Technical Supercharging my early Pontiac V8.
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Aug 16, 2025.
  1. wheeltramp brian
    wheeltramp brian
    Figured I should start a thread. I have acquired a few parts and need some technical ***istance. Scored a early blower manifold off of a fellow hamber that couldn't use it. Was on the lookout for a 671 blower for a while But didn't want to pay full price for a shiny new one I kind of wanted a cast One, even used would have been good. Found an ad on Facebook for a brand new one for pretty cheap and then the guy figured out what he had and was nice enough to only Charging a few hundred bucks more for it. Gave him a deposit and went on this morning and picked it up. It's a speed master blower with a top plate and idler arm on it but no snout. I've got the manifold on a spare engine right now. So I can make it all work before I put it in the hot rod. The motor that's in the car right now is a 1957 347 board out to about 354 inches. The problem may be with the pistons as they are 10 to 1. So I may have to change those or just run very little boost for now. I need some help with the crank Attachment situation has the early Pontiac Balancer, that I'm using doesn't have any holes in it, but I do have one from another motor with holes in it to mount the hub to.pics to come soon.
  2. wheeltramp brian
    wheeltramp brian
  3. wheeltramp brian
    wheeltramp brian
  4. J. A. Miller
    J. A. Miller
    from Central NY
    That's going to be really cool. Something you won't see every day. (Well, you will.):D
  5. Hollywood-East
    Hollywood-East
    Don't know much about ponchos, But sbc, I've done it a couple times, Run the 882 casting heads on 283/327's, They have a "smog" chamber, Larger, big port, good size valves...
    Regardless, The most important thing to know after reading To Talls Blower book, Buy Lathe turned valve locke!!!
    Saved my ***!
    I was cheap and only ran the single "service " valve springs... 7400 rpm after half a summer , a spring let go..
    Never dropped, an limped home..
    porkshop likes this.
  6. Bird man
    Bird man
    from Milwaukee
    What's not to like?
    A 370 or a 389 head should put you in the right territory for compression?
    My sources indicate that a balancer up to 1962 should interchange.
  7. wheeltramp brian
    wheeltramp brian
    Skärmavbild 2025-03-10 kl. 22.25.29.png I'd prefer to run a 2" drive also. Haven't seen any new stuff made so maybe have to search em out.the pic looks like 3" and stock intake made to work.ive got other pics saved
  8. wheeltramp brian
    wheeltramp brian
  9. Fordors
    Fordors
    Dyer’s Blowers will have two inch pulleys available.
  10. pprather
    pprather
  11. flamedabone
    flamedabone
    While you have the motor apart putting pistons in it, have a second keyway cut in the crank. Grab a crank hub which takes the place of your balancer and allows you to run a common v-belt pulley and blower belt. Hit the google ****on for 2 inch Gilmer belts and pulleys. If you can't find the tooth count you want, you can shave an inch off of a 3 inch pulley.
    Here is my old '33 with 2 inch belt.
    Keep us posted, this is gonna be cool.
    -Abone.
  12. wheeltramp brian
    wheeltramp brian
    How would I know what tooth count I would need to start with. Ill call dyers tomorrow
    porkshop, SS327 and mad mikey like this.
  13. jnaki
    jnaki
    Hey WTB,
    Here are two of the best So Cal supercharger companies that have been around since the 60s and 70s. They have great services and are local. It is about a 1.5 hour drive from your location. They have a lot of history in drag racing at Lion’s Dragstrip and in the OC.
    Littlefield Blower Services: Located in Rancho Cuca****a, they have been manufacturing and supplying Roots-type blowers since 1974. They offer a variety of services including custom superchargers, blower snouts, manifolds, and pulleys.
    Hampton Blowers: Situated in Downey, Hampton Blowers is a leading manufacturer of street and strip superchargers, including 6-71, 8-71, 12-71 and 14-71 blowers.
    https://www.jalopyjournal.com/forum/threads/6-71-repairs.1336944/#post-15618903
    https://www.jalopyjournal.com/forum/threads/4-71-score-school-me-on-blowers.1338637/#post-15650917
    Jnaki
    No need to ship for services. They are So Cal locals and have tons of good things about their companies. Don Hampton has been involved in drag racing since the 50s and in most supercharged compe***ion cars from coupes to FED race cars. Mert Littlefield is now gone, but his company continues his good services and name brand work to this day. Give them a call to see what they can do for you…YRMV
  14. SuperWildcat
    SuperWildcat
    I love stuff like this. Can't wait to see how it turns out.
    porkshop and 427 sleeper like this.
