Technical FE into a 29 Model A
Discussion in 'The Hokey Ass Message Board' started by deadbeat, Jan 18, 2025.
  1. deadbeat
    deadbeat
    Happy New year to you all.
    I'm building a 29 at the moment, build thread will be along soon. Currently I have the chassis being built, as I can't weld for shit. That said I dropped off a dummy FE and trans to my builder for a test fit to see how everything lines up. I'm using flathead biscuit mounts and a stock starter motor. I have tried looking for threads on this, but didn't see anything, apart from FE's into everything else. So, my question is does anyone have pics of FE's into model A's. Especially engine, exhaust etc. I know Bill B had done it, but I think that was a 32 chassis if I'm correct. Also, I'm not making the chassis longer than stock. Apologies in advanced if someone does find a thread. Cheers
    bchctybob and Sharpone like this.
  2. Everything will fit in a Model A if you're willing to do the work. I can't give any insight, but I want to see how you end up doing it. I love FE's and I do have a couple Model A's. In fact, I have a nice running 390 with a Top Loader behind it. I'm pretty good at building Headers so for me Exhaust is never an issue.
    bchctybob, deadbeat and lostone like this.
  3. Dino 64
    Dino 64
    from Virginia
    The problem will be fitting it in. The front of those small blocks is pretty long so the engine will be set back and the firewall has to be modified. Especially if you’re keeping the stock chassis dimensions. The engine will not be centered in the engine compartment, part of it will be in the firewall. I like those small blocks but I chose a SBC for my A project cause they fit in well.
    Just Gary and deadbeat like this.
  4. Turns
    Turns
    Squeak Bell had a Tudor with an FE
    rod1, deadbeat and don colaps like this.
  5. lostone
    lostone
    from kansas
    If I can fit a 440 mopar in one I know an FE should fit.
    You have several choices here, 1- if your having a frame built then it's easy to add a couple inches in length to it, that's what I did.
    2- like many old hot rodders did, take the firewall out and turn it around and reinstall. I believe that alone is worth 4 inches. I've also seen the firewall turned around and the radiator shell moved forward an inch or 2.
    As for other problems figuring them out is part of it.
    I used fender well exit headers which turn the tubes up away from the motor before turning them back down. This also gives clearance for the starter in a narrow frame.
    I used a Vega steering box and cross steer which allowed the steering box to be up in front of the starter. I didn't offset the engine either, it's centered in the frame.
    Also note I DID NOT reverse my firewall.
    So yeah anything is possible....
  6. deadbeat
    deadbeat
    awesome thankyou fellas. I have a street rod with an FE in it, but the chassis is a 32 style and has been lengthened a few inches. I was thinking on just running stock exhaust manifolds and was thinking on running one upside down to point the exhaust forward around the engine mount, but that may look dumb. Cheers
    @Turns Squeak will be home for summer so I will catch up with him when I see him, cheers
    @lostone nice job on those headers
    bchctybob and CSPIDY like this.
  7. IronFord
    IronFord
    from NoDak
  8. deadbeat
    deadbeat
    Cheers for that @IronFord. Yes, I had seen those threads b4, but I'm attempting to squeeze mine into a stock length A Tudor with a hood and fenders. No back seat so I can move the fire wall back if need be. Looking forward to getting at it soon, cheers
    bchctybob likes this.
  9. cpraceman
    cpraceman
    from walls, ms
  10. cpraceman
    cpraceman
    from walls, ms
    This is a FE in a Model A with the standard firewall.
    I can be done !
    rod1 likes this.
  11. FrozenMerc
    FrozenMerc
  12. deadbeat
    deadbeat
  13. bchctybob
    bchctybob
    If it was mine, I would just mount the radiator and the body in the stock position, cut out the entire firewall and position the engine to where the fan and radiator have the right relationship. Build engine mounts and a new firewall as required. I kinda like a flat recessed firewall with a polished aluminum face. Looks like two engines in there when it’s clean. Build a simple set of Tri-Y style headers, common stock Ford exhaust manifolds are ugly and horribly restrictive. The fancy hi-performance ones are pricey and probably won’t fit your chassis.
    deadbeat and rod1 like this.
  14. Well, that's you. It's not the way he wants to do it. Kinda like when I did a Blown 392 with a 3" belt drive in my 40 Coupe. Total stock firewall and stock mounted Rad. I was told it couldn't be done, Wrong!
    And, it runs a manual fan mounted off the Crankshaft like they were designed to be. This photo was taken in the mock-up stage just to make sure I could do it.
    loudbang, deadbeat and Just Gary like this.
  15. sidevalve8ba
    sidevalve8ba
    One nice thing (among many!) about an FE is the distributor being at the front of the engine so you don't have that interference at the firewall.
