Technical Help my 40 ford ride better?
Discussion in 'The Hokey Ass Message Board' started by Busmania, Aug 15, 2025.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, it is this car, it has been that way since 1964..... astorianchadly2.jpg
    dana barlow and anothercarguy like this.
  2. krylon32
    krylon32
    from Nebraska
    I'm a deuce guy but love my 40 coupe. I put a fresh Mustang 8" rear under it with a CE parallel leaf rear suspension and 2 inch blocks. The front is a 4 inch magnum with a Posie low spring, P&J's shock kit, Bell power stoppers with 8 inch booster and 525 steering.. Drives and rides great.
    PONTNAK123 likes this.
  3. ALLDONE
    ALLDONE
    I would have took the shocks out and went for a ride......then got shorter shocks.....could also of put stock model a shocks... doesn't take much
  4. Busmania
    Busmania
    from Denver
    Yes I did take the shocks off and drive around. It was very bouncy and kinda scary going over any decent sized bumps at speed.
    re shorter shocks. I didn’t feel like spending any money…yet. Wanted to make sure I understood my issue. Now that I know what works, ill probably look for shorter shocks so I can remove the brackets I made.
    ClayMart likes this.
  5. RonaldR
    RonaldR
    I must be missing something here,in my 70 years of fooling around with these old Fords, I've never seen the short leaves put underneath like that. I guess that you're never to old to learn something new.
    Onemansjunk likes this.
  6. Dan Hay
    Dan Hay
    I may not understand fully your setup, but you shouldn’t need to move the mounts, just get a shorter shock. Because now you have a shock that is fully compressed at ride height, you just need a shock that has the same measurement halfway through its travel.
  7. Dan Hay
    Dan Hay
    that’s so the spring stays the same width for the spring clamps to do their clamping. You can make a spacer after removing leaves from the pack, but putting the leaves on the bottom works too.
    Onemansjunk and hotrodA like this.
