Spray Cans HD Gas Tank
Discussion in 'Off Topic Hot Rods & Customs' started by panhead_pete, Aug 21, 2025.
  1. panhead_pete
    panhead_pete
    Hi Fellas Im planning to paint a new gas tank for my Harley. It will arrive raw. I dont have a compressor etc so wanting to do this with spray cans including primer, filler, paint and clear. Will most probably be gloss black at this stage. Whats the current go to brand to do this? Thanks. Pete.
    swade41 and mitch 36 like this.
  2. nunattax
    nunattax
    sporty or fat bob style tank.
  3. panhead_pete
    panhead_pete
    Aftermarket 14L Sporty style tank
  4. Sharpone
    Sharpone
    Okie Pete and panhead_pete like this.
  5. jnaki
    jnaki
    Hello,
    My last spray was on a custom scooter for our granddaughter. I had to sand the old tube handles and used a fine grit wet dry paper first. Then a flat primer. Finally, I used the Rustoleum high performance enamel for the final coats. (Two)
    Now, a drop or ding on the paint would last a few rounds of rough “kid” play. Plus, it looked good, shiny, and solid… no runs… several light coats was best for the application.
    I also used this to coat several flat metal plates I used at home for another project. No, it looks chrome on the cap, but it is just a little brighter silver than the normal silver paint from the same company. So, don’t be fooled by the cap. In the racks, it looks as if you can buy a chrome paint that looks like chrome. YRMV
    Jnaki
    I have never had the use of clear polyurethane for a final metal paint coat. But, I have used the clear poly urethanc on wood for a good seal from the weather and as long as nothing hits it or makes a deep scratch, the clear coat is solid and protects like no other. But, on wood, one ding and it could start the weeping of weather/water into the surface.
    The matte finish looks better on wood, but for metal, one might want shiny or the gloss version.
    Okie Pete, Sharpone and panhead_pete like this.
  6. slowmotion
    slowmotion
    I've found S E M to be a step above hardware store varieties. OTOH, we did a BSA chopper (w/Sportster tank) that got a two page spread in "The Horse" bike magazine some years ago with Krylon (1316 IIRC). YMMV.
  7. RodStRace
    RodStRace
    Considering your location, I don't know if the formulas are the same.
    That said, Krylon really has been one of the rare companies that hasn't visibly made the product worse, hasn't stepped into the news in a bad way, and seems to be readily available in case of touch ups. They also offer various types of paint; enamel, lacquer, clears, etc. for you to choose from.
    The same might be said for Rustoleum.
  8. panhead_pete
    panhead_pete
    Cheers I have a US shipping address so all good there.
    Sharpone likes this.
  9. oldolds
    oldolds
    Upol products are good for under coat products. They were recommended to me by a friend that works at a BMW dealership. They use them for small repairs. Here in the States we can get most automotive paints put into spray cans. (Look on one of the auction sites). I have done as much as a fender or a door that way.
    You can get base coat or single stage.
    The spray cans of paint are about $40 . 2 cans of paint will do most fenders easily. There is also no time wasted cleaning the spray gun.
  10. There are some companies that sell catalyzed paint in aerosol with a ****on on the bottom that releases the activator. That would be my recommendation. You have better durability with high end paint materials.
  11. deathrowdave
    deathrowdave
    from NKy
    Gasoline is not one’s friend on a motorcycle tank . I prefer a urethane base paint , dried under a lamp . Nothing worse than filling up at the last stop for 150 miles and 2 miles from the station , paint is running off or discolored .
    panhead_pete, rustydusty and Sharpone like this.
  12. rustydusty
    rustydusty
    IMG_0959.jpeg IMG_1026.jpeg Yep, gotta be fuel proof. The tank on a BSA I had was painted at a professional paint shop. This happened when it got its first tank of gas, and I didn’t realize that it was leaking around the pet****…
    Deuces likes this.
  13. rustydusty
    rustydusty
    Show quality paint job and it made me wanna puke…
  14. panhead_pete
    panhead_pete
    Ah man what a bummer!
  15. Sharpone
    Sharpone
    That really ****s. What kind of paint, was it lacquer?
    Dan
  16. swade41
    swade41
    from Buffalo,NY
    I used Rustoleum about 11 years ago and it's still holding up great
    Deuces, ronzmtrwrx, Sharpone and 3 others like this.
  17. panhead_pete
    panhead_pete
    @swade41 Nice Shovel! Couple questions if thats OK
    Was that the engine paint or their normal fare?
    Did you use a clear?
    Did you use Rustoleum for the flames?
    Thanks.
    Sharpone and swade41 like this.
  18. swade41
    swade41
    from Buffalo,NY
    Normal paint, no clear and yes flames are Rustoleum too. I did wash it with car soap that had some kind of wax in it, so it put a little more sheen on it.
    20200712_174039.jpg 20200712_174103.jpg Screenshot_20220712-110240_Gallery.jpg Screenshot_20220712-105804_Gallery.jpg
  19. jimmy six
    jimmy six
    Max 2K Glamour Clear if you want shiney. They do have Max 2 K in Black so no base coat needed. EZ to color sand cut and buff. If it’s shiney you want out of a can …it can’t be beat!
    panhead_pete and Sharpone like this.
  20. panhead_pete
    panhead_pete
    Thanks @swade41 , really appreciate that, particularly the pics of doing the flames.
  21. panhead_pete
    panhead_pete
    Cheers
