Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. Onemansjunk
    Onemansjunk
    from Modesto,CA
    602FAA63-1197-422F-B31E-6C01B324FA0D.jpeg 41734251-61BD-4773-AF88-7C3C0064C60B.jpeg 32083860-CA50-45EB-8EF8-8C5CBF1E2490.jpeg 4392A860-4872-4EFB-8E94-F111ACA1A954.jpeg 986F2464-B2A7-467E-B217-9044DE047F38.jpeg
    I made mine from an old treadmill, little more compact.
    jet996, GuyW, 2devilles and 11 others like this.
  2. Onemansjunk
    Onemansjunk
    from Modesto,CA
    191F09D0-F77B-4353-B01C-6EACCFB4BED8.jpeg 1951BBCF-DE5F-48A2-94BF-51C0A3C0509C.jpeg 2AB00F8C-1014-4C38-897C-4FEB1A33BB15.jpeg FA3D2E95-B92E-40B7-8868-120EAC55A5FB.jpeg This little guy is a big help. Keeps my soldering iron from melting me and everything else. Made from Junk.
  3. Donut Dave
    Donut Dave
    Made one for my heat shrink gun.
  4. patsurf
    patsurf
    rpm56, Onemansjunk, Sharpone and 2 others like this.
  5. Fabber McGee
    Fabber McGee
    Treadmill motors are perfect for a drill press too.
    jet996, tguptill, Sharpone and 3 others like this.
  6. Six Ball
    Six Ball
    from Nevada
    And for a lot of old machine tools for those of us who don't have 220. Finding the right ones can be confusing.
    Tow Truck Tom and Sharpone like this.
  7. leon bee
    leon bee
    I had a little hand tool save my *** yesterday. I may have first heard of it here on the HAMB, a Vessel Impacta screwdriver. Only needed it a few times, but really needed it. A light duty impact screwdriver, for small stuff, JIS tip, like Phillips, but fits Japanese style screw heads better......works fine on ragged old small Phillips. Good for brand new screws, too, saves marking them up. No picture, Google find it easy.
    RICH B, jet996, Tow Truck Tom and 3 others like this.
  8. blue 49
    blue 49
    from Iowa
    My old wood-cutting bandsaw re-powered by a treadmill motor. Jackshafted down to cut steel. The motor controller is from E-Bay.
    Gary
    Sharpone, jet996, ekimneirbo and 8 others like this.
  9. Onemansjunk
    Onemansjunk
    from Modesto,CA
    FD720507-AA67-45E2-81F7-40A76D945182.jpeg 947141D3-C173-47F8-B429-842BC72A2B42.jpeg 1D40FFDA-09F3-4DF2-A450-6CA9E0377AC9.jpeg Who knows what Dad was up to.
    Sharpone, loudbang, TagMan and 3 others like this.
  10. Six Ball
    Six Ball
    from Nevada
    Heating the shop or thawing the pipes? Making coffee?
    Sharpone likes this.
  11. jnaki
    jnaki
    Hello,
    I knew there was an old photo of the variety of cords to be rolled up on our devices. The old photo was taken on a leather couch we gave to our granddaughter. It was a sectional sofa to allow her to have a nice place for her friends to sleep on late night "girl's night out" adventures. It was too low and wide for us old folks after several years.
    But, it made a nice flat platform location for the myriad of corded items in need of some order and neatness. Now, when I grab one item out of the digital file container, I only grab the corded one I need. not a bunch of loose wires.
    Jnaki
    This arrangement has p***ed My wife's seal of approval for neatness and organization. She even uses the Apple phone charger corded clips and other wires all rolled up neatly in her own drawer for Apple products. There are a few Android cords/chargers in that photo, too.
    (Plus, the ever present 4 TB external hard drive )YRMV
    Sharpone and Six Ball like this.
  12. arse_sidewards
    arse_sidewards
    from Central MA
    Fed honeypot solvent traps make great weld on breathers. 2 for $10 on Amazon and they even come with O-rings to seal the filter to the breather. The knurled grip area gives you a place to weld into without getting into the threads like a proper weld washer. This one is installed on a rear axle.
    Screenshot 2025-08-24 at 11.52.00 AM.png attachment(830).jpg attachment(829).jpg attachment(831).jpg
    LAROKE, Sharpone, LOST ANGEL and 3 others like this.
  13. Fabber McGee
    Fabber McGee
    Just looked on Amazon. They have 64 hits in various sizes. What are they originally made to do?
    Sharpone, Six Ball and Algoma56 like this.
  14. Wobbly
    Wobbly
    from UK
    A little tip when installing rear brake shoe return springs. Like most people I don't own return spring installation pliers and used to pull my hair out getting the return springs onto the anchor pin only to have them shoot off the screwdriver under full tension with the resulting shockwave making the brake ***embly fall apart. I overcome this by joining up 3 long cable ties and looping them around the cir***ference of the brake shoes to hold the complete ***embly in place. Once the cable ties are tight you can now take as many shots fitting the return springs without ***embly/re***embly of the brake components.
