Projects Bought a 51 Ford on Purpose
Discussion in 'The Hokey Ass Message Board' started by guthriesmith, Aug 11, 2025.
  1. guthriesmith
    guthriesmith
    Tried to go get the ***le swapped over and get a tag for this yesterday, but a power outage knocked out the system at the tag office. Also, didn't work on it last night since I went and picked up the next project from a friend and fellow HAMBer. I did have to move it out of the shop this morning to move the panhead in. Anyway, won’t talk about the next project here, but hope to get the front of the 51 lowered early next week. :D
  2. tubman
    tubman
    Here's my '51 with stock springs :
    Here's my '51 with Moog Aerostar springs :
    Compare the "spear" on the front fender with the edge of the whitewall.
  3. guthriesmith
    guthriesmith
    Looks like about 2” or so? Also looks like you flipped the shackles in the rear to change it as well?
  4. tubman
    tubman
    Right.
  5. mlagusis
    mlagusis
    Looks very nice here Jeff! Those wheels and tires were a huge improvement
  6. 210superair
    210superair
    from Michigan
    Man I want some skirts after this thread.... Lol. Only if I could drop it reeeaaaallllllll low tho. Mine is about what you can do without notching the back, and I ain't gonna take apart a car that's finished for all that jazz.
    Next one...
    Car looks great Jeff.
  7. Fat47
    Fat47
    I'll be interested in whether the Old's caps stay on when you drive it. I have a set I would like to use on my 50 but have read a number of reports of them coming off when driving so I'm hesitant.
  8. CSPIDY
    CSPIDY
    Great car, like where it’s going
    I spent some of my childhood in the back seat of a 51 4door.
    Great memories
  9. guthriesmith
    guthriesmith
  10. lostn51
    lostn51
    from Tennessee
    Damn Jeff that’s some pretty chrome!!:cool:
  11. lostn51
    lostn51
    from Tennessee
    If you swap out to the Aerostar springs you need this to be able to get the geometry back to where you need it. Also you’ll more than likely need to shim the A arms out so grab some of them. I think I needed an 1/8” to 3/16” to get mine right.
  12. guthriesmith
    guthriesmith
    Well, not sure it is low enough in the front yet. But, if it’s anything like my 56, it will likely still sink an inch or so over time too. About too dark to get a good pic outside. Pretty sure it came down right at 2” in the front and 3” in the rear. May be good enough for a while. I’ll see. I do need to cut the bump stops or remove them. I can bounce it off them now. I also need to put the shocks back on or see if I need shorter ones.
  13. guthriesmith
    guthriesmith
    Tire is not quite flush with the wheel well. Hmm…
    Also, specs on the Monroe 5821 show the collapsed length to be only 1/2” shorter than the ones that were on this car. Guessing I can get away with these same shocks at least for now. Might as well use what I have if I can. They appear fairly new.
  14. Looking great! (still a tiny bit tail dragger-ish, but like you said, that might settle down a bit)
  15. tubman
    tubman
    I had put new stock spec shocks on my car a year or two before I installed the Aerostar's. I have had no problems with them.
  16. guthriesmith
    guthriesmith
    Also, just using a level, camber is real close on the p***enger side, but it’s in at the top on the drivers side. I think I’ll probably leave it like this for a while. I need to pull a clutch on my youngest son’s car. So, this may be on the back burner a few days now until I can get that done.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    Can you space the spring pocket part of the control arm down to lower it more???
  18. guthriesmith
    guthriesmith
    Yes, and I have some spacers already that I made for the 56. I’ll see after I put a few miles on it.
  19. dwollam
    dwollam
    I used Aerostar springs in my '51 coupe to replace cut stockers. Installed new short bumpstops and used stock shocks no problem. Lowered a touch from the cut stockers and really firmed up the cornering! Big improvment. It had 3" blocks in the rear and I'm not a big tail dragger fan so I cut them to 1.5" as the rear springs a a little flat (sag). Like it much better as with 3" the driveshaft rubbed.
    Dave
  20. lostn51
    lostn51
    from Tennessee
    Looking good!!
    porkshop, winduptoy and guthriesmith like this.
  21. guthriesmith
    guthriesmith
    I had to go back and do a comparison of where I started and where I am now. When I consider I have now owned it for exactly 16 days, I guess I have done ok. Not much work involved, but had to get it stopping and lowered. Bonus that I tripped across a set of wheels and tires to get the look I was going for in the last two weeks. I may try to go see what wheel covers the guy in the town where I work has today.
  22. 210superair
    210superair
    from Michigan
    Looks great, like the changes so far.
  23. Mikko_
    Mikko_
    from Sweden
    Looks good, will be even better with full caps.
  24. MMM1693
    MMM1693
    I like it!!!
    porkshop and guthriesmith like this.
  25. 05snopro440
    05snopro440
    Saw this at a little show on Saturday, reminded me of yours so I thought I'd share.
  26. tubman
    tubman
    The best looking of all the shoebox Fords. Out of an act of necessity.
  27. alanp561
    alanp561
    '58 Pan?
    chryslerfan55 and porkshop like this.
  28. guthriesmith
    guthriesmith
    It’s actually a 54 but in a 58 or 59 frame.
  29. 53olds
    53olds
    Your on the right track, I'd have to cut a coil or 2
    :D