  15. wheeltramp brian
    wheeltramp brian
  16. wheeltramp brian
    wheeltramp brian
    I called dyers and left a message But no response so I emailed them and got a quick response.And they're getting info back and forth so they can get a drive made up.
    SS327, bchctybob, Tim and 1 other person like this.
  17. GuyW
    GuyW
    I ***ume your manifold bolt pattern matches your heads
  18. wheeltramp brian
    wheeltramp brian
    Correct. This intake is for the early bolt pattern which I have.
    bchctybob likes this.
  19. bushwacker 57
    bushwacker 57
    Edelbrock Model B-20 55-60 Pontiac Uses four 2 1\4 pop off valves bottom of manifold. As per catalog 1965.
  20. wheeltramp brian
    wheeltramp brian
    Do you have a picture of it in the catalog? I'd like to see it. It does have 4 pop off valves on the bottom and I'd like to know if there's a way to test them to make sure they're in good shape.
    bchctybob and 427 sleeper like this.
  21. Fordors
    Fordors
    You could probably use a thin liquid like lacquer thinner to see if there is any leakage. I expect they are fine but if there is a leak you can remove the nut on a leaker and lap the valve in just like one in a cylinder head.
    loudbang and bchctybob like this.
  22. patsurf
    patsurf
    and here i thought diesel is ALWAYS the liquid of choice!
    SS327 and bchctybob like this.
  23. Tim
    Tim
    from KCMO
  24. wheeltramp brian
    wheeltramp brian
    They asked me to send out one of my spare balancers with the pulleys on it, so they could get some measurements and it arrived yesterday.So that's where i'm at now.
    bchctybob, Tim and pprather like this.
  25. wheeltramp brian
    wheeltramp brian
    Saw that the balancer arrived and shot them an email but still haven't heard anything back. I'll give them a call in the morning. upload_2025-9-3_22-29-43.jpeg
    GlassThamesDoug, Paul, rod1 and 2 others like this.
  26. bchctybob
    bchctybob
    Love the early Pontiac engines with the water elbows on the front. If you change heads and stuff they might go away though. dang. Oh well, a 6-71 on top is a good trade off.
    How far down are you planning to take the engine? New pistons and a general freshen up? Or just bolt the blower on and see what it does? If your engine was a 2 bbl originally, it looks like it was 8.5:1 advertised CR. 4 bbl was 10.0:1.
    GlassThamesDoug and SS327 like this.
  27. wheeltramp brian
    wheeltramp brian
    It was rebuilt about 6 or 7 years ago with 10-1 pistons. It does have a large cam with a bunch of overlap that bleeds out compression so we'll see what happens when I get to that point.
    bchctybob and jimmy six like this.
  28. 19Eddy30
    19Eddy30
    from VA
    @wheeltramp brian
    How hard you plain to turn / run engine?
    If forged piston , 10:1 static is really not so bad for 4-6 psi boost ,none blower piston . 10:1 static with 6 psi under boost = 13ish compression..
    I have ran sbc on stock piston turning
    5,500 rpms .
    Balancer , good Stock Drill pulley with stock balancer pulley pattern grade 8 or ARP bolts would be fine , No blow hub needed , & if you want 2 inch wide pulley , on lathe or saw cut a 3 inch to 2 or even 1 inch ,
  29. wheeltramp brian
    wheeltramp brian
    I'd be happy with 4 or 5 pounds.dyers is making a new hub/balancer ***embly with pulley cut into it. Just the occasional burnouts and a couple trips down the strip at the antique nationals a year.
    bchctybob and SS327 like this.
  30. 19Eddy30
    19Eddy30
    from VA
    Balancer With V drive belt's
    made on it ? 1,2,3, belts ?
    Or
    If not , will it be 1/2 drive?
    If so post pic of , I do not think I see one done that way what I am picturing in my head.
