Need help on GM suspension I.D.
Discussion in 'Off Topic Hot Rods & Customs' started by Bullit68, Aug 22, 2025.
  1. Bullit68
    Bullit68
    from Verona, PA
    I have a ‘53 Chevy 210 sedan that has had some upgrades done, ‘77 350 w/tbi heads, TH400, 9” Ford rear end. Has a front crossmember grafted into the frame with R&P steering. One upper bushing is bad, need to figure out what is here. Here is a pic of the RH upper control arm. Thanks!
    hrm2k likes this.
  2. squirrel
    looks like you got a Pacer front end. More pictures of the whole thing might help confirm.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
  4. Bullit68
    Bullit68
    from Verona, PA
    Who in their right mind does that?
    hrm2k likes this.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    From what I’m seeing it fit’s very well.
  6. Budget36
    Budget36
    Maybe the Mustang 2 was too wide;)
    hrm2k likes this.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
  8. Bullit68
    Bullit68
    from Verona, PA
    I guess more common than I thought! Looks like that’s what was grafted in! I’d never have figured it out without asking here. Thanks guys!
    squirrel likes this.
  9. Bullit68
    Bullit68
    from Verona, PA
    I’ve got two bad upper control arm bushings… nothing is easy…..
  10. squirrel
    In the later 80s Pacers were really cheap, no one wanted them, and turns out it's a good fit in lots of cars and trucks. Now that they're almost 50 years old, not so good of an idea in hindsight.
    lostone and hrm2k like this.
  11. Bullit68
    Bullit68
    from Verona, PA
    yeah, parts for it are “limited availability” for sure.
    I see $$$ leaving me soon! The PS pump leaks and has a bent double pulley. But that part was used on GM cars, so that can be sourced. UCA bushings are scarce…
  12. Bullit68
    Bullit68
    from Verona, PA
    I’ll check that out
  13. DDDenny
    Jim
    A friend of mine put a Pacer front in his girlfriends' 65 Nova in the late 70's, this was before we bought our Nova, long before I knew the realities of the Nova OEM front suspension.
    He said it worked good, he also said just about anything would have been an improvement.
    Bullit68 likes this.
  14. Rolleiflex
    Rolleiflex
    Maybe I'm too optimistic, but if I were you I'd call someone like Energy Suspension. Control arm bushings are just round with a hole for the cross shaft. I bet if you measure the inner and outer diameter something they have would fit.
    RMR&C and Bullit68 like this.
  15. Bullit68
    Bullit68
    from Verona, PA
  16. blue 49
    blue 49
    from Iowa
    I put a Pacer crossmember under an AD truck with instructions and mount kit from Ch***is Engineering. Worked fine.
    Gary
  17. oldolds
    oldolds
    Pacer. Corvair, and Volare front suspensions were popular before Mustangs became popular. They were easy bolt in suspensions for a lot of vehicles. Each had it's problems.
    Pacer was a low production vehicle. Brake parts were always expensive compared to other vehicles. I know I had difficulty finding parts for one about 15 years ago. I doubt finding parts for them has gotten any easier.
  18. Bullit68
    Bullit68
    from Verona, PA
    Yeah, I’m finding that out now…
  19. DDDenny
    Have you tried Kanter?
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    eBay has lowers and there’s a vendor that caters to AMC’s that has uppers.
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Not cheap https://www.amclives.com/ but while looking amclives again Autozone came up showing them but need to be ordered.
  22. Bullit68
    Bullit68
    from Verona, PA
    $130 for two…. Yikes!
    Johnny Gee likes this.
  23. Bullit68
    Bullit68
    from Verona, PA
    looks like $60 each
  24. DDDenny
    Is that a deal breaker?
  25. @Bullit68 , sent you a PM regarding bushings!
    Bullit68 and Johnny Gee like this.
