Projects Finding an old Kustom
Discussion in 'Traditional Customs' started by Sum54ford, Aug 8, 2025.
  1. Dan Hay
    Dan Hay
    The history and all the pictures really makes it special!
  2. RodStRace
    RodStRace
    Brakes and fuel, check.
    I'd look at the cooling system too. 20 years with dissimilar metals does funny things.
    The Ford distributors tend to lock up over time, too. Give the base a little spray.
    I remember that mag! It's probably on the shelf, but I know better than to start diggin'.
  3. Sum54ford
    Sum54ford
    from St. Louis
    Here is the Low Rider in the KKOA book. Gene was member #59 so he must’ve been an original guy to join.
  4. tbirddragracer
    tbirddragracer
    Man, what a great find.
    E
    porkshop and Sum54ford like this.
  5. Hubnut
    Hubnut
    Pretty certain I have a photo or two of this Merc somewhere. Most likely from the Hangin Dice Nationals in the late 90s. If I run across them I will post them up for ya.
  6. rob-redm
    rob-redm
    Congrats !
  7. T. Turtle
    T. Turtle
    Nice car done right. Honestly I would not have said it's an 80 build, it could have come straight out of the early 50s.
  8. Sum54ford
    Sum54ford
    from St. Louis
    I got the Merc up in the air to start tearing into it. I got the old gas tank and fuel lines out. I’m going to turn the brake drums today and replace all the brake parts. IMG_7292.jpeg
    I took out all the rear suspension too. I’ve got new 4” dropped leaf springs coming. So it will get new springs, blocks, u-bolts, shocks and bushings. IMG_7293.jpeg The car had these really old lowering blocks double stacked on each side. IMG_7294.jpeg
    Her is how the back of the master cylinder looked. Nice and toasty.
  9. 54delray
    54delray
    from Fremont NE
    Holy master cylinder, Batman!
  10. sideswipe
    sideswipe
    I remember Gene. He and my dad became good friends. They met at the first merc/deuce reunion in 79 and stayed in touch after. The merc was purple back then. I'm glad to see the old girl coming back. Well done!
  11. Sum54ford
    Sum54ford
    from St. Louis
    That is awesome, your Dad had some great Mercs!
    Here is the Merc at the 79’ Merc Deuce Reunion.
  12. Sum54ford
    Sum54ford
    from St. Louis
    I got the new 4” dropped springs from St. Louis Spring today. Here is a side by side comparison. I also turned all 4 drums over the weekend and cleaned and painted underneath the car to prepare for the new gas tank to go in. I pulled the radiator out to have it cleaned and started to clear parts out of the way to remove the engine for a good clean and re gasket and paint.
  13. Saweeet! Congrats,it's really :cool:!!
  14. Sum54ford
    Sum54ford
    from St. Louis
    IMG_5799.jpeg IMG_5800.jpeg IMG_5804.jpeg IMG_5805.jpeg IMG_5806.jpeg IMG_5798.jpeg
    Here are some more build pics of the Merc. Here it is getting the top chopped at Custom Jim’s Shop in I believe 1981.
  15. Sum54ford
    Sum54ford
    from St. Louis
    It also got a new hood to replace the louvered one that was on it when it was purple. The hood corners were also rounded.
  16. guthriesmith
    guthriesmith
    So cool that you got all that history with the car! That is priceless! :cool:
    Okie Pete, drdave, 54delray and 4 others like this.
  17. Kid Rocker
    Kid Rocker
  18. Austinrod
    Austinrod
    from Austin
  19. Sum54ford
    Sum54ford
    from St. Louis
    I pulled the engine and transmission this weekend to install all new gaskets and clean and paint everything. Things are moving right along.
  20. drdave
    drdave
    You are a busy little beaver!!!
  21. Sum54ford
    Sum54ford
    from St. Louis
    Pushed the Merc out of the garage this weekend to power wash everything under the hood and frame so it can all be repainted. So I washed the car too. Can’t wait to get it back on the road.
  22. glendale
    glendale
    man what a cool find. and way to keep making progress so fast!
  23. guthriesmith
    guthriesmith
  24. 59sedandelivery
    59sedandelivery
    Damn that BABY is Gorgeous!!!!!!!
  25. Sum54ford
    Sum54ford
    from St. Louis
    I took out the original torched front coil springs. It’s hard to believe that this thing has had heated springs in it for so long. Yeah the shocks are toast too. IMG_7385.jpeg
    Here are the new Aerostar springs next to the old ones. IMG_6154.jpeg All the front end parts were removed, blasted and painted. It’s all ready to go back in now.
  26. drdave
    drdave
    Once you are done running through this thing, can you whip down here and get the front suspension thrown under the Lavender Lady since you are so fast and I am not? Haha!! Nice job!!!
    catdad49, 54delray, porkshop and 6 others like this.
  27. guthriesmith
    guthriesmith
    After you are done at Dave’s, my 56 needs a front end rebuild as well. :D
  28. Sum54ford
    Sum54ford
    from St. Louis
    I tell you what it’s a dirty job getting the front end out and cleaning and restoring it. It’s always my least favorite part of the job. I’ll come do the Lavender Lady but that means I will have to do some long test drives. :D
  29. Okie Pete
    Okie Pete
    When you get those two jobs done . I’ve got a 47 Mercury that needs front end work. I’ll even feed you some home grown beef steak
    catdad49, 54delray, porkshop and 4 others like this.
  30. drdave
    drdave
    You ain't kidding about a dirty job. I'm half way through dis***embly on the Chevy and I think I've gone through 3 sets of clothes and 65 rags to get that far. LOL
    John B, catdad49, 210superair and 5 others like this.
