my **** and get that engine/trans in
  9. guthriesmith
    guthriesmith
    I need to unstack the stuff that is sitting on and around my Merc. That also adds inspiration.
    bchctybob, wide34, Okie Pete and 2 others like this.
  10. Student trimmed the other bezel IMG_7863.jpeg IMG_7864.jpeg some fine tuning and well wrap up this part
    bchctybob, 2devilles, BigRRR and 13 others like this.
  11. ffr1222k
    ffr1222k
    It looks good Anthony. Your students have done a great job so far.
  12. Cleaning up the firewall. All the heat and ventilation pieces will probably be painted gloss black. Not sure on the firewall color. Leaning towards semi-gloss black. Not totally against the dark grey metallic that’s on the outside of the car.
    the trans adapter hit the firewall where the top center bolt is. My block doesn’t have that hole
    So we hammered a small recess for that to clear. Got it little more uniform than in the pic. Will mimic that on the trans cover Didn’t need much.
    Frame and suspension will be flat black.
    bchctybob, ffr1222k, bobss396 and 9 others like this.
  13. Okie Pete
    Okie Pete
    Progress . Awesome
  14. warhorseracing
    warhorseracing
    from cameron wv
    BEAT ON THEM CARS WITH HAMMERS!:eek: Looking good.:cool:
  16. Nice Fit! Good work on the edge to housing.
    bchctybob, porkshop, ffr1222k and 3 others like this.
  17. ffr1222k
    ffr1222k
    looks good Anthony
  18. AVater
    AVater
    You do nice work! Thank you for the updates.
  19. Headlight work roughed out
    IMG_9537.jpeg Welded by student.
    Yep. We use filler.
  20. Got some primer on it
    we’ll work the upper area of the pocket some more. But overall, it’s gonna work
    ffr1222k, bchctybob, Squablow and 9 others like this.
  21. Primer is PPG 2050. Has a lot of texture.
    Shot thru a 2.0 tip.
    2050 is an epoxy filler primer.
  22. guthriesmith
    guthriesmith
    Looking good. Must be some thick stuff lumpy like that even through a 2.0 tip.
    anthony myrick likes this.
  23. It’s thick. The catalyst looks like mol***es.
    It’s a DTM epoxy filler. Ok to use under body filler.
    Doesn’t build up as much as a polyester but I like it a lot better than urethane.
  24. bobss396
    bobss396
    So invite all the students to a block party.. :D
  25. Block party round one
