Projects Glass '32 5 Window
Discussion in 'The Hokey Ass Message Board' started by Splitbudaba, Feb 6, 2017.
  1. lurker mick
    lurker mick
    That's tough, but I'm sure she has left you some great memories.
    Mick
    catdad49 and Splitbudaba like this.
  2. The 39 guy
    The 39 guy
    Sorry for your loss, I have had comfort two treasured dogs while they went for their final nap recently, thankfully they had much longer lives. Our vet was very accommodating and showed a lot of empathy which helped. Treasure the memories.
  3. Splitbudaba
    Splitbudaba
    Got the coupe out, put 5 miles around the neighborhood. It was 93 degrees, 55 psi oil pressure, 180 temp, 14 volts from the gen. Steering tight, brakes are great, no leaks.Got a lot of thumbs up. Fun, fun, fun!!
    Tim, Tim_with_a_T, swade41 and 4 others like this.
  4. RodStRace
    RodStRace
  5. Splitbudaba
    Splitbudaba
    Had the coupe out again. Squared up the front end, fixed a couple little issues. Set the idle and mixtures
    Runs great. Now I must center the steering wheel and fix an exhaust hanger. PXL_20250803_022909014.jpg PXL_20250803_023417339.jpg PXL_20250803_023015106.MP.jpg
    49ratfink, big duece, GuyW and 15 others like this.
  6. Splitbudaba
    Splitbudaba
    catdad49, Tim, guthriesmith and 7 others like this.
  7. Bandit Billy
    Bandit Billy
    Cool photo but how the hell do you get a sofa through that front door?
    49ratfink, Tim, Splitbudaba and 2 others like this.
  8. Splitbudaba
    Splitbudaba
    It's wider than it looks. Besides we get all our stuff delivered, so no sweat!!
  9. DDDenny
    I delivered furniture part time while in high school............you should sweat it.
    Deuce coupes rule!
    Algoma56 and Splitbudaba like this.
  10. Splitbudaba
    Splitbudaba
    Good point!!!
    Algoma56 likes this.
  11. Splitbudaba
    Splitbudaba
    OK, grief part is behind me. Started back on the coupe, found out that's the best therapy!!! Working on the switch panel, windshield, secured the hard brake lines on the rear. Ty-raps just didn't cut it. Secured the battery and it's vent lines. All that's fine but makes for boring pictures. Plan on painting the windshield frame metallic silver, with the body opening primer red. Now I can concentrate on putting some miles on her, along with some trust!! Wish me luck!!!
  12. Splitbudaba
    Splitbudaba
    Windshield in and seals. PXL_20250823_193448548.jpg PXL_20250823_193442179.jpg
  13. Splitbudaba
    Splitbudaba
    Lowered the air cleaner base about an inch. Cleared all the controls. Only issue were the float adjustment hardware. Cut some holes and made some bump ups out of 1 inch copper pipe caps trimmed down. JB weld and some paint finished off the job. Not a big change, but I like the results
    PXL_20250825_222315126.jpg PXL_20250826_162654368.jpg PXL_20250826_170708396.jpg PXL_20250826_170703728.jpg
  14. Bandit Billy
    Bandit Billy
    I like it and the cutouts you made for the float screws will prevent the base from turning and possibly jamming the throttle. cool.
  15. Splitbudaba
    Splitbudaba
    Time to put the air cleaner on tomorrow along with 20 miles or so.
    Can't wait!!!
  16. Bandit Billy
    Bandit Billy
    I was watching an old episode of the Gran Tour, those ****s were in Africa driving dune buggies, and the ape put a V8 in his wannabe Manx. The low-rise air-cleaner would vibrate around until it pinned the throttle open. He couldn't come up with a sane idea to prevent that. You did! Bravo
    Tim and Splitbudaba like this.
  17. Splitbudaba
    Splitbudaba
    I love just sitting there coming up with a different twist on things. My whole car was built that way. I am almost sad to be coming to an end! But I have discovered it's a fricken blast to drive!! I figure I will drive it to work the kinks out. Then pull it apart for better paint. Still like the red oxide for a final color, firewall and belly an off white. Time to start thinking about interior choices!
    catdad49 likes this.
  18. pprather
    pprather
    I like your progress.
    If you are going to do better paint on the body, why not real paint?
    In primer, the uninformed will always call it a rat rod, despite the build quality.
    Also, back in the day, yes, there were 'in progress' rods with primer, but every rodder's aspiration was to have a gloss paint finish that was at least as good as brand new oem paint jobs.
    Love your build,
  19. Splitbudaba
    Splitbudaba
    My last build, a 63 Corvette actually won best paint awards at the Boise Roadster show and many other local events. I did all the paint myself, I didn't have any fingerprints for at least a year. Between the labor and the current cost, primer makes me happy. Get a Nick, no problem! Plus I might change my mind, you never know!! IMG_1610.JPG
    rod1, catdad49, Algoma56 and 9 others like this.
  20. DDDenny
    A friend of mine built quite a handful of cars, most of them primered, on a regular basis, he got the "when ya gonna paint it", he got pretty adept at replying "primer is paint"!!!
    Splitbudaba likes this.
  21. Splitbudaba
    Splitbudaba
    Gotta remember that!?
  22. Splitbudaba
    Splitbudaba
    Oh yeah!! Just put, 17 miles on the coupe.
    Ran great! Steering is tight and responsive. Brakes work great, light pedal pressure, nice straight stops. Got loads of waves, thumbs up, and a guy took pictures. Great evening. Oil pressure at 55, water temp 180, and the old gen stayed at 14.2 volts!!! Life is good!!
  23. DDDenny
    Good times, you earned it!
  24. Splitbudaba
    Splitbudaba
    Thanks, felt great!! Much more to come!
  25. Great car! I like your paint choice, l did the same on my 34 PU with charcoal windshield frame.
  26. Splitbudaba
    Splitbudaba
    I appreciate all the input, but the final color is my choice! Red oxide primer is still my first choice! Off white belly and firewall. All the aluminum, radiator and the shroud satin black.Chevy orange SBC with flat black exhaust system. Interior will also be black and white.
    Bandit Billy and swade41 like this.
  27. RodStRace
    RodStRace
    @Splitbudaba You build it for YOU!
    I keep pondering body and paint on my lil project. I keep going back to "Will it take time and money to achieve a higher level, and will that detract from time enjoying it and other wants and needs?"
    It's going to be primer for a while! Especially when it's fenderless and resources are limited.
    You've put in the time and effort for a ton of details that make you happy. You know you can do a super paint, so it's a choice. As Rick Nelson says
    www.youtube.com/watch?v=pL172v6FC_Q
  28. swade41
    swade41
    from Buffalo,NY
    What color for the frame ?
  29. DDDenny
    That's the beauty of it!
  30. Splitbudaba
    Splitbudaba
    Most of the interior will be black, with white accents. Maybe some stainless thrown in for good measure. Time will tell!
    ekimneirbo likes this.