    Sharpone, HemiDeuce, Six Ball and 7 others like this.
  15. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    ;)Okay but, I've seen guys hook the shoes into the bottom adjuster, with spring,
    and the return springs onto the top anchor bolt.
    Then pulling the shoes apart enough to set the tops of the shoes around the anchor bolt. Now just push the hold down pin into place and connect the clip-washer onto the pin(s) one at a time.
    OR go BUY YOU the tool for the job. Can't be more than a large pizza.
    BTW, When I bought mine it was more than Pizza. Pizza was a buck then
    The Ford later style self adj. w/cable etc gets dicey with no tool.
    Still get the tool.;););)
  16. clem
    clem
    Use a cable tie (looped) in place of your screw driver, and use a pair of vice grips on the cable tie to pull the spring over to where you want it. Then once in place, cut the cable tie and pull it out.
    No springs popping off ……..
    Cable tie doesn’t damage the spring end as does using pliers or other tools on the spring and only stretches the spring the minimum amount required to get it in position.
    Handy tip, - use safety gl***es when doing it your way !
    Six Ball and osage orange like this.
  17. PHuscher
    PHuscher
    One of these has always been the easiest for me.
  18. Fabber McGee
    Fabber McGee
    About the price of a medium pizza here.
    https://www.amazon.com/dp/B00BR1BV8Q/?tag=atomicindus08-20
    Slightly different, but pretty close to what I paid for K-D brand 50 years ago. Stop chasing springs all around your shop or driveway for a half hour per corner and buy the tool. 4 seconds or less per spring and works every time.
  19. atch
    atch
    I don't know where I got it and I can't find one with Google; but I've got a one-piece rod like the right leg of the one in the link above and in the pic below. It, of course, doesn't have the curves on the other end. I also have one identical to the link but like/use the one-piece one and never get the "pliers" type out of the tool drawer. Next time I'm in my shop I'll snap a pic and load it here.
    EDIT: the site didn't like the pic I posted but take my word for it; it's nearly identical to the one in the link posted by Fabber McGee above.
  20. RodStRace
    RodStRace
    Yep, I don't have the big pliers. Just a bar that has the kink on it and the round end with a tab to pop them off. No fuss. The pliers have those on the ends of the handles and cost 12 bucks on average.
    Sharpone, X-cpe and Tow Truck Tom like this.
  21. atch
    atch
    Well, wouldn't you know it, the tool I mentioned above isn't in the tool drawer where it's supposed to be.
    The first pic below is all the brake tools that I found in said drawer. Top tool is what was mentioned above and I haven't used this one in over 30 years, probably over 40. Bottom three have one or both ends that are to replace the little "washer" that goes over the spring that holds the shoe at the right distance form the backing plate. The top of these three has the indention to "hook" over the stud to reinstall the "long" spring. The top "pliers" type has a similar indention on one of the handles. These indentions are shown close-up in the other two pix. The tool that I can't find looks like the center pic on one end and I honestly don't remember what the other end looks like. The last time I used it was about 9 years ago and I don't know where I misplaced it.
  22. Fabber McGee
    Fabber McGee
    The missing tool will be under the fridge in your shop when you move it to retrieve that last little bearing ball that just rolled under there.
    vtx1800, HemiDeuce, Six Ball and 2 others like this.
  23. atch
    atch
    If that's the case I'll need a dumpster to put all the stuff that's rolled under there.
  24. GuyW
    GuyW
    I just clamp the straight portion of a spring in vice-grips and pull it over...
    clem, Six Ball and osage orange like this.
  25. Six Ball
    Six Ball
    from Nevada
    The right length bungie will work for a while.
    jet996 likes this.
  26. patsurf
    patsurf
    well,pretty sure that confused me ...am i alone?
    deathrowdave likes this.
  27. deathrowdave
    deathrowdave
    from NKy
    Nope I don’t get it yet , but I ride a Harley I’m slow
    jet996 and patsurf like this.
  28. RodStRace
    RodStRace
    @patsurf I read it as using a bungie to wrap around the shoes as mentioned earlier with zip ties.
    Me, I always hung the shoes with the center pegs and springs, then depending on the adjuster/spring on the bottom, did that or the 2 top pin springs next.
    The wrap around the shoes is to help hold them in place for installing the 2 upper springs, I ***ume.
    X-cpe likes this.
  29. patsurf
    patsurf
    right from the first mention way back this has baffled me --the shoes are against the stop-are people trying to pull the tops of the shoes closer than that --(even possible?)--this is all crazy when the spring tool does everything!!
    X-cpe and RodStRace like this.
