Technical 63 Country Squire late 1/2 2/3 shift
Discussion in 'The Hokey Ass Message Board' started by Ryans65, Aug 24, 2025.
  1. Ryans65
    Ryans65
    from Yulee FL
    Good afternoon Hambers,
    Here's a brief rundown of what I'm dealing with on my country squire:
    stock 352
    autolite 2100
    recently overhauled (not by me) MX
    The late shifting started when I pulled the sad autolite 2150 that was installed at some point and put in the correct 2100. I also had to redo some incorrect throttle linkage and set the bell crank per the factory ford manual. I've adjusted curb idle at about 500 rpm, it drives and idles very nicely, no rpm hunting, no exhaust pops, nothing.
    The only piece of information I am unsure about during the carb swap was when I was messing with the throttle linkage I was trying to make sure the linkage clears a power booster T installed at some point by the previous owner and while turning the throttle through its full range I felt it hit the kick down lever and it had some resistance but then free'd up. I didn't think anything about it until I went for a drive after all the carb work and noticed it shifting pretty high, approx. 30-35 1/2 and up to about 60 2/3. It did not do this before the carb was installed. I thought perhaps since this carb is giving the correct vacuum signal at idle then it must be the modulator, I adjusted the modulator out several times, driving after each change but no luck. The screw was protruding slightly past the vacuum ******. I replaced both soft vacuum lines, checked that the modulator held vacuum with my manual pump and it all checked out. I thought surely the modulator was sticking or something so I replaced it, no change. I dropped the pan, saw what I think is normal fine metallic particles and some other fuzzies but nothing out of the ordinary, inside looked remarkably clean. New Type F fluid, adjusted the level in neutral while warm, no change. Transmission has a great shift through the gears, including reverse but it will not shift earlier than the aforementioned speeds. I can check pressures per the manual if that's what I need to do but my gut tells me I'm missing something simple but I was not a ****** guy when I worked on cars. Everything else I own is a manual, even my diesel truck.... this old wagon might be too if this ****** needs to come out!! Long winded I know but I'm sorta stuck at the moment. Thank you HAMB.
    Deutscher likes this.
  2. jaracer
    jaracer
    What is your manifold vacuum at idle? Have you checked the vacuum at the modulator with a gauge? It should be the same and the modulator must be connected to manifold vacuum.
  3. ClayMart
    ClayMart
    As stated above, make sure the vacuum modulator is connected to a source of full manifold vacuum. Connect a vacuum gauge also to full manifold vacuum with enough hose to route it to the inside of the car. Drive it for a spell and observe the vacuum at idle, under acceleration and at a steady cruising speed of 30 to 50 mph and report back here with your findings.
  4. Ryans65
    Ryans65
    from Yulee FL
    Thank you both-
    Vacuum at warm idle is 18-19, I'll hook up a T and go for a ride.
  5. Oneball
    Oneball
    I’ve got a 62 Merc on a 2100. The only thing the throttle linkage does is activate the kickdown. Disconnect the throttle link to the gearbox and see if it is the same. I put a new vac can on mine and it made the change perfect. The change was just harsh in mine not early or late.
    jimmy six likes this.
  6. Ryans65
    Ryans65
    from Yulee FL
    I'll try this too, thank you.
    On my short drive to the gas station I saw about 15in at part throttle up to let's say 35/40 then a steady drop down to 5 or so at moderate to 3/4 throttle up to about 55. This was read from a vacuum T between the manifold and the modulator.
  7. Ryans65
    Ryans65
    from Yulee FL
    Another thing I'm probably wrong about but need to ask is if there should be any resistance on the kickdown rod if I try to actuate it by hand unhooked from the throttle bell crank.
  8. Oneball
    Oneball
    As you move the rod it’ll be loose until you get to a point where it activates the kickdown mechanism and then it’ll have the resistance of say a light switch. It just clicks on.
  9. Ryans65
    Ryans65
    from Yulee FL
    Ok, that's interesting, this one has zero feel in its full range of movement, no click no resistance.
  10. Oneball
    Oneball
    The range of movement should be really quite small. Then it just clicks. It’s not like the throttle. It’s only perhaps the last 1/4 inch of pedal travel that it moves through.
  11. Oneball
    Oneball
    Crawl underneath and see what it feels like when you move the lever on the trans itself.
  12. Ryans65
    Ryans65
    from Yulee FL
    Just unhooked both ends of the kickdown rod so I could feel the actual lever, it has about 3/8 travel but is loose with no distinct detent or click or anything.
    Edit: no tension on the kickdown rod is what I meant to say. It looks like in the manual there is a kickdown valve with a spring so I feel like I should get some sort of tension one way or the other.
  13. ClayMart
    ClayMart
    With a light foot on the pedal at a steady cruising speed, if the vacuum is too low it will delay the shift timing and shift bit harder. The trans will "think" you're climbing a grade, pulling a trailer or trying to p*** slower traffic.
    Your vacuum at idle would indicate that your initial timing is pretty much spot on. But maybe the mechanical and/or vacuum advance aren't working properly and the timing isn't advancing fully at steady part throttle or when accelerating. Though it would be odd if they started acting up just after a carb change.
  14. Ryans65
    Ryans65
    from Yulee FL
    Since the old carb (2150) was for a 79 289 I really went through everything to make sure I had the timing dialed including checking mechanical max advance and combined max advance. It's pretty spot on. I'm right at 10 degrees idle, 36 degrees mechanical and just shy of 50 total, maybe 48-49.
