Projects 31 Kustom Roadster (DIY duvall, tudor to roadster conversion)
Discussion in 'Traditional Hot Rods' started by Chevy28, Feb 13, 2020.
  1. HelminenHotrods
    HelminenHotrods
    from Finland
    Thanks guys for comments ! Reminds me to write new updates :
    Brakelines are done and bleeded.
    That one "extra" line i did for the hydraulic clutch, but i think its better run shorter route.
    20250609_171010.jpg 20250321_221204.jpg 20250321_221149.jpg 20250321_221449.jpg 20250321_221346.jpg 20250321_221326.jpg
    Through frame fittings:
  2. HelminenHotrods
    HelminenHotrods
    from Finland
    And heres outcome of the hydraulic setup i made. More of that later on : 20250425_214824.jpg
  3. pittaway
    pittaway
    from england
    fantastic build, just read the whole thing, what wheel / tyre combo are you running? looks incredible
    Tow Truck Tom likes this.
  4. 1-SHOT
    1-SHOT
    from Denton
    Love the detail in your build and yes You can weld aluminum foil together. Did on my Lincoln TIG . IMG_8650.jpeg IMG_8649.jpeg
  5. HelminenHotrods
    HelminenHotrods
    from Finland
  6. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you !
    Wheels are Wheel Vintiques gennie, 40 ford repop.
    Tires are : rear firestone 7.50x16 and front firestone 4.50/4.75x16
    Okie Pete and Tow Truck Tom like this.
  7. neilswheels
    neilswheels
    from England
    Just wow! That steering wheel, and everything else, is so cool.
    When you welded the wheel, was there any issues with the surrounding wheel resin?
  8. HelminenHotrods
    HelminenHotrods
    from Finland
    Thanks man !
    There was not really issues welding the steering wheel, when prepared for the job right.
    -First cut was about inch longer than the wanted lenght left.
    -Then i pealed of the resin ( or whatever material the steering wheel surface is )
    So i had more bare metal to weld on.
    - i also ziptied wet rag around the resing. And cooling of with air also.
    So not really issues. A bit of burning rubber smell only when welding real close.
    Tow Truck Tom and Outback like this.
  9. MMM1693
    MMM1693
    I feel like such a hack
  10. HelminenHotrods
    HelminenHotrods
    from Finland
    The hydraulic clutch setup :
    Not too many in process pictures but heres the highlights.
    -As mentioned earlier i polished the bellhousing... well... AFTER polishing, i removed the clutch fork ball and found out it was cracked from the thread to the center hole..
    Note to self ! Double check everything before you polish old cast turd ! 20250320_204123.jpg
    Aint gonna fix that, so new bellhousing was bought.
    Because using the hydraulic setup, and the limited movement of the cylinder,
    i measured the clutch fork movement on table.
    This is somewhat theoretical but knowing what is the stroke of the cylinder. And from mcleods clutch info (and others) how much the throwout bearing needs to move, to disengage the clutch, i was able to determinate how i need to do the clutch fork.
    20250415_184359.jpg 20250424_190631.jpg 20250424_190614.jpg 20250424_190733.jpg 20250424_190704.jpg
    And i needed to build mount for the slave cylinder.
    At first i tried how it would act mounted to frame, but so much of the stroke movement was wasted on engine/trans rubber mounts flexing.
    This mount is also part of the transmission mount.
    20250424_195303.jpg 20250424_195323.jpg 20250424_195335.jpg 20250424_195351.jpg 20250424_195407.jpg
    Muncie is cool, but the shifter and linkage makes everything harder.
    20250425_214824.jpg 20250425_215000.jpg 20250425_214842.jpg 20250425_215029.jpg
    Okie Pete, Tim, Tow Truck Tom and 6 others like this.
  11. HelminenHotrods
    HelminenHotrods
    from Finland
    Needed to ad an return spring for the clutch fork. Just to make sure the throwout bearing really disengages.
    Heres the mount i build 20250426_211442.jpg 20250426_211457.jpg 20250426_211350.jpg
    20250426_212317.jpg 20250629_003639.jpg 20250426_212601.jpg 20250629_003723.jpg
    Okie Pete, Tim, Tow Truck Tom and 7 others like this.
