Technical 30 Model A Coupe door handle linkage help
Discussion in 'Traditional Hot Rods' started by Belvedere1, Aug 16, 2025.
  1. Belvedere1
    Belvedere1
    from 85050
    Being new to these cars, I need some thoughts on what my options are for re-working things before moving on to having door panels made. How could I keep the bear claw latch but move the inside door handle, mechanism, and linkage rod back the original location, or relatively close?
  2. Dino 64
    Dino 64
    from Virginia
    Is that a bear claw latch in it now ? Unfortunately that door is pretty hacked up. I would look for another door for parts.
    Just Gary likes this.
  3. Belvedere1
    Belvedere1
    from 85050
    Yes, bear claw latch and agree that its not good.......hoping there is something that can be done to make this even slightly better than it is now. I would be OK with something cable operated or other non-standard but functional set-up.
    Its been chopped so wont be pursuing doors.
    douglasb likes this.
  4. lostone
    lostone
    from kansas
    I used new brake cables for a bicycle when I started building mine.
    Although different then yours still close enough to get ideas from
    Deutscher, Dino 64, Algoma56 and 2 others like this.
  5. lostone
    lostone
    from kansas
    Dino 64 and '49 Ford Coupe like this.
  6. '49 Ford Coupe
    '49 Ford Coupe
    lostone likes this.
  7. Belvedere1
    Belvedere1
    from 85050
    Thanks for sending that lostone, this is definitely something I will investigate further. I'll read through that link in detail tomorrow morning.
    lostone likes this.
  8. Kiwi 4d
    Kiwi 4d
    We welded a patch with a bump in it to cover the bear claw , but left some access holes. The black cable sheath one needs secured to the bottom latch edge of the door. I ***ume in your final rendition the remote lever will be installed behind the door skin ? The pin sticking out of the B pillar in our model A is going to be a real pain catching jeans etc. at present we can’t see a way around the pin sticking out as a D will probably not be adjustable.
