Projects Fun Project or Nightmare? Fixing a 46 Ford
Discussion in 'The Hokey Ass Message Board' started by WhatDidIDo, Aug 15, 2025.
Tags:
  1. Y’all gonna need a bigger body hammer bro. Hehe.
    lothiandon1940 and WhatDidIDo like this.
  2. topher5150
    topher5150
    B.F.H.
  3. gene-koning
    gene-koning
    I would remove the inner panels long before I would consider adding heat to the outside skin.
    With the inner panels removed, you have direct access to the outer skin. Those bent inner panels are probably interfering with you straightening the outer skin.
  4. Are you aware of special drills just for doing spot welds? They are like mini hole saws designed to go through just the top panel. They are priceless for a job like this.
  5. Okie Pete
    Okie Pete
    Your making good progress looks great
    enloe likes this.
  6. Park by a telephone pole and hook the come along to the pole with cable and then grab the section nearest the dent and "Pull it out", it'll come out easy and then a little dolly and hammer and you'll be "SET"
  7. Greenblade
    Greenblade
    Good job so far
    Keep up the good work!
    enloe likes this.
  8. 325w
    325w
    Flat top Bob is in upper Northwest Tx. Also you might check Browns in Sunset Tx
    enloe likes this.
  9. bobss396
    bobss396
    Get out the pail of Bondo!:D:D:D
    enloe and guthriesmith like this.
  10. LSJUNIPER
    LSJUNIPER
    from ct
    WOW!!!!!!!!!!!
    enloe likes this.
  11. WhatDidIDo
    WhatDidIDo
    Slowly but not so surely...
  12. gene-koning
    gene-koning
    Looks like your having fun, at least at this point yet. Slowly is the proper direction.
  13. F-ONE
    F-ONE
    from Alabama
    Wonderful!!
    I’ll add my two cents….
    There’s plenty of 1946 Fordors restored or in various states of repair.
    If it was mine, I would get it as straight as possible.
    I would get the rear window repaired where it will take a window.
    I Would get things lined up where the deck lid opens and closes and will not leak.
    I would get it as square as possible.
    I would not do any final / fine body work.
    No bondo…
    No filler….
    I would just push it out and metal finish it.
    I would not worry about perfection.
    I would try to match that maroon where paint has to be removed.
    I would drive it wrinkles and all.
    Like I said there’s plenty of Fordors but not many have survived such.
    A little wrinkly but functional says, I survived and somebody loved me enough to get me going again.
    lothiandon1940, enloe, 53olds and 3 others like this.
  14. Okie Pete
    Okie Pete
    Looking good
    lothiandon1940 likes this.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    Squablow and lothiandon1940 like this.
  16. GasserTodd
    GasserTodd
    That, to me, would look like $600 very well spent, but then I completely lack skills and I farm everything out.
  17. catdad49
    catdad49
    Great progress, now comes the part where patience and the right touches bring it to the finish. Make tools if needed to get to the hard to reach parts, rebar works well. Less Is More!
  18. enloe
    enloe
    from east , tn.
    Cool Project
    Greenblade and lothiandon1940 like this.
