Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. saltflats
    saltflats
    from Missouri
    I have some seal protectors for this transmission, sure helps with a rebuild.
  2. chevyfordman
    chevyfordman
    Changed out the clutch pedal bushings on my 40 Ford, really made a big improvement. The old ones were pretty worn but the pedal and shaft were still good. IMG_3022.jpeg
    porkshop, Sharpone, pila38 and 7 others like this.
  3. swade41
    swade41
    from Buffalo,NY
    Lately when I first fire the Henry J I've been gettin some poping out the right pipe, get out on the road and hit a few rpms it clears up.
    I do a lot of this around here, sitting in traffic, so I figure it's just a fouled plug.
    The other day at a steady 3000 rpm I could still hear it, so a couple romps it cleared up again.
    Today I pulled a plug to just see what story they had to tell, they said "you're choking me daddy-o !"
    Early in the year I had dropped 2 numbers all around, today I dropped the primaries another 3 and cleaned the plugs off, I'll take it out tomorrow and see how it does.
    Might be like a regular 2 Lane Blacktop moment around here, gotta check the jets !
  4. chevy57dude
    chevy57dude
    Billy, those polished Mickey T's are beautiful.
  5. mad mikey
    mad mikey
    Billy, I have had to tune a bit with the crazy humidity we have had here for weeks. If you get in lots of traffic, maybe a hotter plug may be in order.
  6. Robdski
    Robdski
    Well, things looked like they were going good, until I discovered this. IMG_4002.jpeg
    Cracked rear servo housing caused by installing the servo out of sequence. Totally my screw up.
    I don’t believe it can be saved, but boy oh boy did I learn a lot in the process.
    I may look for a good used TH-400 case and swap parts or cut my losses and buy a pro rebuilt.
    Remind me to tell you guys about the first time I tried to sweat copper water pipe.
  7. atch
    atch
    "I don’t believe it can be saved"
    Oh, a little JB Weld and/or duct tape and you're back in business.
    If I had a case you'd be welcome to it. Sweetie is in Mokena right now celebrating her son's birthday.
  8. jimmy six
    jimmy six
    Raw US steel wheels…..match painting has become an understatement to say the least. I do like Max 2K Glamor Clear. IMG_7092.jpeg IMG_7093.jpeg
    porkshop, swade41, loudbang and 8 others like this.
  9. Robdski
    Robdski
    I didn’t know if JB Weld would work, or are you just kidding?
    I didn’t know if this was under high pressure or not.
    Mokena city center is a great place for music, they have done a great job there.
    porkshop and Sharpone like this.
  10. High test 63
    High test 63
    IMG_20250817_134704.jpg IMG_20250817_140822.jpg took off the wieand /Holley 4 brl intake and carb today and put the Edelbrock 3x2 intake on. I blocked off the secondarys till i get it fired and tuned properly on the primary carb. It's got to set overnight till the ultra black i used to seal the ends cures. Looking forward to tomorrow!
    porkshop, enloe, Joe Blow and 16 others like this.
  11. atch
    atch
    Sorry; just kidding. That said I've heard some whopper tales that claimed to be true so you never know.
  12. Sharpone
    Sharpone
    Bummer man
    Dan
  13. chevy57dude
    chevy57dude
    @Robdski - sorry, man! But you're out there giving it the 'ol hot rod try. Actually doing it yourself instead of just checkbooking the project.
    Randy - I see custom pushrods in there! Bet it's gonna run like a top on a single 2.
  14. dvsz28
    dvsz28
    porkshop, saltflats, Robdski and 5 others like this.
  15. alanp561
    alanp561
    Huh! And I thought dropping a nut into the intake manifold on my '48 was bad:(. Project was to remove the old 94 and install the new 97. Pulling the intake seemed to be the only option. Recto-cranial inversion followed immediately by missing removing one bolt and breaking the intake manifold:mad:. Sometimes, wedges and long pry bars are NOT your friends:oops:.
  16. 57 Fargo
    57 Fargo
    Small progress on Wifeys T-Bird…
    Found the worst rust on the car,
    Behind/under right headlight buckets.
    Where I ended up calling it an evening yesterday.
  17. lostn51
    lostn51
    from Tennessee
    Oh this brings back memories…….:rolleyes::rolleyes:
    I had a heater hose break on my wife’s OT Town Car with an 4.6. It runs under the intake so you have to pull it off which isn’t a huge deal but whenever you have cataracts and everything is a complete wash out blur so it sorta complicates things:p I tore the top side of the motor off and replaced the hose then put everything back together. It took 3 days to do a 6 hour job because I couldn’t see a damn thing. My dad came over and inspected the job and made sure I had no loose ends and whenever I fired it up it made one hell of a rattle in one of the cylinders and before I could shut it off it stopped. Cranked it up again and ran fine until it started smoking like a freight train. Come to find out part of the intake gasket which was hard plastic fell into the cylinder and it either punched a hole in the piston or it gummed up the cylinder walls and ruined the rings. Either way I destroyed a nice low mileage 4.6 because I always work on all of my cars and never send them to a mechanic. :rolleyes::oops:
  18. swade41
    swade41
    from Buffalo,NY
    Thanks and I see you guys remembered my fake name tag shirt. Lol
    Philip
    lostn51, porkshop, Joe Blow and 7 others like this.
  19. Sharpone
    Sharpone
    If ya ain't screwing up and/or breaking things ya probably ain't doing anything!
    Dan
    lostn51, porkshop, mad mikey and 4 others like this.
  20. Robdski
    Robdski
    I can honestly say, as a non-mechanic, I wasn’t trying to take money away from the trans guy, I just wanted to give it a try, to learn something, for my own benefit.
    For you guy’s that have the knowledge and talent to do this for a living, I have a new found respect.
    Thanks to everyone for the kind words, it was a learning experience. I’ll take the loss and move forward.
  21. Alan, I gave you a like because I’ve done that kind of thing too and feel for you. Not because it happened. I’m looking forward to seeing you again at LF-3!
  22. Zax
    Zax
    I happen to have a stock 48 intake on a shelf in my garage if you need one buddy
  23. deathrowdave
    deathrowdave
    from NKy
    IMG_1506.png IMG_1507.png Had to add a leaf to drivers side of the Power Wagon . Me and full fuel tank on that side , for years caused a bit of a sag .
    porkshop, Joe Blow, saltflats and 9 others like this.
  24. mad mikey
    mad mikey
    Yep! Crazy Philip. Or Bad *** if you prefer. :D:)
    porkshop, swade41 and deathrowdave like this.
  25. Bandit Billy
    Bandit Billy
    Ah, that's what we were talking about the other day. ****s! That intake was dirty anyway. Time for a nice, clean one.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    Plug wires, hooking up gauges and a pvc system ( it had an open 3/8” vacuum hose going into the oil fill tube and a rag in the road draft opening) and a new power valve. 33 Chevy belongs to my friend Kerry. He has owned it since 64 and it was on the cover of the first issue of street rodder
    lostn51, porkshop, Joe Blow and 22 others like this.
  27. alanp561
    alanp561
    Thanks, I appreciate it, but I had another one sitting right next to the car. Everything is back on, new Vintage Speed carb bolted up waiting for a different inlet fitting. That car is going to Lloydfest III if I've got to trailer it.
  28. Sharpone
    Sharpone
    Cool car.
    Dan
    porkshop and chevy57dude like this.
  29. Sharpone
    Sharpone
    You’ll have it up and running, plenty of time.
    Dan
    porkshop, alanp561 and 427 sleeper like this.