    The more I think about it I'm pretty sure there's more to this kickdown rod issue. When I set up the carb and linkage I used the Ford manual to set the bell crank and rod length per the book. When I pushed on the kickdown rod during setup I felt a single click that I have not felt since. I think perhaps whomever rebuilt this trans maybe had the internal lever lined up in correctly and now Im just feeling a loose lever and driving a car with the kickdown rod "depressed" constantly. I'll need to pull the pan and look up in there, looks like you can see the manual lever and kickdown lever without taking anything else apart. Time to get covered in trans fluid again!
  15. jaracer
    jaracer
    Only with the engine running and it will only be at the end of travel.
    Oneball likes this.
  16. Ryans65
    Ryans65
    from Yulee FL
    Thank you, I tried that the other day when I got to thinking something wasn't right with the kickdown but before I threw a new modulator in there. I'm going to drop the pan tonight and see what's going on with the kickdown lever on the valve body side.
  17. tim troutman
    tim troutman
    if it worked fine before you changed the carb it is probably some thing you changed while working on it maybe set the linkage back to the incorrect setting make sure the vacuum ports are in the same position put the modulator back in the old position try again
  18. Ryans65
    Ryans65
    from Yulee FL
    Thank you, I've taken the linkage out of the equation and worked the kickdown lever on the trans by hand. According to the manual the kickdown valve is supposed to be depressed when putting on the valve body so that means there must be some tension on the lever that holds it in the upward position where the kickdown rod from the bellcrank attaches to the lever. Mine does not have any tension at all, you can push it up and it falls back down with gravity.
  19. Ryans65
    Ryans65
    from Yulee FL
  20. Ryans65
    Ryans65
    from Yulee FL
    The kickdown valve is definitely stuck in its bore. I'm going to pull the valve body and see why, I'd imagine some junk from somewhere caught in the valve body. I'll keep you guys posted.
  21. ClayMart
    ClayMart
    It'll be interesting to see how this affects your part throttle upshifting. As has been already mentioned I figured the kickdown valve and linkage only affected full-throttle downshifts.
  22. Ryans65
    Ryans65
    from Yulee FL
  23. Ryans65
    Ryans65
    from Yulee FL
    I had to use some pliers to pull the valve out of the body but it came out and other than some very light scratches it looked fine. I rolled it on a flat surface and it's not bent either. Looking down the bore I couldn't see anything that would obstruct it but carefully using a 90 degree pick I was able to pull some gunk out. I put the valve in my drill and using some polishing rouge I polished the valve and now it slips in and out of the bore very nicely. The spring keeps pretty good tension on the valve too so now it makes sense why I was expecting tension on the arm and not getting any feel.
    What I think happened here was a couple different things all culminating into this odd coincidence. The 2150 carb was not correct for this obviously, the linkage was backwards, there was no dash pot. Someone setup the bell crank to allow this carb to work sort of but the way it was adjusted it never touched the kickdown at the far end of its throttle range. When I adjusted the bell crank properly it now engaged the kickdown but the first time it did so it pushed the valve into its bore and stuck it there delaying both upshifts no matter the vacuum or modulator adjustment. I suspect this trans was indeed rebuilt however they probably did a quick sloppy job and did not clean all the bores. The stuff in the kickdown bore was crusted on there pretty good. There's some crud here and there I will clean out tomorrow but I'm out of energy and can't find my mineral spirits. Yeehaw.
    jaracer and Deutscher like this.
  24. patsurf
    patsurf
    i think a little diesel will help flush before a drain and filter change...
  25. Ryans65
    Ryans65
    from Yulee FL
    It could probably use it, I wish these had more than just this gravel filter too! I think as I get some real miles in this thing we'll see how this trans acts. Only other thing I've noticed is a noise in first gear on accel/ decel but it could be the pinion bearing also. Haven't really had it driving long enough to get a good feel for it yet. I'll probably see if I can score a cheap spare MX at turkey run this year too. I'm confident I could rebuild one of these, always wanted to overhaul an auto but never really needed to working on modern stuff day to day.
  26. Ryans65
    Ryans65
    from Yulee FL
    IMG_0624.png I ended up taking the whole valve body apart suspecting there was more crud in there somewhere but aside from a few tiny bits here and there it was surprisingly clean. I think whatever was stuck in the kickdown bore was leftover from the overhaul. I put it all back together, screwed the vacuum modulator back to where it was new and went for a drive. I now have really smooth 1/2 shifts around 15 mph at light throttle and 2/3 around 30-35ish. The kickdown works as it should and now with the right carb it's running and driving really really nice!
  27. patsurf
    patsurf
    you get the 'squirrel' award for quick thorough repair!...well done!
  28. Ryans65
    Ryans65
    from Yulee FL
    HA! Thanks, this was one of those old car problems that was literally keeping me up at night!
  29. ClayMart
    ClayMart
    Thanks for reporting back . . . Many folks don't. :(
    Your problem may have still been modulator related. There may have been a bit of debris in the modulator valve bore that wasn't allowing the valve to move freely. The trans may have not been able to accurately sense the difference between light and heavy throttle application. You may have dislodged something while inspecting and cleaning the valve body.
  30. Oneball
    Oneball
    Great result and that is a wicked looking car, pretty much my dream Galaxie.