  12. patsurf
    patsurf
    Outback and HelminenHotrods like this.
  13. HelminenHotrods
    HelminenHotrods
    from Finland
    Been slacking on updates here, but have not been slacking in garage.
    Starting with handrake/emergancy brake handle.
    And again not so traditional correct, or streetrodders lokar.. but heres what i came up with an bmw handle :
    Did this stainless steel sleeve :
    And knob :
  14. HelminenHotrods
    HelminenHotrods
    from Finland
    Bolt mount X-member crossmember.
    Making life, or atleast engine/transmission removal easier by building an bolt mounted crossmember.
    20250628_192255.jpg 20250628_192122.jpg 20250628_192026.jpg 20250628_192052.jpg 20250628_192045.jpg
    Tim, Okie Pete, Happydaze and 10 others like this.
  15. Outback
    Outback
    from NE Vic, Oz
    Nice work. Thanks for the updates
  16. rod1
    rod1
    Everything about this car is Cool. The hours spent to build every layer on every bracket is mind numbing. The Path down the Art Deco period is so labor intensive, yet nothing can touch the resulting feeling it invokes .Tatistta.
  17. HelminenHotrods
    HelminenHotrods
    from Finland
    Thanks you very much ! It does sometimes feel like building brackets, loads of brackets, and not a car :D
    But thats why its_building_ a car, not ***embling.
  18. HelminenHotrods
    HelminenHotrods
    from Finland
    More of the x-member center.
    Did not take any process pics other than this.
    Handbrake handle is as low as possible. Dont want it sticking out too much.
  19. 1-SHOT
    1-SHOT
    from Denton
    Love the progress you are makeing. Frank
  20. HelminenHotrods
    HelminenHotrods
    from Finland
  21. HelminenHotrods
    HelminenHotrods
    from Finland
    Handbrake bits and pieces :
    Connecting and making that bmw lever work with chevy 10bolt brakes.
    Deciced to keep it as easily replaceable as possible. So stock gm cables from the back, and stock bmw cables in front which are shortened with threaded ends.
    And here are the little inventions what made me happy !
    There are cable connectors in the market, gm stock etc, but they did not seem too impressive to me, and of cource in Finland they must have been ordered from USA and waited a looong time.... So i made my own :
    20250709_230554.jpg 20250709_230600.jpg 20250709_230624.jpg 20250711_175721.jpg
    And here it is mounted:
  22. HelminenHotrods
    HelminenHotrods
    from Finland
    Video of the cable connector.
    And sorry if these videos looks goofy on computer, im posting everything on phone :D
    Tow Truck Tom, Outback, SR100 and 5 others like this.
  23. James D
    James D
    What an amazing build. I don't know how I missed this. I can only wonder at some peoples skill.
  24. HelminenHotrods
    HelminenHotrods
    from Finland
  25. patsurf
    patsurf
  26. HelminenHotrods
    HelminenHotrods
    from Finland
    Not really sure what welds and joints you meaned. But that squere tubing is just subframe, which has been cutted and added along the build. Keeping the body stable before floors, and i can work from the top before building floor panels
    Tow Truck Tom, Outback and GuyW like this.
  27. HelminenHotrods
    HelminenHotrods
    from Finland
    Building exhaust mounts.
    The exhaust has to run throught frame, so the mounts has be very stable.
    20250724_201201.jpg 20250724_204124.jpg 20250807_203533(1).jpg 20250807_203739(1).jpg 20250807_204239(1).jpg 20250806_214345.jpg 20250806_214413.jpg 20250812_210314(1).jpg 20250812_211145.jpg 20250819_213746.jpg 20250818_201454.jpg 20250819_211647.jpg
  28. HelminenHotrods
    HelminenHotrods
    from Finland
    And couple random pics of the car for a change, so you dont forget where all those parts are going :D
    Finnrodder, simplestone, Tim and 3 others like this.
  29. 59sedandelivery
    59sedandelivery
  30. ronzmtrwrx
    ronzmtrwrx
    You are doing some very crafty work. I like the way you think.
    rod1 likes this.
